Andrew76 Guest
| PIC24F PWM |
Posted: Wed Mar 25, 2009 3:45 pm |
I everyone,
I'm trying to work with PIC24F and PWM module.
What I would like to do is to control the frequency and the duty cycle of the PWM.
My code is the following:
#pin_select OC1 = PIN_B6
setup_timer2(TMR_INTERNAL | TMR_DIV_BY_1);
set_compare_time(1, 0x1FFFF);
set_pwm_duty(1, 200);
setup_compare(1, COMPARE_PWM | COMPARE_TIMER2 |
Something works but not as I intend.
The frequency and the duty cycle still remain always the same.
I've checked PR1 register and it's always on 0xFFFF
Even changing manually, it returns to this value.
So, if I want to change frequency, I'm not able.
About the duty cycle, the register OC1R still remain at the same value and doesn't change even if programmed.
Manually same strange thing: the system doesn't change that value.
How can I do?
What's wrong with his PWM? |
Posted: Wed Mar 25, 2009 5:51 pm |
| You should be aware of possible bugs with PCD built-in functions, there have been already quite a lot. Unfortunately I didn't use PWM and only basic timer functions with PIC24 up to now |
Andrew76 Guest
Posted: Thu Mar 26, 2009 2:10 am |
| Thanks!!! |
jordanPSI Guest
| Re: PIC24F PWM |
Posted: Thu Aug 20, 2009 9:47 am |
| Andrew76 wrote: |
I had the same issue with the PIC24FJ256GA106.
Try something like this:
| Code: | setup_timer2(TMR_INTERNAL | TMR_DIV_BY1);
set_pwm_duty(1,200);
setup_compare(1, COMPARE_PWM_EDGE | COMPARE_TIMER2 | COMPARE_TRIG_SYNC_TIMER2); |
The part I was missing was the "COMPARE_TRIG_SYNC_TIMER2". |
