Joined: 05 Sep 2007 Posts: 46 Location: Londrina - Brazil
Delays and Interrupts: a little problem...
Posted: Wed Jun 03, 2009 11:15 am
Hello Fellows...
One of the biggest problems when using delays and interrupts is that the compiler must disable interrupts while calling the delay function. (to prevent re-entrancy).
Some applications must use lots of delays to accomplish its tasks (like make some bit-bang communications timing just fine).
I wonder what programming techniques do you use to make less use of delays (when a delay is needed) that makes possible calling delays, and using interrupts at the same time.
Or, just some technique to make a precise delay time, not using delay_us, delay_ms or delay_cycles.
Thanks! _________________ Give a man a fish and you'll feed him for a day. Teach a man to fish, and you'll feed him for a lifetime.
Posted: Wed Jun 03, 2009 11:35 am
Create a timer0 interrupt handler. Every software timer will count down to zero. If a counter reaches zero it will stop.:
// Timer0 interrupt, triggers every 100 miliseconds.
// Used for multiple software based timers.
#int_timer0
void timer0_isr()
set_timer0(MS_100); // fire again in 100 ms
// Many software count down timers...
if (MyTimer1) MyTimer1--;
if (MyTimer2) MyTimer2--;
if (MyTimer3) MyTimer3--;
