Delays and Interrupts: a little problem...
rhaguiuda
PostPosted: Wed Jun 03, 2009 11:15 am     Reply with quote
Hello Fellows...
One of the biggest problems when using delays and interrupts is that the compiler must disable interrupts while calling the delay function. (to prevent re-entrancy).
Some applications must use lots of delays to accomplish its tasks (like make some bit-bang communications timing just fine).
I wonder what programming techniques do you use to make less use of delays (when a delay is needed) that makes possible calling delays, and using interrupts at the same time.
Or, just some technique to make a precise delay time, not using delay_us, delay_ms or delay_cycles.
Thanks!
Give a man a fish and you'll feed him for a day. Teach a man to fish, and you'll feed him for a lifetime.
PostPosted: Wed Jun 03, 2009 11:35 am     Reply with quote
You can fix this problem by creating a 2nd instance of the #use delay
library code. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=27345
PostPosted: Wed Jun 03, 2009 5:45 pm     Reply with quote
A technique I oftern use for timers is to create interrupt driven 'software timers'.
For every timer you want you create a global variable:
int8 MyTimer1;
int8 MyTimer2;
int8 MyTimer3;
Setup timer0 to fire (about) every 100ms. This will give you a timer range of 0.1 to 25.5sec
// CLOCK CRYSTAL FREQUENCY
#define XTAL_FREQ          16000000
// value for timer0 to fire every 100 ms
#define MS_100              (int16)(0x0000 - (XTAL_FREQ / (4 * 64 * TIMER0_PER_SECOND)))
#define ONE_SECOND        ( 10)   // 10 interrupts per second
#define TWO_SECONDS       (  2 * ONE_SECOND)
#define FIVE_SECONDS      (  5 * ONE_SECOND)
#define TEN_SECONDS       ( 10 * ONE_SECOND)
  setup_timer_0(RTCC_INTERNAL | RTCC_DIV_64);
Create a timer0 interrupt handler. Every software timer will count down to zero. If a counter reaches zero it will stop.:
// Timer0 interrupt, triggers every 100 miliseconds.
// Used for multiple software based timers.
#int_timer0
void timer0_isr()
  set_timer0(MS_100);        // fire again in 100 ms
  // Many software count down timers...
  if (MyTimer1)    MyTimer1--;
  if (MyTimer2)    MyTimer2--;
  if (MyTimer3)    MyTimer3--;
Example code to flash a led:
#define LED   PIN_A5
  output_low(LED);
  MyTimer1 = TEN_SECONDS;
  while(MyTimer1);
  output_high(LED);
  MyTimer1 = TWO_SECONDS;
  while(MyTimer1);
