jaethelegend Guest
| About LCD control |
Posted: Sat Jun 06, 2009 7:01 am |
Hi, I was originally using a full PORT with all 8 ports available to control a LCD display, connecting RA0~2 to RS,RW,EN and RA4~7 to D04~7.
It worked fine.
Now, i tried to practice different ways of doing it for later use by
connecting RA0~3 to D4~7 and RS to D5, RW to D6, R7 to EN.
I guess the biggest difference between first coding scheme and the second coding scheme is that in first coding scheme, i controlled(outputted) the entire 7 required bits to the LCD at a time. In second time, I played with the output ports before i pulsed enable signal.
below is quick code example
First Scheme which worked fine.
| Code: | void Busy_Check(){
int8 high_nibble, low_nibble;
do{
LCD_TRIS = 0b10000000;
LCD_PORT = 0b00000110; // RS=0, RW=1 EN=1
delay_us(14);
high_nibble=LCD_PORT;
delay_us(14);
LCD_PORT = 0b00000010; //RS = 0, RW = 1, EN = 0
LCD_PORT = 0b00000110; //RS = 0, RW = 1, EN = 1
delay_us(14);
low_nibble = LCD_PORT;
delay_us(14);
LCD_PORT = 0b00000010; // RS = 0, RW = 1, EN = 0
}while(high_nibble&0x80);
LCD_TRIS = 0x00;
LCD_PORT = 0x00;
Second scheme which didn't work
void busy_check(void){
do{
LCD_PORT = 0b00000000; // RS=0, RW=1 EN=1
R_W = 1;
E_N = 1;
delay_us(14);
high_nibble=LCD_PORT; //LCD로 부터 나오는 상위 니블 리드.
delay_us(14);
E_N = 0;
E_N = 1;
delay_us(14);
delay_us(14);
E_N = 0; // RS = 0, RW = 1, EN = 0
}while(high_nibble&0x80); //D7 이 1이면 받을 준비가 안됨.
LCD_TRIS = 0x00;
LCD_PORT = 0x00;
Thank you, I appreciate your help |
Steve H Guest
Posted: Sat Jun 06, 2009 9:44 am |
You realize that in the 4 bit nibble mode - you have to go through a special initialize sequence for the LCD? You can find this in a bunch of places (try the CCS examples, Google or the LCD data sheet) or look at some of my code here,
http://geocities.com/hagtronics/wwvb.c
HTH - Steve H. |
jaethelegend Guest
Posted: Sun Jun 07, 2009 9:46 pm |
| Thanks guys! |
