Need help with motion profile program
Spukkers
PostPosted: Mon Jun 29, 2009 2:39 am     Reply with quote
I need help with my C-program, I found a source code from microchip (AN696). but when I try to change the program to a ccs program, the program simply doesn't work properly.
void UpdTraj (void);
void SetupMove (void);
void UpdPos (void);
void CalcError (void);
void CalcPID (void);
void PicInit(void);
#define TotDist 30000
#define HalfDist TotDist/2
#define Vmax 40
#define DIST 0
#define VEL 1
#define ACCEL 2
#define TIME 3
unsigned int8 firstseg, lastseg, segnum, parameter;
int16 dtime, integral, kp, ki, kd, vlim, mvelocity, upcount;
int16 segment1[12][4];
int32 position, mposition, fposition, flatcount;
struct Status
int1 phase;
int1 neg_move;
int1 motion;
int1 saturated;
int1 bit4;
int1 bit5;
int1 run;
int1 loop;
} stat;
union LNG
   int32 l;
   unsigned int32 ul;
   int16 i [2];
   unsigned int16 ui [2];
   int8 b [4];
   unsigned int8 ub [4];
union LNG
temp, accel, u0, ypid, velact, phase1dist;
#INT_TIMER2
void servo_isr(void)
   UpdTraj();
   SetupMove();
   UpdPos();
   CalcError();
   CalcPID();
   clear_interrupt(INT_TIMER2);
         PicInit();
         printf("\n\rSTART\n\r");
         //PWM settings
         setup_ccp2(CCP_OFF );
         output_low(PIN_C1);
         output_high(PIN_B5);
         set_pwm1_duty(0);
         setup_ccp1(CCP_PWM);
            if(kbhit())
               switch (getc())
                  case 'q':
                     printf("\n\rAAN");
                     stat.run =1;
                     stat.motion = 1;
                     stat.loop = 0;
                     firstseg = 0;
                     lastseg = 0;
                     segnum = 0;
                     set_timer1(0);
                  case 'w':
                  default:;
void UpdTraj (void)
   if (stat.motion && !stat.saturated)
   {//Do motion profile
      if(!stat.phase)
         //printf("\n\r%lu\n\r",velact.ui[1]);
         if(velact.ui[1] < vlim)
            velact.ul = velact.ul + accel.ul;
            flatcount++;
            //printf("\n\r%lu\n\r",flatcount);
         temp.ul = velact.ul;
         if (velact.ui[0] == 0x8000)
            if (!(velact.ub[2] & 0x01))
               temp.ui[1]++;
            else ;
         else if (velact.ui[0] > 0x8000)
            temp.ui[1]++;
         else;
         phase1dist.ul = phase1dist.ul - (unsigned int32)temp.ui[1];
         if (stat.neg_move)
            position = position - (unsigned int32)temp.ui[1];
            position = position + (unsigned int32)temp.ui[1];
         if (phase1dist.l <= 0)
            stat.phase = 1;
         if (flatcount)
            flatcount--;
         else if (velact.ul)
            velact.ul = velact.ul - accel.ul;
            if (velact.i[1] <0)
               velact.l = 0;
            if (dtime)
               dtime--;
               stat.motion = 0;
               position = fposition;
         if (velact.ui[0]==0x8000)
               temp.ui[1]++;
            else;
         else if (velact.ui[0]>0x8000)
            temp.ui[1]++;
         else;
         if (stat.neg_move)
            position = position - (unsigned int32) temp.ui[1];
            position = position + (unsigned int32) temp.ui[1];
   {//load next segment
      if (stat.run && !stat.motion)
         if (segnum < firstseg) segnum = firstseg;
         if (segnum > lastseg)
            segnum = firstseg;
            if(!stat.loop) stat.run = 0;
            SetupMove();
            segnum++;
      else;
   if (segnum < 12)
      phase1dist.i[0] = segment1[segnum][DIST];
      vlim = segment1[segnum][VEL];
      accel.i[0] = segment1[segnum][ACCEL];
      dtime = segment1[segnum][TIME];
   else ;
   phase1dist.b[2]=phase1dist.b[1];
   phase1dist.b[1]=phase1dist.b[0];
   phase1dist.b[0]=0;
   if (phase1dist.b[2] & 0x80)
      phase1dist.b[3] = 0xFF;
      phase1dist.b[3] = 0;
   accel.b[3]=0;
   accel.b[2]=accel.b[1];
   accel.b[1]=accel.b[0];
   accel.b[0]=0;
   temp.l = position;
   if (temp.ub[0]>0x7F)
      temp.l = temp.l + 0x100;
   temp.ub[0]=0;
   position = temp.l;
   fposition = position + phase1dist.l;
   if (phase1dist.b[3] & 0x80)
      stat.neg_move = 1;
      phase1dist.l = -phase1dist.l;
      stat.neg_move = 0;
   phase1dist.l >>= 1;
   velact.l = 0;
   flatcount = 0;
   stat.phase = 0;
   if (accel.l && vlim)
      stat.motion = 1;
void UpdPos (void)
mvelocity = upcount;
upcount = get_timer1();
mvelocity = upcount - mvelocity;
mposition = mposition + mvelocity;
//printf("\n\r%lu-%lu\n\r",mvelocity, mposition);
   temp.l = position;
   temp.b[0] = 0;
   u0.l = mposition - temp.l;
   u0.b[0] = u0.b[1];
   u0.b[1] = u0.b[2];
   u0.b[2] = u0.b[3];
   if(u0.b[2] & 0x80)
      u0.b[3] = 0xFF;
      if((u0.ui[1] != 0xFFFF) || !(u0.ub[1] & 0x80))
         u0.ui[1] = 0xFFFF;
         u0.ui[0] = 0x8000;
      else;
      u0.b[3] = 0x00;
      if((u0.ui[1] != 0x0000) || (u0.ub[1] & 0x80))
         u0.ui[1]=0x0000;
         u0.ui[0]=0x7FFF;
      else;
void CalcPID (void)
   ypid.l = (int32)u0.i[0]*(int32)kp;
   if(!stat.saturated)
      integral = integral + u0.i[0];
   if(ki)
      ypid.l = ypid.l + (int32)integral*(int32)ki;
   if(kd)
      ypid.l = ypid.l + (int32)mvelocity*(int32)kd;
   ypid.i[0] = u0.i[0]*kp;
   ypid.ub[2]=??????;
   ypid.ub[3]=??????;
   if(!stat.saturated)
   if(ki)
      temp.i[0] = integral * ki;
      temp.ub[2] = ?????;
      temp.ub[3] = ?????;
      ypid.l = ypid.l + temp.l;
   if (kd)
      temp.i[0] = mvelocity * kd;
      temp.ub[2] = ?????;
      temp.ub[3] = ?????;
   if (ypid.ub[3] & 0x80)
      if ((ypid.ub[3] < 0xFF) || !(ypid.ub[2] & 0x80))
         ypid.ui[1] = 0xFF80;
         ypid.ui[0] = 0x0000;
      else;
      if(ypid.ub[3] || (ypid.ub[2] > 0x7F))
         ypid.ui[1] = 0x007F;
         ypid.ui[0] = 0xFFFF;
      else;
   ypid.b[0] = ypid.b[1];
   ypid.b[1] = ypid.b[2];
   stat.saturated = 0;
   if(ypid.i[0] > 1000)
      ypid.i[0] = 1000;
      stat.saturated = 1;
   if (ypid.i[0]< 20)
      ypid.i[0]= 20;
      stat.saturated = 1;
   set_pwm1_duty(ypid.i[0]);
   printf("\n\r%lu\n\r",ypid.i[0]);
void PicInit(void)
   set_tris_a(0b11111100);
   set_tris_b(0b11001111);
   set_tris_c(0b10111001);
   set_tris_d(0b11111111);
   set_tris_e(0b00000000);
   set_tris_f(0b11111111);
   set_tris_g(0b11111111);
   #use fast_io(a)
   //#use fast_io(b)
   //#use fast_io(c)
   #use fast_io(d)
   #use fast_io(e)
   #use fast_io(f)
   #use fast_io(g)
   output_low(PIN_B5);
   output_low(PIN_C1); //PWM signale laag maken
   output_low(PIN_C2); //PWM signale laag maken
   setup_timer_0(RTCC_EXT_L_TO_H);
   setup_timer_1 ( T1_EXTERNAL_SYNC|T1_DIV_BY_1 );
   setup_timer_2 ( T2_DIV_BY_1, 255, 16);
   output_high(PIN_B4);//RX en TX signaal omzetten zodat de UART tool gebruikt kan worden
   set_timer1(0);
   firstseg = 0; // Initialize motion segment
   lastseg = 0; // variables
   segnum = 0;
   parameter = 0; // Motion segment parameter#
   stat.phase = 0; // Set flags to 0.
   stat.saturated = 0;
   stat.motion = 0;
   stat.run = 0;
   stat.loop = 0;
   stat.neg_move = 0;
   dtime = 0;
   integral = 0;
   vlim = 0;
   mvelocity = 0;
   upcount = 0;
   temp.l = 0;
   accel.l = 0;
   u0.l = 0;
   ypid.l = 0;
   velact.l = 0;
   phase1dist.l = 0;
   position = 0;
   mposition = 0;
   fposition = 0;
   flatcount = 0;
   kp= 50;
   ki= 0;
   kd= 0;
   segment1[0][DIST] = 30000;
   segment1[0][VEL] = 18;
   segment1[0][ACCEL] = 2;
   segment1[0][TIME] = 12;
Can anyone help me please.
Who has some experience with a servo system or with the Application note from microchip(AN696).
Regard Spukkers
PostPosted: Mon Jun 29, 2009 1:36 pm     Reply with quote
You implied that you had converted it to CCS, but that it would not run
correctly on a PIC. In fact, it doesn't compile. You need to work
on it some more, so that it compiles without errors.
Also, when you post code, post the #include, #fuses, and #use delay()
statements so the program is complete.
Spukkers
Working code changed AN696
PostPosted: Wed Jul 01, 2009 5:39 am     Reply with quote
I've got our code to work.
with the folliwing code we can control a sliding door with a brushed dc motor.
The pwm controls a l298n to drive the motor.
the motor has a encoder to get the postition of the door. like AN696 except we adjust the program and hardware a litle bit, to use one timer for the pulsecount. We cummunicatie over ethernet (UDP).
#define STACK_USE_ICMP  1  //ethernet settings
#define STACK_USE_ARP   1
#define STACK_USE_UDP   1
#define MAX_SOCKETS     2  //the program needs two sockets, one for sending
#define MAX_UDP_SOCKETS 2  //and one for receiving data
#include "ccstcpip.h"
#include <stdlib.h>
#include <string.h>
#include <math.h>
#CASE // make compiler case sensative
#define UDP_SOURCE_PORT 1024  //set port to receive data from
#define UDP_DESTINATION_PORT  1025  //set port to send data to
#define UDP_NUM_LISTEN_SOCKETS   1  //set maximum number of computers to communicate with
#define enable PIN_B5 //define enable for the l298n, to make programming easier
#bit INTEDG3 = 0xFF1.3  //define bit 3 of register 0xFF1 as INTEDG3,
                        //this bit controls the edge triggring of the external interrupt,H_to_L or L_to_H
UDP_SOCKET last_rx_socket=INVALID_UDP_SOCKET;   //sets the endpoint for the maximum of the UDP sockets
//functions declerations
void OpenInit(void);
void UpdPos (void);
void PicInit(void);
void UDPRxTask(void);
void UDPTxTask(void);
signed int32 Teach(void);
//create variables which can be used trough the hole program
int8 ibuffer[4]={255,255,255,255}, obuffer[2]={255,255};
signed int16 dtime, integral, mvelocity, upcount;
signed int32 position, mposition, fposition, flatcount, vlim;
signed int32 accel, temp, u0, ypid, velact;
signed int32 phase1dist, halfdist, halfdisttemp;
signed int32 x0=0, y0=0, z0=0, u=0;
signed int32 x1, y1, z1, u1;
signed int32 Kr=1, Ti=100, Td=0;        // parameters of the PID-controller
signed int32 U, dt=0.667;
signed int32 timer1old=0, timer1oldold=0,pulses;
struct Status //create a structure to maintain the statusses of the program
int1 phase;
int1 open;
int1 closed;
int1 motion;
int1 saturated;
int1 init;
int1 manual;
int1 run;
int1 summerwinter;
} stat;
#INT_EXT3 FAST //use external interrupt3 for the lightsensor
void light_sens()
   disable_interrupts(INT_TIMER2);
   set_pwm3_duty(0);
   setup_ccp3(CCP_OFF);
   output_low(PIN_D1);
   output_high(enable);
   set_pwm1_duty(0);
   stat.open = 0;
   stat.saturated = 0;
   stat.motion = 0;
   mvelocity = 0;
   upcount = 0;
   temp = 0;
   u0 = 0;
   x0=0; y0=0; z0=0; u=0; x1=0; y1=0; z1=0; u1=0;
   velact = 0;
   position = 0;
   mposition = 0;
   fposition = 0;
   flatcount = 0;
   stat.run = 1;
   stat.motion = 1;
   obuffer[1] = 0;
   phase1dist = get_timer1();
   phase1dist = phase1dist * 500;
   set_timer1(0);
   printf("\n\rphase1dist=%ld\n\r",phase1dist);
   dtime = 3000;
   disable_interrupts(INT_EXT3);
   clear_interrupt(INT_EXT3);
#INT_TIMER2 //interrupt service routine, enters every 16 pwm periods
void servo_isr()
   UpdTraj();
   UpdPos();
   CalcError();
   CalcPID();
         PicInit();
         MACAddrInit(); //initialize the mac adress of the pic
         IPAddrInit();  //initialize the ip-adress of the pic
         StackInit();
            StackTask();
            UDPRxTask();
            switch (ibuffer[0])
               case 0:  //open/close automatic
                  if (!stat.manual && stat.closed )   //if door is not opened manual and door is closed
                     dtime = ibuffer[1] * 1500;
                     printf("\n\rdtime=%ld\n\r",dtime);
                     OpenInit();
               case 1:  //open manual
                  if (!stat.manual) //if door is not opened manual
                     stat.manual = 1;
                     OpenInit();
               case 2:  //close door manual
                  if (stat.manual)  //if door is opened manual
                     stat.manual = 0;
                     dtime = 0 ;
               case 3:  //adjust the acceleration and decceleration
                  accel = ibuffer[1];
                  printf("\n\raccel=%u\n\r",accel);
               case 4:  //adjust the velocity limit
                  vlim = (signed int32)ibuffer[1] * 1000;
                  printf("\n\rvlim=%ld\n\r",vlim);
               case 5:  //initialize the controller
                  accel = ibuffer[1];  //set acceleration/decceleration
                  vlim = (signed int32)ibuffer[2] * 1000;   //set velocity limit
                  halfdisttemp = Teach();
                  if (!stat.manual)//if door is not opened manually set summer or wintertime
                     stat.summerwinter=ibuffer[3];
                     if (stat.summerwinter)
                        halfdist = halfdisttemp * 500;
                        printf("\n\Summertime\n\r");
                        halfdist = halfdisttemp * 250;
                        printf("\n\Wintertime\n\r");
               case 7:
                  if (!stat.manual)//if not opened manually, set summer or wintertime
                     stat.summerwinter=ibuffer[1];
                        halfdist = halfdisttemp * 500;  //door will open full
                        halfdist = halfdisttemp * 250;   //door will open half
               default:;
            if (stat.closed) //if door is closed, and pulses are count, generate error to local pc
               if (get_timer1() > 20)
                  obuffer[0]=1;
                  obuffer[1]=255;
                  UDPTxTask();
                  printf("\n\rALARM!!!\n\rGot pulses\n\r",);
                  set_timer1(0);
            ibuffer[0]=255;//reset the input buffer to prevent that cases are re-entered
            ibuffer[1]=255;
            ibuffer[2]=255;
            ibuffer[3]=255;
 * Function:        void OpenInit(void)
 * PreCondition:    None
 * Input:           None
 * Output:          Initializations are made to open the door
 * Side Effects:    None
 * Note:            This function must be called before open the door
void OpenInit(void)
   setup_ccp3(CCP_OFF );
   output_low(PIN_D1);
   set_pwm1_duty(0);
   stat.open = 0;
   stat.closed = 0;
   stat.saturated = 0;
   stat.motion = 0;
   mvelocity = 0;
   upcount = 0;
   temp = 0;
   u0 = 0;
   velact = 0;
   position = 0;
   mposition = 0;
   fposition = 0;
   flatcount = 0;
   phase1dist = halfdist;
   stat.run =1;
   stat.motion = 1;
   obuffer[1] = 0;
   set_timer1(0);
 * Function:        void UpdTraj(void)
 * PreCondition:    OpenInit() has to be called
 * Input:           None
 * Output:          position where the door supposed to be
 * Note:            This function calculates where door supposed to be
void UpdTraj (void)
      //if (stat.open)printf("\n\rQ\n\r");
      if(!stat.phase)
         //printf("\n\rh\n\r");
         if(velact < vlim)
            velact = velact + accel;
            flatcount++;
         temp = velact;
         phase1dist = phase1dist - temp;
         position = position + temp;
         if (phase1dist <= 0)
            stat.phase = 1;
            phase1dist = 0;
         if (flatcount)
            flatcount--;
         else if (velact)
            velact = velact - accel;
            if (velact < 1)
               velact = 0;
            stat.motion = 0;
            if (stat.open)
               printf("\n\r%lu\n\r", get_timer1());
               set_pwm3_duty(0);
               output_low(PIN_D1);
               obuffer[0]=0;
               obuffer[1]=0;
               UDPTxTask();
               stat.closed = 1;
               set_timer1(0);
         temp = velact;
      if (!obuffer[1])
            obuffer[0]=0;
            obuffer[1]=1;
            UDPTxTask();
      if (!stat.manual)
         if (dtime)
            dtime--;
         else if (stat.run && !stat.motion && !stat.open)
            //stat.run = 0;
            stat.open = 1;
            position = 0;
            mposition = 0;//position;
            set_timer1(0);
            stat.phase = 0;
            stat.saturated = 0;
            mvelocity = 0;
            upcount = 0;
            temp = 0;
            u0 = 0;
            velact = 0;
            mposition = 0;
            flatcount = 0;
            stat.run =1;
            stat.motion = 1;
            setup_ccp1(CCP_OFF );
            output_low(PIN_C2);
            set_pwm3_duty(0);
            setup_ccp3(CCP_PWM);
            enable_interrupts(INT_EXT3);
      else if (stat.manual)
 * Function:        void UpdPos(void)
 * Input:           None
 * Output:          position where the door is at the moment
 * Note:            This function reads where door supposed is
void UpdPos (void)
   upcount = get_timer1() * 1000;
 * Function:        void CalcError(void)
 * Input:           None
 * Output:          Position error
 * Note:            This function calculates the positioning error
      u0 = position - mposition;
      //printf("\n\r%ld - %ld\n\r",position, mposition);
 * Function:        void CalcPID(void)
 * Input:           Positioning error u0
 * Output:          Pwm dutycycle
 * Note:            The PID controller calculates the new dutycycle
void CalcPID (void)
   //printf("\n\ru0=%lu\n\r",u0.l);
   x0 = (Kr*u0)/1000;                   // P-action with         Kr=100
   y1 = y0 + x0/Ti*dt;
   z1 = y0 + x0;  // I-action with timeconstant Ti= 10
   u1 = z0 + Td*(z1-z0)/dt;           // D-action with timeconstant Td=  1
   y0=y1;
   z0=z1;
   u=u1;
   stat.saturated = 0;
   if(u1 < 0) //limit the calculated new dutycycle to zero to prevent strange behaviour
      stat.saturated = 1;
      u1 = 0;  // limit u1
   if(u1 >  1023) //limit the calculated new dutycycle to 1023 to prevent strange behaviour
      stat.saturated = 1;
      u1 =  1023;  // limit u1
   if (!stat.open)   //if door is opening, set pwm duty cycle to ccp1
      set_pwm1_duty(u1);
   else  //if door is closing, set pwm duty cycle to ccp3
      set_pwm3_duty(u1);
 * Function:        void PicInit(void)
 * Input:           None
 * Output:          None
 * Note:            Has to be called before any other function
void PicInit(void)
   *0xF92=*0xF92 & 0xFC;   //a0 and a1 output
   set_tris_c(0b10111011);
   set_tris_d(0b11111101);
   #use fast_io(a)
   #use fast_io(b)
   #use fast_io(c)
   #use fast_io(d)
   #use fast_io(e)
   #use fast_io(f)
   #use fast_io(g)
   output_low(enable);
   output_low(PIN_D1); //lower the pwm signals to prevent drifting of the door
   output_low(PIN_C2); //lower the pwm signals to prevent drifting of the door
   setup_adc(ADC_CLOCK_INTERNAL);   //setup AD-Converter for Current measurement
   setup_adc_ports(AN0_TO_AN4);
   set_adc_channel(4);  //set ADC to channel 4
   setup_timer_1 ( T1_EXTERNAL_SYNC);  //setup timer1 as counter for the pulscount
   setup_timer_2 ( T2_DIV_BY_1, 255, 16); //setup timer2 as clocksource for PWM and generate an interrupt every 16 dutyc.
   enable_interrupts(INT_EXT3);  //setup external interrupt for light sensor
   INTEDG3 = 0;   //falling edge triggering
   enable_interrupts(GLOBAL); //enable all interrupts
   delay_ms(1000);   //delay to get a stable signal to switch from programming mode to UART tool
   stat.manual = 0;
   accel = 0;
   vlim = 0;
   stat.summerwinter = 1; //summertime
   stat.closed = 1;
   halfdist = 0;
   set_timer1(0);
   printf("Software was compiled on: ");
   printf(__DATE__);
   printf(" at ");
   printf(__TIME__);
   printf(" \n\r ");
 * Function:        void UDPRxTask(void)
 * PreCondition:    The following functions have to be called:
 *                  PicInit()
 *                  MACAddrInit()
 *                  IPAddrInit()
 *                  StackInit()
 *                  StackTask()
 * Input:           None
 * Output:          ibuffer[]
 * Note:            None
void UDPRxTask(void) {
   static enum {UDP_RX_OPEN=0, UDP_RX_LISTEN=1, UDP_RX_BLAH=2}
            state[UDP_NUM_LISTEN_SOCKETS]={0};
   static UDP_SOCKET socket[UDP_NUM_LISTEN_SOCKETS]={INVALID_UDP_SOCKET};
   int8 i,z=0, c;
   for (i=0;i<UDP_NUM_LISTEN_SOCKETS;i++) {
      if (socket[i]==INVALID_UDP_SOCKET)
         state[i]=UDP_RX_OPEN;
      switch (state[i]) {
         case UDP_RX_OPEN:
            socket[i]=UDPOpen(UDP_SOURCE_PORT,NULL,INVALID_UDP_SOCKET);
            if (socket[i]!=INVALID_UDP_SOCKET) {
               printf("\r\nUDP SOCKET %U OPEN FOR LISTENING", socket[i]);
               state[i]=UDP_RX_LISTEN;
         case UDP_RX_LISTEN:
            if (UDPIsGetReady(socket[i])) {
               last_rx_socket=socket[i];
               printf("\r\nGOT [IP:%U.%U.%U.%U",
                  UDPSocketInfo[socket[i]].remoteNode.IPAddr.v[0],
                  UDPSocketInfo[socket[i]].remoteNode.IPAddr.v[1],
                  UDPSocketInfo[socket[i]].remoteNode.IPAddr.v[2],
                  UDPSocketInfo[socket[i]].remoteNode.IPAddr.v[3]
               printf(" SP:%LU DP:%LU S:%U] - ",
                  UDPSocketInfo[socket[i]].remotePort,
                  UDPSocketInfo[socket[i]].localPort,
                  socket[i]
               printf("\f%U.%U.%U.%U\n",
               while(UDPGet(&c)) {
                  ibuffer[z]=c;
                  printf("%u",ibuffer[z]);
                  z++;
 * Function:        void UDPTxTask(void)
 *                  PicInit()
 *                  MACAddrInit()
 *                  IPAddrInit()
 *                  StackInit()
 *                  StackTask()
 * Input:           obuffer[]
 * Output:          None
 * Note:            None
void UDPTxTask(void) {
   static enum {UDP_TX_OPEN=2, UDP_TX_WAIT=0, UDP_TX_DEBOUNCE=1,
      UDP_TX_ISREADY=3} state=0;
   static int8 tx_socket;
   switch (state) {
      case UDP_TX_WAIT:
         if (last_rx_socket!=INVALID_UDP_SOCKET) {
         state=UDP_TX_OPEN;
      case UDP_TX_OPEN:
         tx_socket=UDPOpen(UDP_SOURCE_PORT, &UDPSocketInfo[last_rx_socket].remoteNode, UDP_DESTINATION_PORT);
         if (tx_socket==INVALID_UDP_SOCKET)
            printf("\r\nCan't open UDP socket for transmit");
            state=UDP_TX_WAIT;
            state=UDP_TX_ISREADY;
      case UDP_TX_ISREADY:
         if (UDPIsPutReady(tx_socket)) {
            printf(UDPPut,"%u%u",obuffer[0],obuffer[1]);
            UDPFlush();
            UDPClose(tx_socket);
            state=UDP_TX_WAIT;
 * PreCondition:    PicInit() has to be called
 * Input:           Speed and MaxCurrent has to be defined
 * Output:          total distance in pulses
 * Note:            None
   int8 nCurrent=0, i, maxcurr = 80, speed = 100;
   signed int32 totdist;
   output_low(PIN_D1);
   set_pwm1_duty(0);
   for (i=1;i<=speed;++i)
      set_pwm1_duty(i);
      delay_ms(30);
      nCurrent = read_adc();
      if (nCurrent > maxcurr)i=speed;
   while (nCurrent < maxcurr)
   obuffer[0]=0;
   obuffer[1]=1;
   UDPTxTask();
   set_pwm1_duty(0);
   setup_ccp1(CCP_OFF);
   output_low(PIN_C2);
   set_pwm3_duty(0);
   set_timer1(0);
      set_pwm3_duty(i);
      delay_ms(30);
   totdist = get_timer1();
   set_pwm3_duty(0);
   output_low(PIN_D1);
   obuffer[0]=0;
   obuffer[1]=0;
   UDPTxTask();
   return(totdist);
// ccstcpip.h - Common code shared among all Embedded Internet/Embedded
// Ethernet tutorial book examples.
// If you are using a CCS Embedded Ethernet Board (labeled PICENS, which
// has an MCP ENC28J60) then define STACK_USE_CCS_PICENS to TRUE.
// If you are using a CCS Embedded Internet Board (labeled PICNET, which
// has a Realtek RTL8019AS and a 56K Modem) then define STACK_USE_CCS_PICNET
// to TRUE.
// 10/25/06
//  - Added STACK_USE_CCS_PICEEC
//  - ExampleUDPPacket[] UDP header length fixed
// 2008.12.20 - JGSCHMIDT
// - added STACK_USE_CCS_OLXMINI for Olimex Mini-Web board
 #define STACK_USE_CCS_PICEEC 1
 #define STACK_USE_MCPINC 1
 #include <18F67J60.h>
 #device adc=8
 #device HIGH_INTS=TRUE
 #use delay(clock=25M)
 #fuses NOWDT, NODEBUG, HS, NOIESO, NOFCMEN, PRIMARY, ETHLED
 #use rs232(baud=38400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#include "tcpip/stacktsk.c"    //include Microchip TCP/IP Stack
void MACAddrInit(void) {
   MY_MAC_BYTE1=0;
   MY_MAC_BYTE2=2;
   MY_MAC_BYTE3=3;
   MY_MAC_BYTE4=4;
   MY_MAC_BYTE5=5;
   MY_MAC_BYTE6=6;
void IPAddrInit(void) {
   //IP address of this unit
   MY_IP_BYTE1=172;
   MY_IP_BYTE2=20;
   MY_IP_BYTE3=0;
   MY_IP_BYTE4=110;
   //network gateway
   MY_GATE_BYTE1=172;
   MY_GATE_BYTE2=20;
   MY_GATE_BYTE3=0;
   MY_GATE_BYTE4=1;
   //subnet mask
   MY_MASK_BYTE1=255;
   MY_MASK_BYTE2=255;
   MY_MASK_BYTE3=255;
   MY_MASK_BYTE4=0;
char ExampleIPDatagram[] = {
   0x45, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00,
   0x64, 0x11, 0x2A, 0x9D, 0x0A, 0x0B, 0x0C, 0x0D,
   0x0A, 0x0B, 0x0C, 0x0E
char ExampleUDPPacket[] = {
   0x04, 0x00, 0x04, 0x01, 0x00, 0x08, 0x00, 0x00,
   0x01, 0x02, 0x03, 0x04
