I am developing an online ups system. I want to get a sine wave by using pwm method. Can anybody assist me regarding this matter? and also need some code.
another way into this
Posted: Mon Jun 22, 2009 2:56 pm
If you want HIGH purity sine functions,
and excellent frequency accuracy ( within .002% of 60 hz)
and wide frequency programmability i suggest you look at the AD9833
I use it in an instrument that has to have .01 hz accuracy from 1 hz to 100 khz - and this part does it to perfection.
The AD9833 it produces a 10 bit accuracy very high purity sine wave
with not too much SPI programming --
I use it several devices and found an EZ way to drive it - using hardware SPI on the PIC.
the secret is to use an EXACT power of 2 as the oscillator reference.
I use 8.388608 and 4.194304 mhz.
programming the part becomes pretty EZ - as all the
divisors are arrived at by simple shifting.
The basic setup is stored as a couple of constants that I initialize it with at system start, and thereafter - you just pump it new divisors to chaneg frequency or switch to square or tri wave output.
Multiple units can be digitally PHASE synchronized by the pic to create precise 3 phase 60 hz signals if you like that sort of thing too.
I admit that as a 60 hz ref its probably overkill
but you will never match the accuracy or purity with simpler circuits,
or trying to filter a PWM signal.
( BTW - you wil be hard pressed to use PWM to make a 60 hz signal
anyway unless you have a ridiculously LOW PIC master osc freq. )
