Two serial and several speeds
Luiz
PostPosted: Wed Jun 03, 2009 7:05 am     Reply with quote
Hello to all
As I do to change the speed of the stream COM2,
#use rs232 (baud=10400, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8)
set_uart_speed (9600); / / it WORKS LIKE THIS
set_uart_speed (19200);
set_uart_speed (4800);
Is it here as I can do to change the speed?
#use rs232 (baud=9600, parity=N, rcv=PIN_A4, bits=8, STREAM=COM2)
Luiz.
PostPosted: Wed Jun 03, 2009 7:57 am     Reply with quote
According to the CCS manual set_uart_speed() provides for an optional Stream parameter
set_uart_speed( )
Syntax: set_uart_speed (baud, [stream, clock])
Parameters: baud is a constant 100-115200 representing the number of bits per second.
stream is an optional stream identifier.
clock is an optional parameter to indicate what the current clock is if it is
different from the #use delay value
Luiz
PostPosted: Wed Jun 03, 2009 8:20 am     Reply with quote
Would it be like this, but and how much the clock?
set_uart_speed(9600,[COM2, ??);
set_uart_speed(10400,[COM2, ??);
set_uart_speed(4800,[COM2, ??);
PostPosted: Wed Jun 03, 2009 8:22 am     Reply with quote
The clock parameter is also optional so:
set_uart_speed(9600,COM2); should be all you need.
Luiz
PostPosted: Wed Jun 03, 2009 9:08 am     Reply with quote
I am using like this.
#include < 18F2685.h>
#use delay (clock = 8000000)
#use rs232 (baud=19200, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8)
#use rs232 (baud=19200, parity=N, rcv=PIN_A4, bits=8, STREAM=COM2)
#int_RDA
void RDA_isr () {CK [PD] = getch (); PD++;IF (PD==0) ck [2] = 0;IF (PD==2) PD=0; }
void main (void)
putc (0x70);
delay_ms (10);
rx=CK [0];
if (rx==0x0D){
PD=0;
set_uart_speed (4800, COM2);
fputc (0x0A);
delay_ms (10);
set_uart_speed (9600, COM2);
rx1=fgetc (COM2);
// Here it doesn't work, the speed doesn't change!
PostPosted: Wed Jun 03, 2009 5:12 pm     Reply with quote
From the CCS manual
Returns: undefined
Function: Changes the baud rate of the built-in hardware RS232 serial port at run-time.
Availability: This function is only available on devices with a built in UART.
The stream on COM2 does not use a hardware UART, so you can't change the baudrate this way.
Solutions to change the baudrate for a soft UART have been posted on this forum.
Luiz
PostPosted: Thu Jun 04, 2009 6:37 am     Reply with quote
Could you give an example?
PostPosted: Thu Jun 04, 2009 11:31 am     Reply with quote
Like I said, solutions have been posted on this forum before, use the Search function of this forum to find them. I don't have time now to search these solutions so why don't you give it a try. If you can't find them, post again.
