mradrenalin
Internal Error - Contact CCS - Function Pointers |
Posted: Tue Jun 16, 2009 12:27 am |
I get this error
Line 23(1,1) Internal Error - Contact CCS LABEL SCR=686
error flashes for curly bracket after "void main()"
#include <18F4550.H>
#fuses NOWDT, NOPROTECT, NOPUT
#use delay(clock = 25000000)
#include "flex_lcd.c"
#build(reset=0x800)
#build(interrupt=0x808)
#org 0x0000,0x07ff
void bootloader()
#asm nop
#endasm
void text0(void);
void text1(void);
typedef int (*intfptr)();
intfptr func[2] = {text0,text1};
lcd_init();
void text0()
lcd_putc("text0");
int text1(int a)
lcd_putc("text1");
Posted: Tue Jun 16, 2009 2:22 am |
As I said, when I posted the typedef you are using, _CCS, does not support initialisation of function pointers, in the declaration_.....
