Using analog input pins on the pic
lyndia
PostPosted: Fri Jul 24, 2009 9:36 am     Reply with quote
Will I be able to use RA0/AN0 for digital output, while using RA1/AN1 for analog input?
The A/D Port Configuration Control bits (PCFG3:0) enable analog input in such a way:
AN0
AN0, AN1
AN0, AN1, AN2
I just want to confirm that setting RA0 as output will not be affected by these configuration bits.
PostPosted: Fri Jul 24, 2009 11:14 am     Reply with quote
See this explanation of dual use of digital/analog i/o pins by Ttelmah:
http://www.ccsinfo.com/forum/viewtopic.php?t=38205&start=6
