PWM OUTPUT
UDIPTA
PWM OUTPUT
PostPosted: Sat Aug 22, 2009 5:05 am     Reply with quote
HOW CAN I GET PWM OUTPUT FROM PIC MICRO-CONTROLLER BASED BOARD?PLEASE LET ME KNOW THE IC NO. HAVING PWM OUTPUTS?
hobby85
Re: PWM OUTPUT
PostPosted: Sat Aug 22, 2009 5:27 am     Reply with quote
hey, i just figured this out a couple of days ago so i can help you. I used a 16f690 but you can use any pic which has pwm capability. The code is in another post a couple of days ago. Search 16f690 and pwm.
PostPosted: Sat Aug 22, 2009 11:36 am     Reply with quote
Here is an example program to use two PWM channels on a 16F877:
http://www.ccsinfo.com/forum/viewtopic.php?t=17729&start=1
UDIPTA
PostPosted: Mon Aug 24, 2009 8:34 am     Reply with quote
How can I drive a solenoid operated valve with the PWM output from PIC16F876A, such that flow through the valve will be controlled by the duty cycle of the PWM output? I am afraid that the MCU output can not drive the solenoid operated valve directly as it has the current rating of 2-2.5 Amps.
Please help.
PostPosted: Mon Aug 24, 2009 1:10 pm     Reply with quote
Post a link to the data sheet for your valve.
