naughty_mark
a question about CAN with disPIC33EP256MU814 |
Posted: Tue Sep 04, 2012 4:00 pm |
Hi, there
I am using disPIC33EP256MU814 with ccs pcd 4.133 compiler,
I am playing with CAN module now, however I got a CAN interrupt problem,
my code is below:
#if defined(__PCD__)
#include <33EP256MU814.h>
//#include <i2c.h>
#fuses HS,PR,NOWDT,ICSP2
#device ADC=12
#pin_select U1TX = PIN_D0
#pin_select U1RX = PIN_D1
#pin_select U2TX = PIN_D2
#pin_select U2RX = PIN_D3
#use RS232(UART1, STREAM = GSM, BAUD=9600, XMIT = PIN_D0 , RCV = PIN_D1 , BITS = 8, STOP = 1, PARITY = N, ERRORS) // Actual Baud is 38400 due to clock (10M not 20M)
#use RS232(UART2, STREAM = MODBUS, BAUD=9600, XMIT = PIN_D2 , RCV = PIN_D3 , BITS = 8, STOP = 1, PARITY = N, ERRORS) // Actual Baud is 38400 due to clock (10M not 20M)
//#use spi(MASTER, DO = PIN_G8, CLK = PIN_G6, mode = 3, stream=SPI_STREAM)
#use i2c(MASTER, I2C1,SCL = PIN_D10, SDA = PIN_D9 , FORCE_SW)
#pin_select IC1=PIN_F0
#pin_select C1TX = PIN_D6
#pin_select C1RX = PIN_D5
And I want to use interrupt to deal with incoming CAN messages, so I define CAN interrupt as follow:
#INT_CAN1RX
void can1_isr()
can_getd(rx_id, &in_data[0], rx_len, rxstat);
CAN_Mgs_Ready = TRUE;
canMsgCounter ++;
however, when I compiled, the ccs report an error as "Line 118(0,1): Invalid Pre-Processor directive"
If I change "#INT_CAN1RX" to "#INT_CAN1", the compile can pass, but once the message comes in, it triggers the default interrupt which means the program can NOT find the entrance for CAN interrupt of receive.
I also tried #int_canrx0 or #int_can0rx ect. but got the same compiling error.
Anything wrong I did? please help, Thanks a lot!
Regards
Mark |
naughty_mark
Posted: Tue Sep 04, 2012 4:59 pm |
Hi, there
I checked the latest PCD reference manual, and it said now only supports #INT_CAN1 and #INT_CAN2, all interrupts related to corresponding CAN share the same interrupt entrance.
However, I still have problem, as I mentioned, even I use "#INT_CAN1", the program can NOT find the proper interrupt, and it jumps into default interrupt instead! Any idea?
Thanks~ |
naughty_mark
Posted: Tue Sep 04, 2012 5:43 pm |
Hi, guys,
some updates.
the default interrupt was not caused by incoming CAN messages, a bug in my LCD display function. I fixed that.
Now, there is no interruption happened during CAN messages coming in!
I put some code that if CAN interruption is called, then micro will display "What!" on LCD display, but nothing there.
void test_can( void )
static int1 in=0;
char s[30];
restart_wdt();
can_init();
can_enable_interrupts(RB|RXOV|WAK);
sprintf(s, " CAN Init Done ");
printCusString(s);
sprintf(s, "CAN TEST ");
printCusString(s);
do
if (CAN_Mgs_Ready)
decode_can();
restart_wdt();
}while(canMsgCounter < 100);
And the CAN interruption now is
#INT_CAN1
void CAN1_isr()
unsigned int16 tmp;
char s[11];
if (C1INTF.rbif == 1/*can_kbhit()*/)
canMsgCounter ++;
tmp = C1INTF; //clear flags, no idea if it works well
sprintf(s, "Whaaaaaat!");
printCusString(s);
Any idea? |
naughty_mark
Posted: Tue Sep 04, 2012 7:30 pm |
Hi, guys
I made it works!
Firstly, there is #INT_CAN1 and #INT_C1RX interrupt name can be used, the first one is for general CAN event, the second for CAN1 receive interrupt and I used the second.
Secondly, I add "IEC2 |= 0x04; //enable can rx interrupt in interrupt register" after can_enable_interrupts() statement, you can find what this register does in micro data sheet.
Thanks for your guys concern.
Maybe more question further, who knows~ |
