timer interrupt issues PCM - but really all pics
asmboy
PostPosted: Sat Jun 06, 2009 8:10 am     Reply with quote
Is there a way to RELIABLY manage MORE than an int8 time keeping variable - with an interrupt based timer?
I have happy been using a timer0 -interrupt based timer that updates a SINGLE byte quantity at a 10 mSec rate - the high level 'user' functions must poll often enough to know how many "ticks' have elapsed.
BUT
I can't think of a way to SAFELY use an int32 counter for the same purpose ,
due to the certainty that timer0 interrupts will occur DURING the high level function calls, trying to READ the multi byte format -and change the bytes of the long integer - as they are being read .
This sort of thing was EZ to solve in the 808x environment I was used to in a former life - is the same sort of code needed here ?
ie disabling the timer0 int - copying my timer int32 counter to a temp var - and then re enabling the timer ints ( what I did in PC assembler)
Is there an elegant - simple solution I should know about ?
PostPosted: Sat Jun 06, 2009 9:07 am     Reply with quote
There is a pretty easy means, that is generally used in all similar cases, where consistency of data structures across interrupt calls is an issue: Disabling interrupts temporarily, either globally or the respective conflicting one.
PostPosted: Sat Jun 06, 2009 10:10 am     Reply with quote
Yes. the 'normal' method, is to have a variable used only in the interrupt handler, and a 'copy', used by the external routines.
disable_interrupts(global);
local_tick=timer_tick;
enable_interrupts(global);
//work using 'local_tick' here.
I also, if using a 'fast' tick, will still only update an 8bit value in the interrupt, then instead of the above code, use:
if (local_tick > timer_tick)
   ++local_msb;
This way there is still only an 8bit counter in the timer, while the main code has a 'tick', and an extended counter. Often I'll create a union, so that I have (say), an 8bit 'tick', and a 16bit extended counter, stored in a 32bit value, to give 24bits useable, without using 32bit arithmetic.
