Email with GPRS, or how to create a .txt file?
Tagge
PostPosted: Mon Jun 22, 2009 3:19 am     Reply with quote
Hi, does anyone know if there is some max size of an email when using GPRS? I'm using an Telit module and can only send about 1000 bytes at a time?? or do I have something wrong in my code.
I have tried several ways, now using an global buffer of 3000 chars Shocked but it's always only about 800 bytes that comes through.
In my program I can see that all is transmitted to the module, but it isn't then in the email, very confusing.
void send_gprs_mail(){
char my_str[21]="", OK=0;
int32 i=0, j=0, x=0;
const int CZ=0x1A;
   for(i=0;i<20;i++)
         my_str[i]=0;
   //disable_interrupts(GLOBAL);
   //disable_interrupts(int_TIMER0);
   output_low(PIN_B2);// DTR On
   //output_low(PIN_B5);//debug
   fprintf(GPRS,"AT#EMAILD=%s,%s,0\r",EMAIL_ADDRESS,UNIT_ID);
   for(i=0;i<20;i++){
         my_str[i]=my_timed_getc();
         if(my_str[i]=='>'){ i=20;OK=1;}
   my_str[i+1]=0;
   fprintf(rs232,"%s\r\n",my_str);
   if(OK){
   fprintf(GPRS,"%s\r\n%02u-%02u-%02u;%02u:%02u\r\n",UNIT_ID,T_YEAR,T_MONTH,T_DAY, T_HOUR,T_MIN);
   get_email_body();
   fprintf(GPRS,"%s",E_MAIL_BODY);
   delay_ms(2000);
   fprintf(GPRS,"%c\r",CZ);
      for(i=0;i<20;i++){
         if(my_str[i]=='K') i=20;
   my_str[i+1]=0;
   delay_ms(5000);
   else fprintf(rs232,"No >!\r\n");
   output_high(PIN_B2);// DTR Off
   //enable_interrupts(GLOBAL);
   //enable_interrupts(int_TIMER0);
// get saved from ext flash /////////////////////////////////
void get_email_body(){
int8 my_i=0, my_page_count=0;
BYTE temp_buffer[100];
   j=0;
     if(PAGE_COUNTER>30){my_page_count=PAGE_COUNTER-30;j=ADDRESS_COUNTER-3000;}
     else{my_page_count=PAGE_COUNTER; j=DATA_ADDRESS;}
     x=0;
      for(i=j;i<ADDRESS_COUNTER;i++){//från address och 100 fram
         flashReadBlock(i,&E_MAIL_BODY[x],1);
         if((E_MAIL_BODY[x] != 0x0) && (E_MAIL_BODY[x] != '!') && (E_MAIL_BODY[x] != 0x1A) && (E_MAIL_BODY[x] != 0x03)&& (E_MAIL_BODY[x] != 0x02))
            x++; }
     E_MAIL_BODY[x]=0x0;
    fprintf(RS232,"%s\r\n", E_MAIL_BODY);
I'm using a PIC18F97J60.
Tagge
Ascii buffer to .txt?
PostPosted: Mon Jun 22, 2009 7:22 am     Reply with quote
Just figured it out, the Telit module cant take larger e-mail bodys than about 1kB. But an attached file can be much larger,
that raises the question, how can I make a ascii buffer to an .txt file?
to be sent with the e-mail.
It dont have to have the .txt end, I suppose it would work with any ending as long it only containes ascii chars?
sri
data transfer with gprs modem
PostPosted: Mon Jun 29, 2009 1:48 am     Reply with quote
hi,
did u finished the programm..i am into the project few days unable to communicate with the gprs module at commands can u please help me with the code.expecting a good response...
thanks in advance
