I cant seem to get a maximimum PWM output using timer2.
Theoretically I using a 4Mhz clock I should be able to get a 1Mhz PWM output. I have tested the following code and do not get any output from ccp1 or ccp2 in PWM mode. The does not work until a get preload a value of 50 or above.
I can't find any talk of a min preload or max pwm speeds relative to clock speed. Am i missing something here. What is the maximum PWM speed relative to clock that i can have?
