Stack Underflow
davekelly
Stack Underflow
PostPosted: Thu Jul 16, 2009 5:44 am     Reply with quote
V4.093
I have recently completely reinstalled my Vista PC from scratch, and now having problems with compiling applications.
In the past few days I have created new projects for the 16F648A and the 18F2620. Both are having problems with debugging, whether I use a RealICE, ICD2 or MPLAB SIM.
The startup code in the memory appears to be completely wrong.
I compiled this simple test program:
#include <18F2620.h>
#use delay (clock = 20 M)
#fuses HS, NOFCMEN, NOIESO, PUT, BROWNOUT_NOSL, NOWDT, MCLR, NOPBADEN, NOLPT1OSC, CCP2B3, NOSTVREN, NOLVP, NODEBUG
#int_timer1
void timer1Overflow()
   output_toggle (PIN_A2);
void main ()
   enable_interrupts (GLOBAL);
   enable_interrupts (INT_TIMER1);
   while (1)
      output_toggle (PIN_A1);
When stepping through the disassembly or Program Memory, the code steps through until it reaches a RETFIE instruction, which causes the stack underflow.
When I look at the listing, the code appears correct. The first instruction is a GOTO, the address corresponds to the start of the main function. However the disassembly in the Program Memory is completely wrong:
    CCS PCH C Compiler, Version 4.093, 44595 16-Jul-09 12:16
    Filename: main.lst
    ROM used: 200 bytes (0%)
    Largest free fragment is 65332
    RAM used: 24 (1%) at main() level
    24 (1%) worst case
    Stack: 1 worst case (0 in main + 1 for interrupts)
    00000: GOTO 00A8
    00008: MOVWF 05
    0000A: MOVFF FD8,06
    0000E: MOVFF FE0,07
    00012: MOVLB 0
    00014: MOVFF FE9,0D
    00018: MOVFF FEA,08
    0001C: MOVFF FE1,09
    00020: MOVFF FE2,0A
    00024: MOVFF FD9,0B
    00028: MOVFF FDA,0C
    0002C: MOVFF FF3,14
    00030: MOVFF FF4,15
    00034: MOVFF FFA,16
    00038: MOVFF 00,0F
    0003C: MOVFF 01,10
    00040: MOVFF 02,11
    00044: MOVFF 03,12
    00048: MOVFF 04,13
    0004C: BTFSS F9D.0
    Line Address Opcode Disassembly
    1 0000 0200 MULWF 0, ACCESS
    2 0002 1E1C COMF 0x1c, F, ACCESS
    3 0004 8000 BSF 0, 0, ACCESS
    4 0006 0080
    5 0008 C00F MOVFF 0xf, 0xf
    6 000A E00F BZ 0x2a
    7 000C 400F RRNCF 0xf, W, ACCESS
    8 000E CFE0 MOVFF 0xfe0, 0x7
    9 0010 F007 NOP
    10 0012 0100 MOVLB 0
    11 0014 CFE9 MOVFF 0xfe9, 0xd
    12 0016 F00D NOP
    13 0018 CFEA MOVFF 0xfea, 0x8
    14 001A F008 NOP
    15 001C CFE1 MOVFF 0xfe1, 0x9
    16 001E F009 NOP
    17 0020 CFE2 MOVFF 0xfe2, 0xa
    18 0022 F00A NOP
    19 0024 CFD9 MOVFF 0xfd9, 0xb
    20 0026 F00B NOP
    21 0028 CFDA MOVFF 0xfda, 0xc
    22 002A F00C NOP
    23 002C CFF3 MOVFF 0xff3, 0x14
I was using MPLAB 8.33. The code compiled fine on my colleagues XP installation with MPLAB 8.30, so I have downgraded my MPLAB to that version, but with the same issues.
I also tried an older 4.083 compiler, with the same problems.
Anybody wise as to what is going on?
Edit:
I have just noticed when scrolling to the bottom of the disassembly, that is is putting the fuses settings at location 0, as these correspond with the disassembly above
    .................... output_toggle (PIN_A1);
    000C4: BCF F92.1
    000C6: BTG F89.1
    000C8: BRA 00C4
    000CA: SLEEP
    Configuration Fuses:
    Word 1: 0200 HS NOIESO NOFCMEN
    Word 2: 1E1C NOWDT BORV21 PUT BROWNOUT_NOSL WDT32768
    Word 3: 8000 CCP2B3 NOPBADEN NOLPT1OSC MCLR
    Word 4: 0080 NOSTVREN NODEBUG NOLVP NOXINST
    Word 5: C00F NOPROTECT NOCPD NOCPB
    Word 6: E00F NOWRT NOWRTD NOWRTC NOWRTB
    Word 7: 400F NOEBTR NOEBTRB
davekelly
PostPosted: Thu Jul 16, 2009 9:59 am     Reply with quote
Reinstalled the compiler, seems ok now.
