16f628a dimmer, simple problem
Grimmjow
PostPosted: Tue Jul 28, 2009 10:51 am     Reply with quote
Hi there!!
Here is the code:
#include <16f628a.h>
#fuses INTRC_IO,NOPUT,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,NOMCLR
#use delay (clock=4M)
void main(){
   int inc = 0;
   int counter = 0;
   setup_ccp1(CCP_PWM);  // CCP1 set as PWM
   setup_timer_2(T2_DIV_BY_16,32,1); // timer2 set at 2 kHz
   set_pwm1_duty(inc);
   while(TRUE){
         if(input(PIN_A0)){
            while(input(PIN_A0)){
            if(counter<4){
               inc = inc + 8;
               counter++;
         if(input(PIN_A1)){
            while(input(PIN_A1) && inc>0){
            if(counter>0){
               inc = inc - 8;
               counter--;
         set_pwm1_duty(inc);
Code does the following:
- When a button that is connected to PIN_A0 is pushed, LED is turned on with a duty cycle of 25%.
- Similarly, when a button that is connected to PIN_A1 is pushed, LED is dimmed with a duty cycle of 25%.
Code works but veeerrrryyyy slow Evil or Very Mad LED responds approximately after 15 seconds each time a button is pushed.
I don't think the root of the problem is hardware.
Thanks in advance...
PostPosted: Tue Jul 28, 2009 10:56 am     Reply with quote
Try using some better button code that has debouncing:
http://www.ccsinfo.com/forum/viewtopic.php?t=23837
Grimmjow
PostPosted: Wed Jul 29, 2009 5:03 am     Reply with quote
I said that however this was not true... Embarassed I had connected the pull-up resistor to the wrong side of the button. So, code was correct and is working now...
Thanks for the quick reply though...
