Change pwm 18f4431
jacob
Change pwm 18f4431
PostPosted: Sat Aug 08, 2009 6:19 am     Reply with quote
Hi...I wanna move PWM0,1 to PWM6,7.
I tried to change PWMCON0 (01010000) for enable all PWM.
It's still out at PWM0,1 ....... I have no idea how it work.
MOVLW    0x00
MOVWF    PTCON0
MOVLW    0xC0
MOVWF    PTCON1
MOVLW    0x20
MOVWF    PWMCON0
MOVLW    0x01
MOVWF    PWMCON1
MOVLW    0b00001110
MOVWF    DTCON
CLRF     PTMRL
CLRF     PTMRH
MOVLW    0x00
MOVWF    PTPERH
MOVLW    0xFF
MOVWF    PTPERL
MOVLW    0xFF
MOVWF    OVDCOND
MOVLW    0x00
MOVWF    OVDCONS
Thanks a lot.....!!! Crying or Very sad
PostPosted: Sat Aug 08, 2009 7:30 am     Reply with quote
You can't.....
Look at Fig17-1.
PWM 6/7, are the outputs for channel 3. You can't move the channel 0 outputs 'to' these.
You need to enable/use channel3, to get outputs on these pins.
PostPosted: Sat Aug 08, 2009 10:59 am     Reply with quote
This post shows how to enable PWM on the six channels of the 18F4431:
http://www.ccsinfo.com/forum/viewtopic.php?t=37206&start=2
Also, this is a C forum for the CCS compiler. If you're programming
in MPASM, then you should ask your questions in the Microchip PWM
forum:
http://www.microchip.com/forums/tt.aspx?forumid=36
Or, in the Microchip 16-bit core (i.e., 18F PICs) forum:
http://www.microchip.com/forums/tt.aspx?forumid=7
