jaga Guest
| disable_interrupts(global) seems doesn't work |
Posted: Fri Jun 12, 2009 2:58 pm |
I'm using 2 interruptions one for the int_timer1 and one for int_ext, the isr work perfectly. I always have pulses in INT pin(number 5) of pic12f75.
The trouble is when I try to disable the interruptions (both - I don't need them anymore) the microcontroller works strange, but if I stop to send pulses and put the pin 5 to high level the microcontroller works fine.
I need the micro work with the pulses all the time.
In order to disable the interruptions I only use :
| Code: | | disable_interrupts(global); |
Someone can help.
Thanks in advance. |
Posted: Fri Jun 12, 2009 3:07 pm |
I doubt if the problem is with the disable interrupt command. Post your compiler version, in case there is an issue with your version, but I have not seen a fault with this, in several years...
A number of comments apply though:
Where are you disabling the interrupts?. You _cannot_ use this command inside an ISR. The global flag is always re-enabled when you leave an ISR (this is done by the _hardware_), so if you were performing the disable inside the ISR, this would explain what you are seeing.
Are you sure that the supply is remaining properly stable as the pulses arrive?. Try a simple test without interrupts, but with the pulse train present.
The internal interrupt flags will still be set, if an interrupt even occurs while the master disable is 'off'. You will need to clear these flags, before turning the interrupts back on, or you will get a spurious trigger at this point.
jaga Guest
| disable_interrupts(global) seems doesnt work |
Posted: Mon Jun 15, 2009 12:23 pm |
Ttelmah, thank you.
I'm using the version 4.057.
Here is my code.
#include <12f675.h>
//#fuses INTRC_IO,NOWDT,NOMCLR,NOWP
#fuses HS,NOWDT,PUT,NOPROTECT,NOCPD,NOMCLR,BROWNOUT
#case
//#priority int_ext
#define PIN_TX PIN_A0
#define PIN_RX PIN_A3
#define PIC_RDY PIN_A1
//#use rs232(baud=57600,xmit=PIN_TX,errors,timeout=50)
#use rs232(baud=115200,xmit=PIN_TX,rcv=PIN_RX,errors)//,timeout=2)//
int8 odo_LSB=0,odo_MSB=0;
int8 vel=0;
//int8 cdna_dumm[5]={0};
int8 cdna[10]={0};
int1 flgNewData=FALSE;
int1 flgEnviaVel=FALSE;
int8 count_cien_ms=0;
int1 flgSendRdy=FALSE;
int1 flg_noint=FALSE;
int8 a0=0,a1=0,a2=0,a3=0,a4=0,a5=0;
int8 cuenta2odo=0;
//int8 odo_MSB_ante=0,acel=0;
#int_ext
rcv_data()
// gets(cdna);
cdna[0]=getc();
cdna[1]=getc();
if(cdna[1]==255)
odo_LSB=(int8)cdna[0];
odo_MSB=(int8)cdna[1];
//!vel=(int8)cdna[2];
if(odo_LSB<=220)
flg_noint=FALSE;
flgNewData=TRUE;
#int_timer1
void times()
cuenta2odo++;
count_cien_ms++;
if(count_cien_ms>=2)
count_cien_ms=0;
flgEnviaVel=TRUE;
delay_ms(8000);
setup_adc_ports(NO_ANALOGS);
ext_int_edge( L_TO_H );
enable_interrupts(INT_EXT);
setup_timer_1(T1_DIV_BY_8|T1_INTERNAL);//overflow cada 104.8 ms
output_low(PIC_RDY);
//RECEPCION DE DATOS
//ENVIO DE DATOS
if((input(PIC_RDY)==1))//&&(flgNewData==TRUE))
{//Enviamos la ultima cadena recibida
cuenta2odo=0;
//printf("HOLA\n\r");
if((flgEnviaVel==TRUE)&&(flg_noint==FALSE))
printf("%c",odo_LSB); //odom_LSB
// printf("%c",odo_MSB); //odom MSB
printf("%c",255); //vel
// printf("%c",255);
flgEnviaVel=FALSE;
while(input(PIC_RDY)==1);
if(cuenta2odo>=7)//SE dejo en bajo la peticion de vel por 1 seg:revisar en reset de modems que pasaria
disable_interrupts(GLOBAL);
delay_ms(10);
//habilñitamos bandera de recepcion de datos
flg_noint=TRUE;
if(flg_noint==TRUE)
a0=getc();
a1=getc();
a2=getc();
a3=getc();
if(input(PIC_RDY)==1)
printf("%c",a0);
printf("%c",a1);
printf("%c",a2);
printf("%c",a3);
I have not find what´s wrong with this yet. I hope someone can help. |
mkuang
Posted: Mon Jun 15, 2009 1:00 pm |
What are you trying to do here?
rcv_data()
// gets(cdna);
cdna[0]=getc();
cdna[1]=getc();
if(cdna[1]==255)
if(odo_LSB<=220)
flg_noint=FALSE;
flgNewData=TRUE;
Getc() fetches an ASCII character between between 0 and 127 inclusive. So I am confused as to what this accomplishes:
Posted: Mon Jun 15, 2009 1:08 pm |
| Quote: | | Getc() fetches an ASCII character between between 0 and 127 |
Not true. It gets a byte from 0 to 255.
Here's part of the .LST file for a test program using the hardware UART
on an 18F452. Notice how it moves RCREG directly into 'c'.
It doesn't mask down the byte. It gets all 8 bits.
| Code: | .......... c = getc();
0020: BTFSS PIR1.RCIF
0022: BRA 0020
0024: MOVFF RCREG,c |
mkuang
Posted: Mon Jun 15, 2009 1:25 pm |
| PCM programmer wrote: | | Quote: | | Getc() fetches an ASCII character between between 0 and 127 |
0022: BRA 0020
Yes indeed...
Now I am even more confused. The UART is receiving ASCII characters right? And ASCII characters only range from 0 to 127. When will you get anything in the receive buffer that is greater than 127?
Sorry I don't know the language that the comments from the original code were written in. |
Posted: Mon Jun 15, 2009 1:34 pm |
The PIC's UART sends and receives 8-bit bytes. (At least, it does this
in its normal configuration, with 1 start bit, 8 data bits, and 1 stop bit). |
