question on setup_adc_ports()
juanjose
PostPosted: Thu Jun 25, 2009 12:46 am     Reply with quote
The combinations offered by the setup_adc_ports() do not attend my requirement.
I need to setup the AN7 on the RE3 port plus the AN0 on the RA0 port of a 16f877a, but the options available on the mentioned instruction do not cover this combination.
Is there another way to setup the ADC ports than the setup_adc_ports() ????
thanks in advance
juanjose
PostPosted: Thu Jun 25, 2009 1:43 am     Reply with quote
You can't do it with the 16F877A. Read these threads:
http://www.ccsinfo.com/forum/viewtopic.php?t=37899
http://www.ccsinfo.com/forum/viewtopic.php?t=38361
juanjose
PostPosted: Thu Jun 25, 2009 9:40 am     Reply with quote
Hi PCM programmer
I did not realize it was a chip design limitation.
As I want to use some 16f877A leftovers, I will swap the connections between RE3 and RA1 or RA2.
Thanks a lot for the fast and objective answer.
juanjose
