arithmatic problem.
jaethelegend
arithmatic problem.
PostPosted: Sat Jun 13, 2009 12:22 am     Reply with quote
HI, I have a question about variable types.
#include<C:\Documents and Settings\Microsoft\My Documents\PIC\Header\16f886.h>
#include<C:\Documents and Settings\Microsoft\My Documents\PIC\Header\def_16f886.h>
#fuses INTRC_IO
#use delay(clock = 1000000)
int8 hund_digit=0;
int8 thou_digit=0;
int8 ten_digit = 0;
int8 one_digit = 0;
int16 num2display = 438;
void disp_rtn(int16 buffer){
   thou_digit = buffer/1000;
   buffer -= thou_digit*1000;
   hund_digit = buffer/100;
   buffer -=hund_digit*100;
   ten_digit = buffer/10;
   one_digit = buffer-ten_digit*10;
void main(void){
   disp_rtn(num2display);
The coding does not separate correct digits. However, if i change the variable types of thou_digit,hund_digit, etc, to int16, all the sudden it starts working again.
Anybody have an idea?
jaethelegend
additional question
PostPosted: Sat Jun 13, 2009 12:34 am     Reply with quote
void main(void){
init_rtn();
   while(1){
adc_in = READ_ADC();
disp_number = adc_in/1023*5000;
disp_rtn(disp_number);
Does not work
but if i change
disp_number = adc_in/1024*5000;
to
disp_number = adc_in*4.886;
All the sudden it starts working
Anybody has an idea?
FvM
PostPosted: Sat Jun 13, 2009 1:43 am     Reply with quote
If I remember right, a similar example has been discussed a few days before.
Gives only correct result, if hund_digit <2, because the multiply result is of int8 type. You must typecast one term to int16 before, e.g.:
buffer -=(int16)hund_digit*100;
Also the second example shows, that you should think about the way, integer expressions are evaluated by the compiler. adc_in/1024 can be supposed to have a result of zero for all possible ADC values.
(int32)adc_in*5000/1024
should give the intended result.
