mikem
dealing with clock stretching using ccs i2c functions |
Posted: Thu Jul 16, 2009 7:15 am |
Hi all,
I am currently trying to convert some very elegantly written master I2C assembler code written for a pic16f960 over to C. The original assembly routines were based on the Microchip app note: AN554 Software Implementation of I2C a Bus Master.
The slave device I am trying to talk to uses clock stretching to delay the clock: From slave device spec:
"The TVP5150AM1 decoder requires delays in the I2C accesses to accommodate its internal processor's timing. In accordance with I2C specifications, the TVP5150AM1 decoder holds the I2C clock line (SCL) low to indicate the wait period to the I2C master."
For simplicity I am trying to start off with the i2c functions provided by the CCS compiler to get some basic functionality working. Unfortunately the CCS i2c functions do not seem to deal with clock stretching. Is this the case? Is there anyway of using the CCS I2C functions to create a simple I2C master and account for clock stretching by the slave?
I have include my simple code below. It is far from elegant but at this point I am just trying to write to a specific address in the slave device.
I can see the slave address going out on the logic analyzer so I know the program is partially working.
Any suggestions would be much appreciated!!
Cheers
Mike
Code: | #include <16F690.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES PUT //No Power Up Timer
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#use delay(internal=4M)
#use i2c(Master,Slow,sda=PIN_B4,scl=PIN_B6)
#include "C:\mydocs\picfware\i2c_master_trial\main.h"
setup_adc(ADC_OFF);
setup_timer_1(T1_DISABLED);
setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
setup_oscillator(OSC_4MHZ);
// TODO: USER CODE!!
while (1){
i2c_start ();
i2c_write (0xbb); // slave device address
i2c_write (0x00); // request slave ‘internal memory address’ 0×00
i2c_write (0x80); // write data 0x80
i2c_stop();
delay_us(20);
Posted: Thu Jul 16, 2009 9:49 am |
Because you didn't specify FORCE_HW in #use i2c, a software master is implemented from your code. I'm not sure, if it's also supporting clock stretching. The PIC16F hardware I2C interface should support it. |
mikem
Posted: Thu Jul 16, 2009 10:03 am |
Hi FvM,
from reading the pic16f690 datasheet I was under the impression that any master functionality had to be implemented in software.
The pic16f690 only has an SSP hardware module and not the MSSP module that some other microchip parts have. Unless I am missing something?
Cheers
Mike |
Posted: Thu Jul 16, 2009 11:48 am |
Quote: | The TVP5150AM1 decoder |
I've done a driver for this. Here are the low-level register r/w routines
and an init routine. There are other routines, but this will get you started.
The init routine has some experimental settings in it because the product
was still under development at the time. But I believe the uncommented
settings do work.
// TVP5150A.c
// Notes:
// The T.I. FAQ for this chip says the i2c latency can be up to
// one Horizontal line time (64 us for PAL, 63.5 us for NTSC).
// They say that the i2c stop function must check the SCL signal,
// and not return until it goes high. (ie., the TVP5150A does
// clock stretching). I checked the .LST file and the CCS compiler
// does this for the i2c_stop() function. (At least they do it
// for software i2c, and that's what we're using on this board).
// Write an 8-bit value to the specified TVP5150A register.
void write_TVP5150A_reg(char reg_addr, char value)
i2c_start();
i2c_write(TVP5150A_I2C_WRITE_ADDRESS);
i2c_write(reg_addr);
i2c_write(value);
i2c_stop();
// Read an 8-bit value from the specified TVP5150A register.
// The method shown below is peculiar in that it doesn't do
// a "re-start", but this is how the data sheet says to do it.
char read_TVP5150A_reg(char reg_addr)
char value;
i2c_start();
i2c_stop();
i2c_start();
i2c_write(TVP5150A_I2C_READ_ADDRESS);
value = i2c_read(0);
i2c_stop();
return(value);
void init_TVP5150A(void)
//write_TVP5150A_reg(0x03, 0x09);
// CAUTION:
// There are restrictions on the settings for
// registers 0x03 and 0x0F regarding the VBLANK/GPCL pin.
// Some settings will cause the TVP5150A to appear to stop
// working. The data sheet hints at this. I've seen it.
// The following settings work OK.
write_TVP5150A_reg(0x03, 0xEF); // Was 0x2F
write_TVP5150A_reg(0x0F, 0x0A); // Enable pin 27 for VBLANK/GPCL
//write_TVP5150A_reg(0x0F, 0x08);
// 8-17-05
// Disable adaptive line filter and comb filter on
// the receiver board, per [mgr]. This removes artifacts
// due to the 3-line filtering with lines that are no
// longer properly adjacent, due to the scrambling.
// The default value is 0x0C which enables both filters.
// *** TESTING *** COMMENTED OUT FOR THE PASSTHRU TEST.
//write_TVP5150A_reg(0x1A, 0x00);
// Tell it to expect a pedestal. By doing this, we prevent
// the TVP5150A from inserting a pedestal.
write_TVP5150A_reg(0x07, 0x20);
void display_TV5150A_reg(int8 addr)
printf("%02x %02x\n\r", addr, read_TVP5150A_reg(addr));
void dump_TVP5150A_regs(void)
char i;
for(i = 0; i <= 0x1E; i++)
display_TV5150A_reg(i);
display_TV5150A_reg(0x28);
for(i = 0x2c; i <= 0x2F; i++)
for(i = 0x80; i <= 0x8C; i++)
for(i = 0xC0; i <= 0xCF; i++)
Posted: Fri Jul 17, 2009 1:53 am |
Sweet!! Thanks very much PCM programmer. This should definitely help!!
Thanks for the code. |
Posted: Fri Jul 17, 2009 2:11 am |
Quote: | from reading the pic16f690 datasheet I was under the impression that any master functionality had to be implemented in software. | I2C master operation is explicitely discussed in the datasheet. At least part of the master functionality is handled by the hardware when selecting FORCE_HW in CCS C. |
Posted: Fri Jul 17, 2009 11:03 am |
The 16F690 says the following, but it's referring to Multi-Master mode.
Quote: | 13.13 Master Mode
Master mode of operation is supported in firmware
using interrupt generation on the detection of the Start
and Stop conditions. |
In normal i2c Master Mode, in a PIC with an SSP module (not MSSP)
the compiler will generate "bit banging" code only, with no hardware
support. That's the only way it can be done.
If "FORCE_HW" is used in the #use i2c() statement, and the PIC only
has an SSP module, the compiler will generate incorrect code. It won't
work. It tries to send a byte by writing to the SSPBUF register, but that
register isn't functional in Master mode, because the PIC only has an
SSP module. Also, it tries to setup the hardware i2c baudrate generator
by writing to SSPADD, but it can't work, because that feature isn't
available in an SSP module (only in MSSP). |
mikem
Posted: Mon Jul 20, 2009 4:15 am |
Hi PCM programmer and FVM.
Thanks for your help.
Cheers
Mike |
