spi_write()... or just handling int8 |
Posted: Mon Aug 31, 2009 10:22 am |
Hi
Take a look at this.
The first ex. is clean and nice:-)
The second ex. is not so clean, why?
I have no success with casting (int8) in the second ex.
any good explanation?
.................... tmp=x>>8&0xff;
0090: MOVFF x+1,tmp
.................... spi_write( tmp );
0094: MOVF SSPBUF,W
0096: MOVFF tmp,SSPBUF
009A: RRCF SSPSTAT,W
009C: BNC 009A
.................... spi_write( x>>8&0xff );
009E: MOVFF x+1,@@60
00A2: CLRF @@x61
00A4: CLRF x61
00A6: MOVF SSPBUF,W
00A8: MOVFF x+1,SSPBUF
00AC: RRCF SSPSTAT,W
00AE: BNC 00AC
Posted: Mon Aug 31, 2009 3:01 pm |
Quote: | The second ex. is not so clean, why? |
It appears that no matter how it's done, the compiler puts in 2 or 3
ROM words of unnecessary instructions. The "make8" method has
the least number (only 2 words) of all the methods shown below. But
how important is this ? Why worry about optimizing out 2 instructions ?
#include <16F877.H>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
int16 x;
x = 0x1234;
// Try different ways of getting the MSB of 'x' for the
// spi_write() function:
spi_write(x >> 8);
spi_write(make8(x, 1));
spi_write(x/256);
John P
Posted: Tue Sep 01, 2009 7:24 am |
My favorite way to get an 8-bit quantity out of an int16 would do it like this:
#include <16F877.H>
int16 x;
#byte x_low = x
#byte x_hi = x+1
x = 0x1234;
spi_write(x_low); // Should send 0x34
spi_write(x_hi); // Should send 0x12
