Zigbee: Problem getting parameters
hayee
PostPosted: Wed Jun 10, 2009 11:21 pm     Reply with quote
I am doing a project using ZigBee. I have one Coordinator board and two Sensor boards. Coordinator sends different data to both of the sensors one by one. The problem is that I am not getting ChildEui64 of both the sensors when I print it.
I print this parameter in each sensor board and it gives me 64bit ID as follows
sensor 1:
f60d1200006f0d00
sensor 2:
c6780e00006f0d00
But in the Coordinator board it will get stuck on one value (i-e f60d1200006f0d00 or other random value) and print the same value for both sensors.
Due to this problem when I power off one sensor, the 2nd sensor also stops receiving data and vice versa.
Does anyone of you know why this is happening ?
hayee
PostPosted: Wed Jun 17, 2009 1:25 am     Reply with quote
Anyone have use Zigbee?
I am stuck in my project.
hayee
PostPosted: Thu Jun 18, 2009 12:48 am     Reply with quote
Can anyone send me some examples of how to make a network using zigbee having "one Coordinator" and "two sleepy sensors" and coordinator sends data to both sleepy sensors.
