PIC24 ARRAY READ OUT doesn´t work
richi-d
PostPosted: Fri Jul 10, 2009 6:21 am     Reply with quote
Hi Following problem: DUMMY2 doesn´t get the value of PWM_INK_ZAEHLER[1]
Compiler Version is PCD 4.089
MPLAB 8.33
Any ideas?
MAIN
// V01 10.03.2009
#include <24FJ128GA106.h>
//#device adc=10
#include <string.h>
#include <math.h>
#include <Main_V01.h>
   DUMMY32BIT_1 =  100000;
   WEGDIFFERENZ = 500;
TASK_NR = 1;
   for(;;)
      PWM_INK_ZAEHLER[TASK_NR] = DUMMY32BIT_1 / WEGDIFFERENZ;
      DUMMY2 = PWM_INK_ZAEHLER[TASK_NR];
      }//   for(;;)
   }//Main()
HEADER
#FUSES FRC_PLL,NOPROTECT,NOIESO,NOJTAG,ICSP1,DEBUG
#use delay (clock=32000000)
unsigned int   WEGDIFFERENZ;
long      DUMMY32BIT_1;
long      PWM_INK_ZAEHLER[11];
char      TASK_NR;
long      DUMMY2;
Wayne_
PostPosted: Fri Jul 10, 2009 7:11 am     Reply with quote
WEGDIFFERENZ is 8 bit
WEGDIFFERENZ = 500;
WEGDIFFERENZ now = 500 - 256 = 244
TASK_NR = 1;
C arrays have a zero based index so an array of
Has indexex from 0 to 10 giing you 11 values.
PWM_INK_ZAEHLER[0];
to
PWM_INK_ZAEHLER[10];
The following will not fail but will cause problems as it is wrong!
richi-d
Take care!! PIC24
PostPosted: Fri Jul 10, 2009 7:49 am     Reply with quote
HI,
at PCD and PIC24 "unsigned int" is a 16bit value...
and why is PWM_INK_ZAEHLER[11]; wrong? This is the declaration of the variable...
First read, then answer!
Wayne_
PostPosted: Fri Jul 10, 2009 7:53 am     Reply with quote
So what are the values you are seeing and how are you viewing them ? Which debugger ?
richi-d
PostPosted: Fri Jul 10, 2009 7:54 am     Reply with quote
Not the values are the problem, this is the problem:
The assembler code is wrong! Try it and look!
PostPosted: Fri Jul 10, 2009 9:07 am     Reply with quote
Your code seems to compile correctly in most recent PCD V4.093.
...       DUMMY2 = PWM_INK_ZAEHLER[TASK_NR];
002C8:  MOV.B   834,W0L
002CA:  CLR.B   1
002CC:  SL      W0,#2,W0
002CE:  MOV     #808,W4
002D0:  ADD     W0,W4,W0
002D2:  MOV     #836,W4
002D4:  MOV     [W0++],[W4++]
002D6:  MOV     [W0++],[W4++]
There are however several unfixed PCD bugs, some have been reported about 8 months ago.
richi-d
PostPosted: Fri Jul 10, 2009 12:25 pm     Reply with quote
This is what 4.089 makes:
 002C4  BFC832     mov.b 0x0832,0x0000
 002C6  EF6001     clr.b 0x0001
 002C8  DD0042     sl 0x0000,#2,0x0000
 002CA  208064     mov.w #0x806,0x0008
 002CC  400004     add.w 0x0000,0x0008,0x0000
 002CE  208344     mov.w #0x834,0x0008
 002D0  780230     mov.w [0x0000++],0x0008
 002D2  780230     mov.w [0x0000++],0x0008
Is there a chance to get a workarround? My update time is off.
How can I implement the ASM code?
This works:
#define NOP   #asm NOP #endasm;
but not the lines above...
PostPosted: Fri Jul 10, 2009 2:56 pm     Reply with quote
The point that was being made about PWM_INK_ZAEHLER[11], was that your code, does not limit 'TASK_NR' at all, You will be pulling semi random values, from memory, once this gets past 10....
PostPosted: Fri Jul 10, 2009 3:05 pm     Reply with quote
Curiously, I never saw the reported PCD bug. I found that the line of code is also compiled correctly by PCD V4.084. Possibly, it's a bug exclusive to V4.089. In this case, I won't see much sense in designing a workaround.
Generally, PCD assembler is working, but some minor syntax issues must be managed.
P.S.: I don't understand some discussions about wrong index ranges, because the example code uses a fixed index of 1.
richi-d
PostPosted: Sat Jul 11, 2009 3:51 am     Reply with quote
FvM and Ttelmah, what should I do now? I don´t understand what you want to tell me...
PostPosted: Sat Jul 11, 2009 7:46 am     Reply with quote
Try with any other PCD version than V4.089 (older or newer).
