seme1 Guest
| "Warning: No configuration words in hex file" |
Posted: Sat Jun 13, 2009 5:58 am |
PIC18F46K20
PCW 4.078
Code I'm compiling is very simple:
#include <16F877A.h>
#device adc=8
#include <stdio.h>
#include <stdlib.h>
#include <lcd.c>
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
// TODO: USER CODE!!
output_high(PIN_A0);
lcd_init();
lcd_putc("\f NuTrade Sys\n TESTing 1.0 ");
while(TRUE){
// delay_ms(4000);
int8 fd=0;
for(fd=0;fd<10000;fd++){
output_toggle(PIN_A0);
After compiling the program, when I try importing the generated hex file with PICkit2 I always get the message : "Warning: No Configuration words in hex file. In MPLAB use File-Export to save hex with config"
Any idea what could be causing this and how to fix it ? |
seme1
Posted: Sat Jun 13, 2009 6:05 am |
Nevermind,,
I just realized that the device type has been changed for some reason..
The warning message is no longer displayed now |
Posted: Sat Jun 13, 2009 3:03 pm |
Also, as a comment, put your 'includes', except for the processor one, after the delay, and #use RS232 statements (if present).
Basically, the latter depends on the former, and anything that depends on delay timings, and RS232, should have the statements present _before_ being included, or you may get unexpected results....
