Need help in creating pulse counter
yoonees
PostPosted: Tue Jul 28, 2009 10:04 am     Reply with quote
Hi all,
I'm trying to create a pulse counter to count pulses for 15 seconds and the value will be displayed on an LCD. This value will be refreshed every 15 seconds. Earlier, I modified PCM programmer's debouncing code (http://www.ccsinfo.com/forum/viewtopic.php?t=19874) and it worked just fine. However, it is a non-multitasking code and therefore I am unable to run other functions other than the pulse counter code. Right now, I'm trying to write a similar pulse counter that is able to count pulses and at the same time run other functions as well. In the idle state, the input is low. When there is a pulse, the input will be high.
Here are my codes. However, they are not complete. Since the 15 seconds timer and the LCD are working fine I left out the codes. The codes can only seem to count a few pulses out of about 20 pulses. I'm using PIC18LF4550 with 20 MHz crystal oscillator. Compiler version: PCWHD 4.057.
#define HIGH_PERIOD_IN_MS 10
#define LOW_PERIOD_IN_MS 30
static unsigned char high_flag = 0;
void main ()
   lcd_putc("\f");
   while(true)
      getPulse();
      otherFunction1();
      otherFunction2();
void getPulse (void)
// Count pulses
// The function is to detect a high pulse followed by a low pulse
// before the counter is to increase by 1.
   if(input(PIN_A1) == 0 && high_flag == 0)  // No pulse detected
      return;
   if(input(PIN_A1) == 1 && high_flag == 1)  // Current state same as previous state
      return;
   if(input(PIN_A1) == 1 && high_flag == 0)  // High input detected
      delay_ms(HIGH_PERIOD_IN_MS);
      while(input(PIN_A1) != 1)
         high_flag = 1;   // A flag is created to show that input was high
         return;
   if(input(PIN_A1) == 0 && high_flag == 1)  // Low input detected
      delay_ms(LOW_PERIOD_IN_MS);
      while (input(PIN_A1) != 0)
         pulse++;
         high_flag = 0;
         return;
Thanks!
PostPosted: Tue Jul 28, 2009 11:13 am     Reply with quote
Are you counting button pushes ? Here's a program that will
debounce pushbuttons, and record the keypresses in a buffer.
It's interrupt-driven, so it's suitable for multi-tasking:
http://www.ccsinfo.com/forum/viewtopic.php?t=39585&start=1
If you're not counting keypresses, then describe the input pulse
signal in detail.
yoonees
PostPosted: Tue Jul 28, 2009 7:44 pm     Reply with quote
signal in detail.
Hi PCM programmer,
I'm actually trying to count pulses in the form of square waves so it's very similar to counting button pushes. That is why when I used your non-multitasking codes, it worked.
When there is not pulse, the input signal line remains low. When there is a pulse, the input signal like goes up high for about 200 - 400 ms.
If it is possible, I would prefer not to involve interrupt in the counting process.
Thank you Smile
PostPosted: Tue Jul 28, 2009 7:54 pm     Reply with quote
How long does the pulse go low ?
yoonees
PostPosted: Tue Jul 28, 2009 8:35 pm     Reply with quote
You mean the period between 2 high pulses? It's about 400 - 500 ms.
yoonees
PostPosted: Tue Jul 28, 2009 10:14 pm     Reply with quote
Just to add, the reason why I used the delays in the codes is because sometimes there are unwanted short pulses (something like bouncing in button pushes).
