Help.. serial monitor problem in CCS C window
shashank27187
PostPosted: Mon Aug 03, 2009 1:09 am     Reply with quote
Hey...
I'm using 18f2585.
After programming the micro controller I've put it in the circuit as per the design to read it.
The code used is:
#include <18f2585.h>
#fuses HS,NOPROTECT,NOLVP,NOWDT
#use delay(clock=2000000)
int i;
for (i=1;i<1000;i++)
   printf("%d",i);
   output_low(PIN_B0);
   delay_ms(2000);
   output_high(PIN_B0);
Here, while reading the values, the LED toggles correctly in the board, but the serial monitor window displays something different than what it should actually display.
Here is what is being shown:
(top of the window)
ÿÿÿÿþþþþÿÿÿþþþþþÿÿþÿþþþþþþþþÿþþÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿüüüüþüüüþþü
and
(bottom of the window)
FE FE FF FF FF FE FE FE FE FE FF FF FE FF FE FE FE FE FE FE FE FE FF FE FE FC FC FC FE FC FC FC FE FE FC FC FC FC FF FC FC FE FE FE FC FC FC FC FC FE
Do you guys have any idea whts wrong with it ?
The output's hex value should lie in range of 00-7F,
but the values are printed with hex value more than 7F, even when it is not asked to do so. Shocked
The above code works well with 16f877a and also the LED toggles.
Moreover the compiler and the board I have used to program and read is also the same.
HELP ME.
Thanks in advance.
PostPosted: Mon Aug 03, 2009 1:29 am     Reply with quote
Look closely at the line in bold. Is that what you intend ?
shashank27187
PostPosted: Mon Aug 03, 2009 3:19 am     Reply with quote
Thank You..
