PCD: Just need a sanity check!
Robert Kinchin
PostPosted: Wed Aug 19, 2009 5:46 am     Reply with quote
Hi, oh the problems of using a new processor lol,
Im using the PIC24FJ256GB110 in a USB enviroment and I think my problems my be hardware, but need a sanity check.
I have installed the usb_hid driver almost direct from the example just changed the pll to 3 for my 12Mhz example (using a development board while I wait for PCB's to be manufactured)
So far I have 2 problems
1. MPLAB complains that the configeration is illegal and the compiler does seem to not set the RESO bit (reserved = 1) and other reserved bits is this a problem i let MPLAB correct it.
2. I can't get the USB to enumerate, even though the code works fine when compiled for the 18F4550 so unless its the specific processor hid file i guess it hardware.
I have the USBGEN off and supply VUSB 3.3V myself and VBUS is supplied from the host usb, its only 4 wires lol
Any help please
Robert
PostPosted: Wed Aug 19, 2009 6:01 am     Reply with quote
I can't be of much help because I don't have the PIC24 compiler, but in order for other people to be able to help you: post your compiler version number.
PostPosted: Wed Aug 19, 2009 6:19 am     Reply with quote
CCS PCD C Compiler, Version 4.097
Robert Kinchin
Solved
PostPosted: Wed Aug 19, 2009 7:45 am     Reply with quote
It was hardware, development board problems, had to break out USB pins
Robert Kinchin
Still would like to know about configuration problem though
PostPosted: Wed Aug 19, 2009 10:19 am     Reply with quote
Still would like to know about configuration problem though if any one knows of this
FvM
PostPosted: Wed Aug 19, 2009 1:05 pm     Reply with quote
Incorrect set reserved configuration bits can be found also with other PIC24F chips. It's generally O.K. to let MPLAB correct them. The more interesting question is, if they could cause problems with other programmers, that don't correct them.
