Posted: Tue Sep 01, 2009 12:12 pm |
Here is a post of mine from the old CCS forum on this topic.
These comments apply to 16F PICs.
I had a similar problem. My 16c77 was 93% full.
I know that the compiler starts to have problems if it
gets to 95%, so I really only had 2% space left.
So I looked at the .LST file. I saw many, many places
where the compiler used ROM very inefficiently.
In the first hour of examining the .LST file, I recovered
400 bytes by re-writing my code. In the next hour I
got back maybe 300 more bytes, and so on. Eventually,
I probably recovered at least 1500 bytes.
1. CCS does pointer operations very inefficiently.
Don't do:
ptr = buffer;
a = *ptr++;
b = *ptr++;
c = *ptr++;
Do this, if possible. It uses a lot less ROM:
a = buffer[0];
b = buffer[1];
c = buffer[2];
2. Avoid using CCS string functions. They use up tons of ROM.
If you are calling one string function many times,
then it's not so bad. But if you use a CCS string
function just once, then you are wasting a lot of
ROM for just one function. There is usually a cheaper
way to do it.
3. Avoid using printf() or lcd_putc() with strings.
If you are sending 5 characters or less, then it is
cheaper to use constant characters.
Don't do:
printf("ABC");
Do:
putc('A');
putc('B');
putc('C');
Code can usually be written more efficiently.
Here was the original way that I sent commands.
Note: I sent a lot more than 3 commands, and they
were spread out all over the program. I am just
using 3 commands together, below, as an example.
puts("$PXXXP"); // Send P command
puts("$PXXXA"); // Send A command
puts("$PXXXR"); // Send R command
Here's a cheaper way to do it. Create a central
routine that sends the command string. Then just
call that routine with the command letter.
send_command('P');
send_command('A');
send_command('R');
void send_command(char command_letter)
printf("$PXXX");
putc(command_letter);
putc(0x0d);
putc(0x0a);
It might take you a few days, but I will bet that
you can recover 1K to 2K of your ROM space by looking
at the .LST file. |
