seme1
Timer on PIC18F46K20 |
Posted: Sat Jun 13, 2009 8:47 am |
PIC18F46k20
PCW 4.078
#include <18F46K20.h>
#device adc=8
#FUSES LP //Low power osc < 200 khz
#FUSES H4
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
unsigned int8 fd =0,sd=0,td=0;
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
// TODO: USER CODE!!
output_high(PIN_A1);
// implementing the delay ... seems like the code gets stock here for some reason and never reaches the output_high(PIN_A0);
for( fd=0;fd<20;fd++){
for (sd=0;sd<20;sd++){
for (td=0;td<20;td++){ }
while(TRUE){
for( fd=0;fd<200;fd++){
for (sd=0;sd<200;sd++){}
output_toggle(PIN_A0);
When running the above code, it doesn't reach output_high(PIN_A0); and it seems like it's stuck in the for loops for some reason.
I tried the following (having two inner for loops instead of three)
Code: | for( fd=0;fd<20;fd++){
and it reached the line output_high(PIN_A0); and executed it. However, there is never a delay inside the while loop (it is supposed to keep toggling A0 from low to high, and the opposite, to give a flashing effect to an LED)
Anybody has any idea what am I doing wrong here? |
Posted: Sat Jun 13, 2009 9:10 am |
#FUSES H4 |
Don't use multiple oscillator fuses. Just use one of them.
output_high(PIN_A0); |
Don't do this. Use the delay_us() and delay_ms() functions that are built
into the compiler. |
seme1
Posted: Sat Jun 13, 2009 11:54 am |
Thanks a lot for your help
Now, I have the following:
#device adc=8
#fuses H4, NOWDT, PUT ,BROWNOUT, NOLVP
#use delay(clock=16000000)
setup_wdt(WDT_OFF);
while(TRUE){
output_low(PIN_A1);
output_low(PIN_A0);
I am using the following to connect Pins 13 and 14 (CLKI and CLKO) on the PIC.
http://img5.imageshack.us/img5/9572/dsc09503w.jpg
The effect I see when running it on the PIC is that A1 stays ON all the time (no flashing effect) and A0 stays off with no blinking, too.
Removing the quartz crystal while the circuit is connected to power causes A1 to go OFF, putting it back makes A1 go ON again.
Any help for the newbie here is very much appreciated. ![Embarassed](images/smiles/icon_redface.gif) |
Posted: Sat Jun 13, 2009 3:08 pm |
You need the NOXINST fuse back.
However the behaviour, sounds as if your oscillator is not actually running. The way you talk about 'removing the crystal', suggests you are using something like a plug in breadboard?. If so, be aware that the capacitance of these can be enought to stop the oscillator running on some versions....
seme1
Posted: Sat Jun 13, 2009 5:56 pm |
I have tried the following, and the result is that A0 and A1 are always HIGH !! (there is no flashing effect at all)
#device adc=8
#fuses INTRC, NOWDT, PUT ,BROWNOUT, NOLVP
while(TRUE){
delay_ms(70);
output_low(PIN_A1);
delay_ms(70);
output_low(PIN_A0);
delay_ms(70);
My understanding is that this does not require the external quartz crystal to work. When running the above, removing the quartz crystal does not cause A1 and A0 to go down as what happened previously with the fuse H4.
Any clues what could be causing this ?? |
