lecutus
Input doesn't stay the same when it's output |
Posted: Thu Aug 13, 2009 8:54 am |
Why would an input of 5000, be written to and eeprom is later read as something different.
The ID number is what is important here.
What am I missing? Why the conversion? It needs to read in a number, keep the format, and display the ID in the same format
Let show the logging of the action:
08/12/2009 15:47:50.003 --> get_setup()>>>>>>>>>>>>>>>>>>>>>>>
08/12/2009 15:47:50.003 --> ID=5000
08/12/2009 15:47:53.097 --> Cat=01 Cummins=02 Detroit=03 Enter Engine Number=02
08/12/2009 15:47:55.003 --> Cat=01 Twin Disk=02 Allison=03 Enter Trans Number=.# #03
08/12/2009 15:48:00.159 --> inside write_data()
08/12/2009 15:48:00.159 --> i=0, offset=0, data =5000
08/12/2009 15:48:00.159 --> id_num=e_data[0]=136,id_num=e_data[1]=0, engine=e_data[2]=0, trans=e_data[3]=0
08/12/2009 15:48:00.159 --> This from - read_e_data() Id_Num= 0136 Engine=00 Trans=00
08/12/2009 15:48:00.175 --> i=1, offset=0, data =5000
08/12/2009 15:48:00.175 --> id_num=e_data[0]=136,id_num=e_data[1]=1, engine=e_data[2]=0, trans=e_data[3]=0
08/12/2009 15:48:00.175 --> This from - read_e_data() Id_Num= 0392 Engine=00 Trans=00
08/12/2009 15:48:00.175 --> write_eeprom_16bit - offset_id=0 ,id_num=392
08/12/2009 15:48:00.191 --> write_eeprom - offset_e=2 ,engine=0
08/12/2009 15:48:00.191 --> write_eeprom - offset_t=3 ,trans=0
08/12/2009 15:48:00.206 --> LEAVING write_data()
08/12/2009 15:48:00.206 --> This from - get_setup() Id_Num= 0392 Engine=00 Trans=00
08/12/2009 15:48:00.206 --> <<<<<<<<<<<<<<<<<<<<<<<<<<LEAVING get_setup()
And now the software.
Code: | #include <18F258.h>
#fuses HS,PROTECT,NOLVP,WDT32,nowdt
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 12
#include <can-18xxx8.c>
#byte pir1=0x0F9E
#define TMR1iF 0X00
#rom int 0xf00000={0x00,0x00,0x00,0x00}
#define offset_id 0x00 // original
#define offset_e 0x02// original
#define offset_t 0x03// original
//below is an experiment in shifting to right the starting address
#define offset_id 0x02
#define offset_e 0x04
#define offset_t 0x05
#include <stdlib.h>
#include <input.c>
void read_e_data() //reads stored values from eeprom
int8 count=0,address=0;
int8 e_data[4]; //original
//int16 e_data[4];// don't use!!!!!!
for(address=0; address<=4; ++address)
e_data[count++]=READ_EEPROM(address); } // LOADS E_DATA ARRAY, then feeds the parts
printf(" id_num=e_data[0]=%u,id_num=e_data[1]=%u, engine=e_data[2]=%u, trans=e_data[3]=%u ",e_data[0],e_data[1],e_data[2], e_data[3]);
line_feed();
id_num=make16(e_data[1],e_data[0]);
engine=e_data[2];
trans=e_data[3];
line_feed();
printf("This from - read_e_data() Id_Num= %04lu Engine=%02u Trans=%02u",id_num,engine,trans);
line_feed();
void write_eeprom_16bit(int offset, int16 data)
{int8 i;
for (i=0;i<2;i++)
write_eeprom(i+offset,*(&data+i));
printf("i=%u, offset=%u, data =%lu",i, offset , data);
line_feed();
read_e_data();
void write_data() //store operating prarmeters in eeprom
printf(" inside write_data()");
line_feed();
write_eeprom_16bit(offset_id,id_num);
printf(" write_eeprom_16bit - offset_id=%u ,id_num=%lu ", offset_id,id_num);
line_feed();
//write_eeprom(offset_id,id_num);
write_eeprom(offset_e,engine);// orginal
//write_eeprom_16bit(offset_e,engine);
printf(" write_eeprom - offset_e=%u ,engine=%u ", offset_e,engine);
line_feed();
write_eeprom(offset_t,trans);//original
//write_eeprom_16bit(offset_t,trans);
printf(" write_eeprom - offset_t=%u ,trans=%u ", offset_t,trans);
line_feed();
printf(" LEAVING write_data()");
line_feed();
void get_setup()
printf("get_setup()>>>>>>>>>>>>>>>>>>>>>>>");
line_feed();
setup_wdt(wdt_off);
line_feed();
printf("ID="); //enter id number for pumper
id_num=get_long(); //orignal statement
//scanf(%4Lu, id_num); //my suggestion,
//gets(id_num);//nope!
line_feed();
printf("Cat=01 Cummins=02 Detroit=03 Enter Engine Number=");
engine=get_int();
line_feed();
printf("Cat=01 Twin Disk=02 Allison=03 Enter Trans Number=");
trans=get_int();
line_feed();
write_data();
printf("This from - get_setup() Id_Num= %04lu Engine=%02u Trans=%02u",id_num,engine,trans);
line_feed();
//setup_wdt(wdt_on);
printf(" <<<<<<<<<<<<<<<<<<<<<<<<<<LEAVING get_setup()");
line_feed();
setup_wdt(wdt_on);
The set up a PIC18F258, icd-u40, and PCWHD 4.079
Background, I'm not new to C, I've using on and off since college. Reccently, last six months, I've been working C#, love it!!!!!!!!!!!!!!!!!!!!!!!!
What I am new at is the PIC programming part. I usually don't program at this level.
[/img] |
mkuang
Posted: Thu Aug 13, 2009 9:00 am |
I don't know about the rest of your code but you better fix this:
You want the WDT on or not?
In addition there is no main function unless I am missing something.
This code actually compiles? |
Wayne_
Posted: Thu Aug 13, 2009 9:06 am |
mkuang wrote: | I don't know about the rest of your code but you better fix this:
There is actually no problem with this, I do a similar thing
#fuses NOWDT, WDT1024
I then start the WDT in software to wake me up from sleep mode :-
setup_wdt(WDT_ON); // If sleep is called then WDT will wakeup and NOT reset
sleep(); // Preserve Power (WDT1024 x 4)ms (4.096 seconds)
setup_wdt(WDT_OFF); |
lecutus
Yes it compiles |
Posted: Thu Aug 13, 2009 9:25 am |
To Mkuang
This is obviously only part of the program. For the sake of brevity, I only posted the setup and the section that I'm have trouble with.
I'll post the entire program if need be.
L. |
mkuang
Posted: Thu Aug 13, 2009 9:38 am |
Why don't you take the time to create a simple test program showing how you are storing ID number to eeprom and then reading and assembling it? For starters just declare long ID = 5000, save it to eeprom, then read it back out and see what you get. |
lecutus
Already have |
Posted: Thu Aug 13, 2009 9:45 am |
I've already done that. That's why I posted only the part I'm having problem with, everything else works fine.
If you notice the log in the very first of this thread I inputted the number 5000 and got out something else.
I write very sparse code with lots of printf's for this very reason: to see when it goes bad.
L |
Wayne_
Posted: Thu Aug 13, 2009 10:03 am |
This might be due to the line
&data returns a pointer to a 16 bit value. When you increment a pointer in C it should take into account the size of the type of data it is pointing to. So if
&data = 0 and data points to an int16 then &data + 1 should make
&data = 2
you can fix this by casting to an 8 bit pointer so
(char *)&data + 1
or in your case
write_eeprom(i+offset,*((char *)&data + i));
try it and let us know.
As stated a compilable program would help us to find and fix your problem, It may also help you find it yourself as the process of creating a compilable program using the parts of your program which seem to fail may lead you to discovering the problem yourself.
A lot of time the problem is a simple mistake but to trawl though someone elses code and not to be able to test the result ourselves due to it NOT being compilable usually results in very little help from our part. ME included.
There have been many times I have seen a post on here with a whole lot of un-compilable code and turned away because it is too much hassle on my part. |
mkuang
Posted: Thu Aug 13, 2009 10:06 am |
Looks like you are missing a nibble or two here and there.
5000=0b 0001 0011 1000 1000 //this is id_num
392 = 0b 0000 0001 1000 1000 //this is what you are getting out
136 = 0b 0000 0000 1000 1000 //this is data[0] which is correct
However, your data[1] is showing it is equal to 1 where it should be equal to 0b 0001 0011 which is 19 in decimal.
I would double-check this:
{int8 i;
for (i=0;i<2;i++)
line_feed();
read_e_data();
I can't say it is incorrect but it looks a bit funky. I wouldn't code like that just because it is very hard to read.
How about simplifiying it a bit by doing this:
int8 data_lsb, data_msb;
data_msb = make8(data,1) // gets msb of data
data_lsb = make8(data,0) // gets lsb of data
write_eeprom(offset, data_lsb);
write_eeprom(offset+1, data_msb);
read_e_data();
The entire program |
Posted: Thu Aug 13, 2009 11:23 am |
I knew there was something skewed on my end. Thanks to both of you guys, I have a another way to look at this. I'll give both a try.
For the record I inherited this project so some of it is hard to read. But I'll take care of that.
Once again thanks, I'll update later.
L
Here's the entire program.
//X361 RS232 THRL_SHFT
//PROGRAM TO SEND SWITCH STATUS TO LOCAL CONTROL
//WAITS FOR REQUEST FROM LOCAL CONTROL
// PGN300 IF LOCAL SWITCHES
// BUFFER[0] SWI STATUS
// BUFFER[1] PLUNGER LUBE AUTO/MAN
// IF BUFFER[2,3] LESS THAN 0XFF THEN VALUE IS REQUESTED RPM
// IF BUFFER[4,5] LESS THAN 0XFF THEN VALUE IS REQESTED OVER PRESSURE
// IF BUFFER[6] LESS THAN 0XFF THEN VALUE IS REQESTED GEAR
// BUFFER[7] NOT USED
// PGN301 IF REMOTE SWITCHES
// 0=NO ACTIVITY
// 1=THROTTLE UP
// 2=THROTTLE DOWN
// 3=SHIFT UP
// 4=SHIFT DOWN
// 5=SET PRESSURE UP
// 6=SET PRESSURE DONW
// 7=START ENGINE
// 8=STOP ENGINE
// 9=E-STOP ENGINE
//10=NEUTRAL & IDLE ENGINE
//11=SPARE#1
//12=SPARE#2
// 01/30/07 clean up problem with momentary rpm going to 0000
// missing break after spn detection
//01/20/09 eliminate the retrun of rpm/gear/ovp/swi
// add E and T for eng and trans equiped
//01/31/09 add id to incoming string
//7.23.09 - added id parse routine id_num at the begining to keep truks other than the one
// that's suppose to have info
//7.31.09 - checking all routines for protocol, form, and definitions
//8.03.09 - From this date on there will be modification no tof the orignal plan
//8.13.09 - Reached out to CCS community for help. Going to save this as reference
// still having conversion problems - X361 RS232 THRL_SHFT_ID.N.0803.2
//8.13.09 - using X361 RS232 THRL_SHFT_ID.N.0813.09.1
#include <18F258.h>
#byte pir1=0x0F9E
#define TMR1iF 0X00
//#define offset_id 0x00 // original
#include <stdlib.h>
#include <input.c>
int8 swi_status=0,loop_cnt=0,/*tmp_port,*/conv_lok,req_gear; //buffer counter
int8 sel_gear,cur_gear,gear, fuel_psi,oil_psi,water;
int buffer[8],rx_len,rxstat;
int32 rx_id,rx_ad,hrs;
int1 /*tf_send_status=false,*/tf_lube_ovr=false/*tf_eng_run=false*/;
//int1 tf_psi_lo=false,tf_temp_hi=false;
int16 rpm,outspeed,inspeed,pressure_out,lube_psi,lube_temp;
int16 pressure_max,crpm,volts,injt_psi,spn/*rpm_pre,rpm_total=0,rpm_temp*/;
float bpm;
int8 rm_volts,rm_hrs,alr_pump,fmi, spn_count=0,fmi_count=0/*,rpm_cnt*/;
//int32 spn_fmi;
int8 k_char,x=0;
int16 x_cnt;
int1 tf_rs232=false,tf_data_ok=false,tf_send_can=false,tf_send_232=false;
char s1[30];
int16 rpm_rs=740,ov_press_rs=7500,pump_id=0,id_num;
int8 swi_rs=0,gear_rs=125,cnt_send_can=0,engine=0,trans=0;
void line_feed()
{printf("\r\n");}
/*void read_e_data() //reads stored values from eeprom
//int8 e_data[4]; //original
int16 e_data[4];
printf(" e_data[1]=%u ,e_data[0]=%u ,id_num ",e_data[1],e_data[0]);
line_feed();
engine=e_data[2];
trans=e_data[3];
line_feed();// LOADS E_DATA ARRAY, then feeds the parts
line_feed();
line_feed();
engine=e_data[2];
trans=e_data[3];
line_feed();
line_feed();
{int8 i;
for (i=0;i<2;i++)
line_feed();
read_e_data();
line_feed();
line_feed();
line_feed();
line_feed();
line_feed();
void get_setup()
line_feed();
setup_wdt(wdt_off);
line_feed();
line_feed();
engine=get_int();
line_feed();
trans=get_int();
line_feed();
write_data();
line_feed();
line_feed();
setup_wdt(wdt_on);
void get_input_232(char* s, int max)
int len;
char c;
printf("inside get_input_232() >>>>>>>>>>>>>>>.........>>>>>>");
line_feed();
--max;
len=0;
do {restart_wdt();
c=getc();
if(c==8) { // Backspace
if(len>0) {
len--;
putc(c);
putc(' ');
putc(c);
} else if ((c>=' ')&&(c<='~'))
if(len<max) {
s[len++]=c;
//putc(c);
} while(c!=38);
s[len]=0;
printf("LEAVING get_input_232()<<<<<<<<<<<<<...........<<<<<<<<<<");
line_feed();
void ck_rs232()
//printf("inside ck_rs232() >>>>>>");
//line_feed();
if (kbhit())
k_char=getc();
if (k_char=='!')
tf_RS232=true;
x=0;
x_cnt=0;
tf_data_ok=false;
output_low(pin_b5);
if ((k_char=='i') | (k_char=='I')) get_setup(); // <<<<<<<<<<
if (tf_rs232)
get_input_232(s1, 30);
tf_rs232=false;
tf_data_ok=true;
output_high(pin_B5);
//x=0;while (x<24) {putc(s1[x]);x++;}
//printf("LEAVING ck_rs232() <<<<<<<<<<");
//line_feed();
void process_rs232()
char r[5],g[5],op[6],sw[5],id[5];// this also shows original order
//char id[5],r[5],g[5],op[6],sw[5];
int8 x1=0;
tf_data_ok=false;
x=0;x1=0; while (s1[x1]<0x3a)
{ x1++;
if (s1[x1]>0x2f) {r[x]=s1[x1];x++;x1++;} //get rpm string
r[x]=0; //add null to end of string
x=0;x1++; while (s1[x1]<0x3a)
{if (s1[x1]>0x2f) {g[x]=s1[x1];x++;x1++;} }//get gear string
g[x]=0; //add null to end of string
{if (s1[x1]>0x2f) {op[x]=s1[x1];x++;x1++;}} //get over pressure string
op[x]=0; //add null to end of string
{if (s1[x1]>0x2f) { sw[x]=s1[x1];x++;x1++;}} //get switch status string
sw[x]=0; //add null to end of string
{if (s1[x1]>0x2f) {id[x]=s1[x1];x++;x1++;}}//get pump_id string
id[x]=0; //add null to end of string
// putc(10);putc(13);
//x=0;while (x<strlen(r)) {putc(r[x]);x++;} putc(10);putc(13);
//x=0;while (x<strlen(g)) {putc(g[x]);x++;} putc(10);putc(13);
//x=0;while (x<strlen(op)) {putc(op[x]);x++;} putc(10);putc(13);
//x=0;while (x<strlen(sw)) {putc(sw[x]);x++;} putc(10);putc(13);
// pump_id=atol(id);
rpm_rs=atol(r); //convert string to number
gear_rs=atoi(g);
ov_press_rs=atol(op);
swi_rs=atoi(sw);
pump_id=atol(id); // original place
printf("RPM=%lu Gear=%u OP=%lu SWI=%u ID=%lu\r\n",rpm_rs,gear_rs,ov_press_rs,swi_rs,pump_id);
if (pump_id==id_num)
{tf_send_can=true; //set true to send received command via j1939
cnt_send_can=0; //init number of times to send j1939 packet with 232 com.
tf_send_232=true;} //set true to return data string
void get_swi_status()
{ int8 port;
swi_status=0; //assume all switches off
tf_lube_ovr=0; //assume lube override=false
port=input_a();
delay_ms(1);
if (!bit_test(port,0)) swi_status=1; //throttle up
if (!bit_test(port,1)) swi_status=2; //throttle down
if (!bit_test(port,2)) swi_status=3; //shift up
if (!bit_test(port,3)) swi_status=4; //shift down
if (!bit_test(port,4)) swi_status=5; //max up
if (!bit_test(port,5)) swi_status=6; //max down
port=input_c();
delay_ms(1);
if (!bit_test(port,0)) swi_status=7; //start
if (!bit_test(port,1)) swi_status=8; //stop
if (!bit_test(port,2)) swi_status=9; //e-stop
if (!bit_test(port,3)) swi_status=10;//neutral/idle
if (!bit_test(port,5)) tf_lube_ovr=true; //lube override=true;
void ck_j1939_input()
{int16 a;
//printf("inside ck_j1939_input() >>>>>>");
//line_feed();
if (can_kbhit())
{restart_wdt();
can_getd(rx_id, &buffer[0],rx_len,rxstat);
rx_ad=rx_id&0x000000Ff; //get source address
if (rx_ad==05) req_gear=buffer[2]; //if source address=05 buffer[2]=req_gear;
if (rx_ad==44) {crpm=crpm=make16(buffer[2],buffer[1]); //store req spd buffer
crpm=crpm>>3; //calculate speed received rpm/8
rx_id=rx_id&0x00ffff00; //mask out irrevllant data
rx_id=rx_id>>8; //shift data to right 8 times
switch (rx_id)
{case (61442) : {conv_lok=buffer[0] & 0x04;
outspeed=make16(buffer[2],buffer[1]);
outspeed=outspeed>>3; //divide by 8
inspeed=make16(buffer[6],buffer[5]);
inspeed=inspeed>>3; //divide by 8
}break;
case (65226) : {fmi=buffer[4]&0x1f;
spn=buffer[2];
spn_count = 20;
fmi_count = 20;
}break;
case (61444) : {*(&rpm)=buffer[3];
*(&rpm+1)=buffer[4];
break; //correct by dividing by 8
case (61445) : {sel_gear=buffer[0];
cur_gear=buffer[3];}break;
case (65271) : {volts=make16(buffer[5],buffer[4]);
rm_volts=(volts%20)>>1;volts=volts/20;
}break;
case (65263) : {a=(long)buffer[3]*58;oil_psi=a/100;
a=(long)buffer[0]*58;fuel_psi=a/100;}break;
case (65262) : {a=buffer[0]-40;
a=(long)a*9;
a=a/5;
water=a+32;}break;
case (65253) : {hrs=make32(buffer[3],buffer[2],buffer[1],buffer[0]);
rm_hrs=(hrs%20)>>1;hrs=hrs/20;
}break;
case(65143) : {pressure_out=make16(buffer[1],buffer[0]);
lube_psi=make16(buffer[3],buffer[2]);
lube_temp=make16(buffer[5],buffer[4]);
}break;
case(302) : pressure_max=make16(buffer[1],buffer[0]);break;
case(303) :{alr_pump=buffer[0];
*(&bpm)=buffer[1];
*(&bpm+1)=buffer[2];
*(&bpm+2)=buffer[3];
*(&bpm+3)=buffer[4];
if (bpm>99) bpm=0;}break;
case (65243) : {*(&injt_psi) =buffer[2];
*(&injt_psi+1)=buffer[3];
injt_psi = (injt_psi*58)/100;}
default :{//spn=0;
// printf("LEAVING ck_j1939_input() <<<<<<<<<<");
//line_feed();
void RS232()
printf("inside RS232()>>>>>>");
line_feed();
output_low(pin_b4);
printf("I%04lu",id_num);
rpm=rpm>>3; //rpm
printf("R%04lu",rpm);
switch (cur_gear) //gear
{ case (124) : gear = 1; printf("G0%u", gear); break;
case (125) : gear = 2; printf("G0%u", gear); break;
case (126) : gear = 3; printf("G0%u", gear); break;
case (127) : gear = 4; printf("G0%u", gear); break;
case (128) : gear = 5; printf("G0%u", gear); break;
case (129) : gear = 6; printf("G0%u", gear); break;
case (130) : gear = 7; printf("G0%u", gear); break;
case (131) : gear = 8; printf("G0%u", gear); break;
case (132) : gear = 9; printf("G0%u", gear); break;
case (133) : gear = 10; printf("G%u", gear); break;
default : {}; break;
//oil pressure
printf("O%03u", oil_psi);
//water temp
printf("C%03u",water);
//battery volts
printf("V%02lu.%u", volts, rm_volts);
//pump speed
printf("W%04lu",outspeed);
//fuel pressure
printf("F%03u", fuel_psi);
//convertor lock
printf("L%u",conv_lok);
//ov pressure set
printf("S%05lu", pressure_max);
//pump output pressure
if (pressure_out>15000) pressure_out=15000;
printf("P%05lu", pressure_out);
//pump lube pressure
printf("X%03lu", lube_psi);
//pump lube temperature
printf("Y%03lu", lube_temp);
//barrels per min
if (bpm<1) printf("B0%02.2f",bpm);
if ((bpm>=1)&&(bpm<10)) printf("B0%2.2f",bpm);
if (bpm>=10) printf("B%2.2f",bpm);
//engine hrs
printf("H%05lu", hrs);
printf("E01T01");
//diagnostics spn
printf("D%04lu", spn);
//diagnostics fmi
printf("Z%04lu",pump_id);
printf("_%02u", fmi);
printf("!\r\n"); //delimiter
tf_send_232=false;
output_high(pin_b4);
printf("LEAVING RS232()<<<<<<<<<<");
line_feed();
void send_swi_status()
{if (tf_send_can) //if true send this data via
{buffer[0]=swi_rs; //swi status packet
buffer[1]=0x00;
buffer[2]=*(&rpm_rs);
buffer[3]=*(&rpm_rs+1);
buffer[4]=*(&ov_press_rs);
buffer[5]=*(&ov_press_rs+1);
buffer[6]=gear_rs;
buffer[7]=0xff;
}else //else only send swi_status
{buffer[0]=swi_status;
buffer[1]=0x00;
buffer[2]=0xff;
buffer[3]=0xff;
buffer[4]=0xff;
buffer[5]=0xff;
buffer[6]=0xff;
buffer[7]=0xff;
if (tf_lube_ovr) buffer[1]=0x08; //bit4 buffer[1]=1 to override auto lube
if (!input(pin_c4)) rx_id=300; //remote swi interface C4=0
if (input(pin_c4)) rx_id=301; //local switch interface C4=1
rx_id=rx_id<<8;
can_putd(rx_id,&buffer[0],8,1,TRUE,FALSE);
if (tf_send_can) cnt_send_can++; //setup to end 232 data 3 times
if (cnt_send_can==3) tf_send_can=false; //then revert to normal mode
void ck_spn_fmi()
{if (spn_count > 0) spn_count--; else spn = 0;
if (fmi_count > 0) fmi_count--; else fmi = 99;
int1 va;
line_feed();line_feed();
printf(".......inside main XXXXXX>>>>>>>>>>>>XXXX");
line_feed();
set_tris_a(0xff);
set_tris_c(0xBF);
setup_timer_1(t1_internal|t1_div_by_8); //setup timer #1
can_init(); //init can module
setup_wdt(wdt_on);
set_timer1(0xBDC); //init timer #1
bit_clear(pir1,tmr1if);
// printf("just b4 read_E_data");
line_feed();
read_e_data(); //reads stored values from eeprom
//printf("just afta read_E_data");line_feed();
printf("ENTERING >>>>>>>>>>>>>> , inside while (true)");
line_feed();
va = bit_test(pir1,tmr1if);
//printf("Bit_test = value = %x, pir1 = %x, tmr1if = %x ", va,pir1,tmr1if );
/* printf("Bit_test = value = %2x ", bit_test(pir1,tmr1if));
line_feed();
printf(" pir1 = %x ", pir1);
line_feed();
printf("tmr1if = %x", tmr1if);
line_feed();
while (!bit_test(pir1,tmr1if)) //sample j1939 rX for 100ms
//printf("inside !bit_test pir1,tmr1if, inside while (true)");//line_feed();
ck_j1939_input();
ck_rs232();
if (tf_data_ok) process_rs232(); //PROCESS RS232 IF DATA IS OK
if (tf_send_232) rs232(); //SEND DATA STRING AFTER ANALYZING RS232 COMMANDS
loop_cnt++;
ck_spn_fmi();
if (loop_cnt>=3) //send swi status every 300ms
{ get_swi_status();
send_swi_status();
loop_cnt=0;
printf("leaving <<<<<<< inside while (true)");
line_feed();
printf(".........LEAVING main <<<XXXXXXXXXXXX");
line_feed();
Posted: Thu Aug 13, 2009 11:42 am |
CCS has routines to write 16 or 32-bit integers to eeprom.
They're in this file:
mkuang
Posted: Thu Aug 13, 2009 11:49 am |
PCM programmer wrote: | CCS has routines to write 16 or 32-bit integers to eeprom.
Does CCS proof-read their drivers?
A couple of lines down I read this:
//// void write_int16_eeprom(address, int16 data) ////
//// Call to read a 16 bit integer ////
Posted: Thu Aug 13, 2009 11:52 am |
Apparently they copy and paste. It's a quick way to duplicate code
and do a change to it, but at the risk of leaving errors like that.
Also, they could use a spell checker on their comments in some files. |
lecutus
Posted: Thu Aug 13, 2009 12:40 pm |
Gentleman and ladies if present
All very valid comments and will be taken to heart. But good news is @ hand.
And MKuang is our winner.
Taking his advice first, the read portion of the output was right on.
The proof:
08/13/2009 12:57:40.675 --> .......inside main XXXXXX>>>>>>>>>>>>XXXX
08/13/2009 12:57:40.691 --> id_num=e_data[0]=0,id_num=e_data[1]=0, engine=e_data[2]=0, trans=e_data[3]=0
08/13/2009 12:57:40.691 --> This from - read_e_data() Id_Num= 0000 Engine=00 Trans=00
08/13/2009 12:57:40.894 --> get_setup()>>>>>>>>>>>>>>>>>>>>>>>
Here is where the data is first entered
08/13/2009 12:57:40.909 --> ID=5000
08/13/2009 12:57:44.456 --> Cat=01 Cummins=02 Detroit=03 Enter Engine Number=02
08/13/2009 12:57:46.519 --> Cat=01 Twin Disk=02 Allison=03 Enter Trans Number=03
The inside write is where the input to the eeprom happens and the eeprom is read to form the output.
08/13/2009 12:57:47.550 --> inside write_data()
08/13/2009 12:57:47.566 --> data_msb=19, data_lsb=136, offset=0, data =5000
08/13/2009 12:57:47.581 --> id_num=e_data[0]=136,id_num=e_data[1]=19, engine=e_data[2]=0, trans=e_data[3]=0
08/13/2009 12:57:47.581 --> This from - read_e_data() Id_Num= 5000 Engine=00 Trans=00
08/13/2009 12:57:47.581 --> write_eeprom_16bit - offset_id=0 ,id_num=5000
08/13/2009 12:57:47.597 --> write_eeprom - offset_e=2 ,engine=0
08/13/2009 12:57:47.597 --> write_eeprom - offset_t=3 ,trans=0
08/13/2009 12:57:47.597 --> LEAVING write_data()
The next statement is reverfication and leaves the writing section.
08/13/2009 12:57:47.613 --> This from - get_setup() Id_Num= 5000 Engine=00 Trans=00
08/13/2009 12:57:47.613 --> <<<<<<<<<<<<<<<<<<<<<<<<<<LEAVING get_setup()
08/13/2009 12:57:48.144 --> .......inside main XXXXXX>>>>>>>>>>>>XXXX
08/13/2009 12:57:48.144 --> id_num=e_data[0]=136,id_num=e_data[1]=19, engine=e_data[2]=0, trans=e_data[3]=0
08/13/2009 12:57:48.159 --> This from - read_e_data() Id_Num= 5000 Engine=00 Trans=00
Next is to get the engine and trans id's to keep. I think I can manage. If not I'll be back.
And now for my benefit: why the numbers 136 and 19. What are they?
Like I said in my disclaimer, this bit shifting is kinda new.
Thanks to everyone. And MKuang take the rest of the week off.
L. |
mkuang
Posted: Thu Aug 13, 2009 12:54 pm |
lecutus wrote: | Gentleman and ladies if present
L. |
You start out with a 16 bit number id_number = 5000.
In binary form:
5000=0b 0001 0011 1000 1000.
Now you break it up into two eight bit numbers. The lower byte you called data[0]. So in binary form:
data[0]=0b 1000 1000
which is equal to 136 in decimal.
The upper byte of id_num is 0b 0001 0011 which you call data[1]:
data[1] = 0b 0001 0011
which is equal to 19 in decimal. |
lecutus
I feel so edified |
Posted: Thu Aug 13, 2009 1:15 pm |
Thanks M, it makes sense.
And now for Mr Wayne_. In my new found exuberance I tried your version.
Not to doubt you, of course. Now Wayne_, for your explanation as to why your version works. In the blur of the last days I vaguely remember reading something to the affect of you version.
Yes folks we have two winners!!!!!!!!!!!!!!!
I ran both versions, they have same numbers and behaviours. I shan't bother with any printouts. Just look at the rest of the thread
Wayne_ why don't you take the rest of the week off as well.
I like this place!!!!!!!!!!!!!!!!!!!!!!
L ![Cool](images/smiles/icon_cool.gif) |
