Problem with functions: Compiling in MPLAB
uni_student
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Thu Oct 11, 2007 12:00 am     Reply with quote
Just trying to set up a simple function in my program, but MPLAB doesn't like it when compiling. These are the errors:
"Expecting a basic type"
for function declaration line
"Expecting an identifier"
and
"Expecting a declaration"
for within the function.
Heres the code:
#include <18f452.h>
#include "left.c"
#include "sound11.c"
#device ICD=TRUE
#fuses HS,NOLVP,NOWDT
#use delay (clock=10000000)
#define LED PIN_A1
#define MEM_SELECT PIN_C1 //checked
#define MEM_HOLD PIN_D1 //checked
#define WR_PROTECT PIN_D0 //checked
#define WREN 0x06 //checked
#define WRSR 0x01 //checked
#define RDSR 0x05 //checked
#define READ 0x03 //checked
#define PP 0x02 //checked
#define BE 0xC7 //checked
#define DREQ PIN_D7 //checked
#define BSYNC PIN_D6 //checked
#define xCS PIN_D5 //checked
#define RESET PIN_C0 //checked
void wren (void); //first problem here
void main(){
   unsigned long int Sound_Pointer;
   unsigned long int Sound_Pointer2;
   int data, value, i, k, m, j;
I call the function by this line "wren();"
void wren (void){
   int status;
   output_low(MEM_SELECT); //*******SELECTED*******
   spi_write(WREN);
   output_high(MEM_SELECT); //********DESELECTED********
   status=0;
   while(status!=2){
      spi_write(RDSR);
     status=spi_read(0);
Any help appreciated
PostPosted: Thu Oct 11, 2007 12:20 am     Reply with quote
Don't define a constant with the same name as a function.
uni_student
PostPosted: Thu Oct 11, 2007 12:38 am     Reply with quote
Cheers!!! Fixed now
mattsouthgate
Helpful
PostPosted: Tue Aug 04, 2009 4:18 am     Reply with quote
I'm an old hand at this but it's the simplest problems like this without help compiler error messages that are the infuriating to find. Thanks for the help.
