Converting a unix time stamp
ktallevi
PostPosted: Tue Oct 21, 2008 12:49 pm     Reply with quote
Does CCS have any built-in functions to convert a unix time stamp to something usable.
Eg. 685586AC (hex) -> 16:05:00 June 20 2025
thanks.
PostPosted: Tue Oct 21, 2008 4:09 pm     Reply with quote
The ctime() function does the conversion from a Unix Timestamp to
a readable date and time. That function is the rtctimer.c file, which
is included with the CCS compiler. Here is the file location:
c:\Program Files\picc\Drivers\rtctimer.c
The test program shown below has the following output:
Fri Jun 20 16:05:00 2025
#include <16F877.H>
#include <rtctimer.c>
int32 tTime;
int8 tString[80];
tTime = 0x685586AC;
ctime(&tTime, tString);
printf(tString);
PostPosted: Tue Oct 21, 2008 4:25 pm     Reply with quote
Not for UNIX date/time, but in the Code Library are some optimized time routines for years 2001 - 2098.
http://www.ccsinfo.com/forum/viewtopic.php?t=25611
Add or subtract the number of seconds from 1-1-1970 to 1-1-2001 and you are up and running.
crystal_lattice
PostPosted: Wed Oct 22, 2008 12:28 am     Reply with quote
Or have a look at the AN517 appnote from Maxim/Dallas.
D-Kens
PostPosted: Mon Jun 08, 2009 3:45 am     Reply with quote
PCM programmer wrote:
The ctime() function does the conversion from a Unix Timestamp to a readable date and time. That function is the rtctimer.c file, which is included with the CCS compiler.
Nice !!! I didn't know there were tools to work with Unix timestamps... But... Euh... How comes I don't have the RTCTimer library in my Drivers directory ? Confused
PostPosted: Mon Jun 08, 2009 5:06 am     Reply with quote
How old is your compiler?.
This library, only appeared with the V4 releases. It came out, mid 2007.
