Spukkers
Need help with motion profile program |
Posted: Mon Jun 29, 2009 2:39 am |
I need help with my C-program, I found a source code from microchip (AN696). but when I try to change the program to a ccs program, the program simply doesn't work properly.
void UpdTraj (void);
void SetupMove (void);
void UpdPos (void);
void CalcError (void);
void CalcPID (void);
void PicInit(void);
#define TotDist 30000
#define HalfDist TotDist/2
#define Vmax 40
#define DIST 0
#define VEL 1
#define ACCEL 2
#define TIME 3
unsigned int8 firstseg, lastseg, segnum, parameter;
int16 dtime, integral, kp, ki, kd, vlim, mvelocity, upcount;
int16 segment1[12][4];
int32 position, mposition, fposition, flatcount;
struct Status
int1 phase;
int1 neg_move;
int1 motion;
int1 saturated;
int1 bit4;
int1 bit5;
int1 run;
int1 loop;
} stat;
union LNG
int32 l;
unsigned int32 ul;
int16 i [2];
unsigned int16 ui [2];
int8 b [4];
unsigned int8 ub [4];
union LNG
temp, accel, u0, ypid, velact, phase1dist;
#INT_TIMER2
void servo_isr(void)
UpdTraj();
SetupMove();
UpdPos();
CalcError();
CalcPID();
clear_interrupt(INT_TIMER2);
PicInit();
printf("\n\rSTART\n\r");
//PWM settings
setup_ccp2(CCP_OFF );
output_low(PIN_C1);
output_high(PIN_B5);
set_pwm1_duty(0);
setup_ccp1(CCP_PWM);
if(kbhit())
switch (getc())
case 'q':
printf("\n\rAAN");
stat.run =1;
stat.motion = 1;
stat.loop = 0;
firstseg = 0;
lastseg = 0;
segnum = 0;
set_timer1(0);
case 'w':
default:;
void UpdTraj (void)
if (stat.motion && !stat.saturated)
{//Do motion profile
if(!stat.phase)
//printf("\n\r%lu\n\r",velact.ui[1]);
if(velact.ui[1] < vlim)
velact.ul = velact.ul + accel.ul;
flatcount++;
//printf("\n\r%lu\n\r",flatcount);
temp.ul = velact.ul;
if (velact.ui[0] == 0x8000)
if (!(velact.ub[2] & 0x01))
temp.ui[1]++;
else ;
else if (velact.ui[0] > 0x8000)
temp.ui[1]++;
else;
phase1dist.ul = phase1dist.ul - (unsigned int32)temp.ui[1];
if (stat.neg_move)
position = position - (unsigned int32)temp.ui[1];
position = position + (unsigned int32)temp.ui[1];
if (phase1dist.l <= 0)
stat.phase = 1;
if (flatcount)
flatcount--;
else if (velact.ul)
velact.ul = velact.ul - accel.ul;
if (velact.i[1] <0)
velact.l = 0;
if (dtime)
dtime--;
stat.motion = 0;
position = fposition;
if (velact.ui[0]==0x8000)
temp.ui[1]++;
else;
else if (velact.ui[0]>0x8000)
temp.ui[1]++;
else;
if (stat.neg_move)
position = position - (unsigned int32) temp.ui[1];
position = position + (unsigned int32) temp.ui[1];
{//load next segment
if (stat.run && !stat.motion)
if (segnum < firstseg) segnum = firstseg;
if (segnum > lastseg)
segnum = firstseg;
if(!stat.loop) stat.run = 0;
SetupMove();
segnum++;
else;
if (segnum < 12)
phase1dist.i[0] = segment1[segnum][DIST];
vlim = segment1[segnum][VEL];
accel.i[0] = segment1[segnum][ACCEL];
dtime = segment1[segnum][TIME];
else ;
phase1dist.b[2]=phase1dist.b[1];
phase1dist.b[1]=phase1dist.b[0];
phase1dist.b[0]=0;
if (phase1dist.b[2] & 0x80)
phase1dist.b[3] = 0xFF;
phase1dist.b[3] = 0;
accel.b[3]=0;
accel.b[2]=accel.b[1];
accel.b[1]=accel.b[0];
accel.b[0]=0;
temp.l = position;
if (temp.ub[0]>0x7F)
temp.l = temp.l + 0x100;
temp.ub[0]=0;
position = temp.l;
fposition = position + phase1dist.l;
if (phase1dist.b[3] & 0x80)
stat.neg_move = 1;
phase1dist.l = -phase1dist.l;
stat.neg_move = 0;
phase1dist.l >>= 1;
velact.l = 0;
flatcount = 0;
stat.phase = 0;
if (accel.l && vlim)
stat.motion = 1;
void UpdPos (void)
mvelocity = upcount;
upcount = get_timer1();
mvelocity = upcount - mvelocity;
mposition = mposition + mvelocity;
//printf("\n\r%lu-%lu\n\r",mvelocity, mposition);
temp.l = position;
temp.b[0] = 0;
u0.l = mposition - temp.l;
u0.b[0] = u0.b[1];
u0.b[1] = u0.b[2];
u0.b[2] = u0.b[3];
if(u0.b[2] & 0x80)
u0.b[3] = 0xFF;
if((u0.ui[1] != 0xFFFF) || !(u0.ub[1] & 0x80))
u0.ui[1] = 0xFFFF;
u0.ui[0] = 0x8000;
else;
u0.b[3] = 0x00;
if((u0.ui[1] != 0x0000) || (u0.ub[1] & 0x80))
u0.ui[1]=0x0000;
u0.ui[0]=0x7FFF;
else;
void CalcPID (void)
ypid.l = (int32)u0.i[0]*(int32)kp;
if(!stat.saturated)
integral = integral + u0.i[0];
if(ki)
ypid.l = ypid.l + (int32)integral*(int32)ki;
if(kd)
ypid.l = ypid.l + (int32)mvelocity*(int32)kd;
ypid.i[0] = u0.i[0]*kp;
ypid.ub[2]=??????;
ypid.ub[3]=??????;
if(!stat.saturated)
if(ki)
temp.i[0] = integral * ki;
temp.ub[2] = ?????;
temp.ub[3] = ?????;
ypid.l = ypid.l + temp.l;
if (kd)
temp.i[0] = mvelocity * kd;
temp.ub[2] = ?????;
temp.ub[3] = ?????;
if (ypid.ub[3] & 0x80)
if ((ypid.ub[3] < 0xFF) || !(ypid.ub[2] & 0x80))
ypid.ui[1] = 0xFF80;
ypid.ui[0] = 0x0000;
else;
if(ypid.ub[3] || (ypid.ub[2] > 0x7F))
ypid.ui[1] = 0x007F;
ypid.ui[0] = 0xFFFF;
else;
ypid.b[0] = ypid.b[1];
ypid.b[1] = ypid.b[2];
stat.saturated = 0;
if(ypid.i[0] > 1000)
ypid.i[0] = 1000;
stat.saturated = 1;
if (ypid.i[0]< 20)
ypid.i[0]= 20;
stat.saturated = 1;
set_pwm1_duty(ypid.i[0]);
printf("\n\r%lu\n\r",ypid.i[0]);
void PicInit(void)
set_tris_a(0b11111100);
set_tris_b(0b11001111);
set_tris_c(0b10111001);
set_tris_d(0b11111111);
set_tris_e(0b00000000);
set_tris_f(0b11111111);
set_tris_g(0b11111111);
#use fast_io(a)
//#use fast_io(b)
//#use fast_io(c)
#use fast_io(d)
#use fast_io(e)
#use fast_io(f)
#use fast_io(g)
output_low(PIN_B5);
output_low(PIN_C1); //PWM signale laag maken
output_low(PIN_C2); //PWM signale laag maken
setup_timer_0(RTCC_EXT_L_TO_H);
setup_timer_1 ( T1_EXTERNAL_SYNC|T1_DIV_BY_1 );
setup_timer_2 ( T2_DIV_BY_1, 255, 16);
output_high(PIN_B4);//RX en TX signaal omzetten zodat de UART tool gebruikt kan worden
set_timer1(0);
firstseg = 0; // Initialize motion segment
lastseg = 0; // variables
segnum = 0;
parameter = 0; // Motion segment parameter#
stat.phase = 0; // Set flags to 0.
stat.saturated = 0;
stat.motion = 0;
stat.run = 0;
stat.loop = 0;
stat.neg_move = 0;
dtime = 0;
integral = 0;
vlim = 0;
mvelocity = 0;
upcount = 0;
temp.l = 0;
accel.l = 0;
u0.l = 0;
ypid.l = 0;
velact.l = 0;
phase1dist.l = 0;
position = 0;
mposition = 0;
fposition = 0;
flatcount = 0;
kp= 50;
ki= 0;
kd= 0;
segment1[0][DIST] = 30000;
segment1[0][VEL] = 18;
segment1[0][ACCEL] = 2;
segment1[0][TIME] = 12;
Can anyone help me please.
Who has some experience with a servo system or with the Application note from microchip(AN696).
Regard Spukkers |
Posted: Mon Jun 29, 2009 1:36 pm |
Quote: |
when I try to change the program to a ccs program, the program simply doesn't work properly. |
You implied that you had converted it to CCS, but that it would not run
correctly on a PIC. In fact, it doesn't compile. You need to work
on it some more, so that it compiles without errors.
Also, when you post code, post the #include, #fuses, and #use delay()
statements so the program is complete. |
Spukkers
Working code changed AN696 |
Posted: Wed Jul 01, 2009 5:39 am |
I've got our code to work.
with the folliwing code we can control a sliding door with a brushed dc motor.
The pwm controls a l298n to drive the motor.
the motor has a encoder to get the postition of the door. like AN696 except we adjust the program and hardware a litle bit, to use one timer for the pulsecount. We cummunicatie over ethernet (UDP).
#define STACK_USE_ICMP 1 //ethernet settings
#define STACK_USE_ARP 1
#define STACK_USE_UDP 1
#define MAX_SOCKETS 2 //the program needs two sockets, one for sending
#define MAX_UDP_SOCKETS 2 //and one for receiving data
#include "ccstcpip.h"
#include <stdlib.h>
#include <string.h>
#include <math.h>
#CASE // make compiler case sensative
#define UDP_SOURCE_PORT 1024 //set port to receive data from
#define UDP_DESTINATION_PORT 1025 //set port to send data to
#define UDP_NUM_LISTEN_SOCKETS 1 //set maximum number of computers to communicate with
#define enable PIN_B5 //define enable for the l298n, to make programming easier
#bit INTEDG3 = 0xFF1.3 //define bit 3 of register 0xFF1 as INTEDG3,
//this bit controls the edge triggring of the external interrupt,H_to_L or L_to_H
UDP_SOCKET last_rx_socket=INVALID_UDP_SOCKET; //sets the endpoint for the maximum of the UDP sockets
//functions declerations
void OpenInit(void);
void UpdPos (void);
void PicInit(void);
void UDPRxTask(void);
void UDPTxTask(void);
signed int32 Teach(void);
//create variables which can be used trough the hole program
int8 ibuffer[4]={255,255,255,255}, obuffer[2]={255,255};
signed int16 dtime, integral, mvelocity, upcount;
signed int32 position, mposition, fposition, flatcount, vlim;
signed int32 accel, temp, u0, ypid, velact;
signed int32 phase1dist, halfdist, halfdisttemp;
signed int32 x0=0, y0=0, z0=0, u=0;
signed int32 x1, y1, z1, u1;
signed int32 Kr=1, Ti=100, Td=0; // parameters of the PID-controller
signed int32 U, dt=0.667;
signed int32 timer1old=0, timer1oldold=0,pulses;
struct Status //create a structure to maintain the statusses of the program
int1 phase;
int1 open;
int1 closed;
int1 motion;
int1 saturated;
int1 init;
int1 manual;
int1 run;
int1 summerwinter;
} stat;
#INT_EXT3 FAST //use external interrupt3 for the lightsensor
void light_sens()
disable_interrupts(INT_TIMER2);
set_pwm3_duty(0);
setup_ccp3(CCP_OFF);
output_low(PIN_D1);
output_high(enable);
set_pwm1_duty(0);
stat.open = 0;
stat.saturated = 0;
stat.motion = 0;
mvelocity = 0;
upcount = 0;
temp = 0;
u0 = 0;
x0=0; y0=0; z0=0; u=0; x1=0; y1=0; z1=0; u1=0;
velact = 0;
position = 0;
mposition = 0;
fposition = 0;
flatcount = 0;
stat.run = 1;
stat.motion = 1;
obuffer[1] = 0;
phase1dist = get_timer1();
phase1dist = phase1dist * 500;
set_timer1(0);
printf("\n\rphase1dist=%ld\n\r",phase1dist);
dtime = 3000;
disable_interrupts(INT_EXT3);
clear_interrupt(INT_EXT3);
#INT_TIMER2 //interrupt service routine, enters every 16 pwm periods
void servo_isr()
UpdTraj();
UpdPos();
CalcError();
CalcPID();
PicInit();
MACAddrInit(); //initialize the mac adress of the pic
IPAddrInit(); //initialize the ip-adress of the pic
StackInit();
StackTask();
UDPRxTask();
switch (ibuffer[0])
case 0: //open/close automatic
if (!stat.manual && stat.closed ) //if door is not opened manual and door is closed
dtime = ibuffer[1] * 1500;
printf("\n\rdtime=%ld\n\r",dtime);
OpenInit();
case 1: //open manual
if (!stat.manual) //if door is not opened manual
stat.manual = 1;
OpenInit();
case 2: //close door manual
if (stat.manual) //if door is opened manual
stat.manual = 0;
dtime = 0 ;
case 3: //adjust the acceleration and decceleration
accel = ibuffer[1];
printf("\n\raccel=%u\n\r",accel);
case 4: //adjust the velocity limit
vlim = (signed int32)ibuffer[1] * 1000;
printf("\n\rvlim=%ld\n\r",vlim);
case 5: //initialize the controller
accel = ibuffer[1]; //set acceleration/decceleration
vlim = (signed int32)ibuffer[2] * 1000; //set velocity limit
halfdisttemp = Teach();
if (!stat.manual)//if door is not opened manually set summer or wintertime
stat.summerwinter=ibuffer[3];
if (stat.summerwinter)
halfdist = halfdisttemp * 500;
printf("\n\Summertime\n\r");
halfdist = halfdisttemp * 250;
printf("\n\Wintertime\n\r");
case 7:
if (!stat.manual)//if not opened manually, set summer or wintertime
stat.summerwinter=ibuffer[1];
halfdist = halfdisttemp * 500; //door will open full
halfdist = halfdisttemp * 250; //door will open half
default:;
if (stat.closed) //if door is closed, and pulses are count, generate error to local pc
if (get_timer1() > 20)
obuffer[0]=1;
obuffer[1]=255;
UDPTxTask();
printf("\n\rALARM!!!\n\rGot pulses\n\r",);
set_timer1(0);
ibuffer[0]=255;//reset the input buffer to prevent that cases are re-entered
ibuffer[1]=255;
ibuffer[2]=255;
ibuffer[3]=255;
* Function: void OpenInit(void)
* PreCondition: None
* Input: None
* Output: Initializations are made to open the door
* Side Effects: None
* Note: This function must be called before open the door
void OpenInit(void)
setup_ccp3(CCP_OFF );
output_low(PIN_D1);
set_pwm1_duty(0);
stat.open = 0;
stat.closed = 0;
stat.saturated = 0;
stat.motion = 0;
mvelocity = 0;
upcount = 0;
temp = 0;
u0 = 0;
velact = 0;
position = 0;
mposition = 0;
fposition = 0;
flatcount = 0;
phase1dist = halfdist;
stat.run =1;
stat.motion = 1;
obuffer[1] = 0;
set_timer1(0);
* Function: void UpdTraj(void)
* PreCondition: OpenInit() has to be called
* Input: None
* Output: position where the door supposed to be
* Note: This function calculates where door supposed to be
void UpdTraj (void)
//if (stat.open)printf("\n\rQ\n\r");
if(!stat.phase)
//printf("\n\rh\n\r");
if(velact < vlim)
velact = velact + accel;
flatcount++;
temp = velact;
phase1dist = phase1dist - temp;
position = position + temp;
if (phase1dist <= 0)
stat.phase = 1;
phase1dist = 0;
if (flatcount)
flatcount--;
else if (velact)
velact = velact - accel;
if (velact < 1)
velact = 0;
stat.motion = 0;
if (stat.open)
printf("\n\r%lu\n\r", get_timer1());
set_pwm3_duty(0);
output_low(PIN_D1);
obuffer[0]=0;
obuffer[1]=0;
UDPTxTask();
stat.closed = 1;
set_timer1(0);
temp = velact;
if (!obuffer[1])
obuffer[0]=0;
obuffer[1]=1;
UDPTxTask();
if (!stat.manual)
if (dtime)
dtime--;
else if (stat.run && !stat.motion && !stat.open)
//stat.run = 0;
stat.open = 1;
position = 0;
mposition = 0;//position;
set_timer1(0);
stat.phase = 0;
stat.saturated = 0;
mvelocity = 0;
upcount = 0;
temp = 0;
u0 = 0;
velact = 0;
mposition = 0;
flatcount = 0;
stat.run =1;
stat.motion = 1;
setup_ccp1(CCP_OFF );
output_low(PIN_C2);
set_pwm3_duty(0);
setup_ccp3(CCP_PWM);
enable_interrupts(INT_EXT3);
else if (stat.manual)
* Function: void UpdPos(void)
* Input: None
* Output: position where the door is at the moment
* Note: This function reads where door supposed is
void UpdPos (void)
upcount = get_timer1() * 1000;
* Function: void CalcError(void)
* Input: None
* Output: Position error
* Note: This function calculates the positioning error
u0 = position - mposition;
//printf("\n\r%ld - %ld\n\r",position, mposition);
* Function: void CalcPID(void)
* Input: Positioning error u0
* Output: Pwm dutycycle
* Note: The PID controller calculates the new dutycycle
void CalcPID (void)
//printf("\n\ru0=%lu\n\r",u0.l);
x0 = (Kr*u0)/1000; // P-action with Kr=100
y1 = y0 + x0/Ti*dt;
z1 = y0 + x0; // I-action with timeconstant Ti= 10
u1 = z0 + Td*(z1-z0)/dt; // D-action with timeconstant Td= 1
y0=y1;
z0=z1;
u=u1;
stat.saturated = 0;
if(u1 < 0) //limit the calculated new dutycycle to zero to prevent strange behaviour
stat.saturated = 1;
u1 = 0; // limit u1
if(u1 > 1023) //limit the calculated new dutycycle to 1023 to prevent strange behaviour
stat.saturated = 1;
u1 = 1023; // limit u1
if (!stat.open) //if door is opening, set pwm duty cycle to ccp1
set_pwm1_duty(u1);
else //if door is closing, set pwm duty cycle to ccp3
set_pwm3_duty(u1);
* Function: void PicInit(void)
* Input: None
* Output: None
* Note: Has to be called before any other function
void PicInit(void)
*0xF92=*0xF92 & 0xFC; //a0 and a1 output
set_tris_c(0b10111011);
set_tris_d(0b11111101);
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
#use fast_io(d)
#use fast_io(e)
#use fast_io(f)
#use fast_io(g)
output_low(enable);
output_low(PIN_D1); //lower the pwm signals to prevent drifting of the door
output_low(PIN_C2); //lower the pwm signals to prevent drifting of the door
setup_adc(ADC_CLOCK_INTERNAL); //setup AD-Converter for Current measurement
setup_adc_ports(AN0_TO_AN4);
set_adc_channel(4); //set ADC to channel 4
setup_timer_1 ( T1_EXTERNAL_SYNC); //setup timer1 as counter for the pulscount
setup_timer_2 ( T2_DIV_BY_1, 255, 16); //setup timer2 as clocksource for PWM and generate an interrupt every 16 dutyc.
enable_interrupts(INT_EXT3); //setup external interrupt for light sensor
INTEDG3 = 0; //falling edge triggering
enable_interrupts(GLOBAL); //enable all interrupts
delay_ms(1000); //delay to get a stable signal to switch from programming mode to UART tool
stat.manual = 0;
accel = 0;
vlim = 0;
stat.summerwinter = 1; //summertime
stat.closed = 1;
halfdist = 0;
set_timer1(0);
printf("Software was compiled on: ");
printf(__DATE__);
printf(" at ");
printf(__TIME__);
printf(" \n\r ");
* Function: void UDPRxTask(void)
* PreCondition: The following functions have to be called:
* PicInit()
* MACAddrInit()
* IPAddrInit()
* StackInit()
* StackTask()
* Input: None
* Output: ibuffer[]
* Note: None
void UDPRxTask(void) {
static enum {UDP_RX_OPEN=0, UDP_RX_LISTEN=1, UDP_RX_BLAH=2}
state[UDP_NUM_LISTEN_SOCKETS]={0};
static UDP_SOCKET socket[UDP_NUM_LISTEN_SOCKETS]={INVALID_UDP_SOCKET};
int8 i,z=0, c;
for (i=0;i<UDP_NUM_LISTEN_SOCKETS;i++) {
if (socket[i]==INVALID_UDP_SOCKET)
state[i]=UDP_RX_OPEN;
switch (state[i]) {
case UDP_RX_OPEN:
socket[i]=UDPOpen(UDP_SOURCE_PORT,NULL,INVALID_UDP_SOCKET);
if (socket[i]!=INVALID_UDP_SOCKET) {
printf("\r\nUDP SOCKET %U OPEN FOR LISTENING", socket[i]);
state[i]=UDP_RX_LISTEN;
case UDP_RX_LISTEN:
if (UDPIsGetReady(socket[i])) {
last_rx_socket=socket[i];
printf("\r\nGOT [IP:%U.%U.%U.%U",
UDPSocketInfo[socket[i]].remoteNode.IPAddr.v[0],
UDPSocketInfo[socket[i]].remoteNode.IPAddr.v[1],
UDPSocketInfo[socket[i]].remoteNode.IPAddr.v[2],
UDPSocketInfo[socket[i]].remoteNode.IPAddr.v[3]
printf(" SP:%LU DP:%LU S:%U] - ",
UDPSocketInfo[socket[i]].remotePort,
UDPSocketInfo[socket[i]].localPort,
socket[i]
printf("\f%U.%U.%U.%U\n",
while(UDPGet(&c)) {
ibuffer[z]=c;
printf("%u",ibuffer[z]);
z++;
* Function: void UDPTxTask(void)
* PicInit()
* MACAddrInit()
* IPAddrInit()
* StackInit()
* StackTask()
* Input: obuffer[]
* Output: None
* Note: None
void UDPTxTask(void) {
static enum {UDP_TX_OPEN=2, UDP_TX_WAIT=0, UDP_TX_DEBOUNCE=1,
UDP_TX_ISREADY=3} state=0;
static int8 tx_socket;
switch (state) {
case UDP_TX_WAIT:
if (last_rx_socket!=INVALID_UDP_SOCKET) {
state=UDP_TX_OPEN;
case UDP_TX_OPEN:
tx_socket=UDPOpen(UDP_SOURCE_PORT, &UDPSocketInfo[last_rx_socket].remoteNode, UDP_DESTINATION_PORT);
if (tx_socket==INVALID_UDP_SOCKET)
printf("\r\nCan't open UDP socket for transmit");
state=UDP_TX_WAIT;
state=UDP_TX_ISREADY;
case UDP_TX_ISREADY:
if (UDPIsPutReady(tx_socket)) {
printf(UDPPut,"%u%u",obuffer[0],obuffer[1]);
UDPFlush();
UDPClose(tx_socket);
state=UDP_TX_WAIT;
* PreCondition: PicInit() has to be called
* Input: Speed and MaxCurrent has to be defined
* Output: total distance in pulses
* Note: None
int8 nCurrent=0, i, maxcurr = 80, speed = 100;
signed int32 totdist;
output_low(PIN_D1);
set_pwm1_duty(0);
for (i=1;i<=speed;++i)
set_pwm1_duty(i);
delay_ms(30);
nCurrent = read_adc();
if (nCurrent > maxcurr)i=speed;
while (nCurrent < maxcurr)
obuffer[0]=0;
obuffer[1]=1;
UDPTxTask();
set_pwm1_duty(0);
setup_ccp1(CCP_OFF);
output_low(PIN_C2);
set_pwm3_duty(0);
set_timer1(0);
set_pwm3_duty(i);
delay_ms(30);
totdist = get_timer1();
set_pwm3_duty(0);
output_low(PIN_D1);
obuffer[0]=0;
obuffer[1]=0;
UDPTxTask();
return(totdist);
// ccstcpip.h - Common code shared among all Embedded Internet/Embedded
// Ethernet tutorial book examples.
// If you are using a CCS Embedded Ethernet Board (labeled PICENS, which
// has an MCP ENC28J60) then define STACK_USE_CCS_PICENS to TRUE.
// If you are using a CCS Embedded Internet Board (labeled PICNET, which
// has a Realtek RTL8019AS and a 56K Modem) then define STACK_USE_CCS_PICNET
// to TRUE.
// 10/25/06
// - Added STACK_USE_CCS_PICEEC
// - ExampleUDPPacket[] UDP header length fixed
// 2008.12.20 - JGSCHMIDT
// - added STACK_USE_CCS_OLXMINI for Olimex Mini-Web board
#define STACK_USE_CCS_PICEEC 1
#define STACK_USE_MCPINC 1
#include <18F67J60.h>
#device adc=8
#device HIGH_INTS=TRUE
#use delay(clock=25M)
#fuses NOWDT, NODEBUG, HS, NOIESO, NOFCMEN, PRIMARY, ETHLED
#use rs232(baud=38400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#include "tcpip/stacktsk.c" //include Microchip TCP/IP Stack
void MACAddrInit(void) {
MY_MAC_BYTE1=0;
MY_MAC_BYTE2=2;
MY_MAC_BYTE3=3;
MY_MAC_BYTE4=4;
MY_MAC_BYTE5=5;
MY_MAC_BYTE6=6;
void IPAddrInit(void) {
//IP address of this unit
MY_IP_BYTE1=172;
MY_IP_BYTE2=20;
MY_IP_BYTE3=0;
MY_IP_BYTE4=110;
//network gateway
MY_GATE_BYTE1=172;
MY_GATE_BYTE2=20;
MY_GATE_BYTE3=0;
MY_GATE_BYTE4=1;
//subnet mask
MY_MASK_BYTE1=255;
MY_MASK_BYTE2=255;
MY_MASK_BYTE3=255;
MY_MASK_BYTE4=0;
char ExampleIPDatagram[] = {
0x45, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00,
0x64, 0x11, 0x2A, 0x9D, 0x0A, 0x0B, 0x0C, 0x0D,
0x0A, 0x0B, 0x0C, 0x0E
char ExampleUDPPacket[] = {
0x04, 0x00, 0x04, 0x01, 0x00, 0x08, 0x00, 0x00,
0x01, 0x02, 0x03, 0x04
