using interrupt on Change port for 16F677
me
PostPosted: Wed Jun 03, 2009 12:22 pm     Reply with quote
Port A on the 16F677 is a change on Interrupt port. What is the #int_ for this interrupt. Also does the chip have built in commands to set it up or do I have to do it manually.
mkuang
PostPosted: Wed Jun 03, 2009 12:36 pm     Reply with quote
Check the .h file for your device in the devices folder. You will see all the available interrupts towards the bottom. Should be something like #int_xxx.
