jaethelegend Guest
arithmatic problem. |
Posted: Sat Jun 13, 2009 12:22 am |
HI, I have a question about variable types.
#include<C:\Documents and Settings\Microsoft\My Documents\PIC\Header\16f886.h>
#include<C:\Documents and Settings\Microsoft\My Documents\PIC\Header\def_16f886.h>
#fuses INTRC_IO
#use delay(clock = 1000000)
int8 hund_digit=0;
int8 thou_digit=0;
int8 ten_digit = 0;
int8 one_digit = 0;
int16 num2display = 438;
void disp_rtn(int16 buffer){
thou_digit = buffer/1000;
buffer -= thou_digit*1000;
hund_digit = buffer/100;
buffer -=hund_digit*100;
ten_digit = buffer/10;
one_digit = buffer-ten_digit*10;
void main(void){
disp_rtn(num2display);
The coding does not separate correct digits. However, if i change the variable types of thou_digit,hund_digit, etc, to int16, all the sudden it starts working again.
Anybody have an idea? |
jaethelegend Guest
additional question |
Posted: Sat Jun 13, 2009 12:34 am |
Code: | void main(void){
init_rtn();
while(1){
adc_in = READ_ADC();
disp_number = adc_in/1023*5000;
disp_rtn(disp_number);
Does not work
but if i change
Code: | disp_number = adc_in/1024*5000; |
to
Code: | disp_number = adc_in*4.886; |
All the sudden it starts working
Anybody has an idea?
Thanks |
FvM
Posted: Sat Jun 13, 2009 1:43 am |
If I remember right, a similar example has been discussed a few days before.
Code: | buffer -=hund_digit*100; |
Gives only correct result, if hund_digit <2, because the multiply result is of int8 type. You must typecast one term to int16 before, e.g.:
Code: | buffer -=(int16)hund_digit*100; |
Also the second example shows, that you should think about the way, integer expressions are evaluated by the compiler. adc_in/1024 can be supposed to have a result of zero for all possible ADC values.
Code: | (int32)adc_in*5000/1024 | should give the intended result. |
