Looking for actual itoa function code
horanyee
PostPosted: Fri Aug 07, 2009 10:45 am     Reply with quote
Can someone show me how atoi() are implemented?
I like to have actual code for atoi() in CCS C compiler.
Thank you in advance!!!!
PostPosted: Fri Aug 07, 2009 10:51 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=38852
PostPosted: Fri Aug 07, 2009 10:52 am     Reply with quote
Look in C:\Program Files\PICC\Drivers\INPUT.C
This universal routine takes positive and negative values, decimal and hex strings. Problem is that because of this generic implementation it compiles to a relative large function.
For example, if you know your string is always a two characters long hexadecimal value you can create a much compacter function.
horanyee
Thank you I found it.
PostPosted: Fri Aug 07, 2009 10:59 am     Reply with quote
