ELM and OBD
karth
ELM and OBD
PostPosted: Fri Jun 05, 2009 9:43 am     Reply with quote
Does anybody knows the code for the following:
Hi I finally got the sae spec...
Here is the next question, I am trying to get from the obd bus to elm chip following:
Description Hex sae spec
Vehicle Speed ----> 01 0D J1979 TABLE B2x working!!!
ENGINE RPM ----> 01 0C J1979 TABLE B2x working!!!
Key Position ----> don't know
Brake Pedal status ----> don't know
Accel. Pedal status ----> don't know
Clutch Pedal status ----> don't know
Hand Brake status ----> don't know
Gear Status/auto or manual ----> 01 65 J1979 TABLE B2x notworking!!! respond: nodata
Could you show me a sample of saej2178 sample for example brakes the code provided below, I was trying this all yesterday and I was not able to figure out what I need:
Brakes-(See Table 14.)
Primary ID: Brakes
Command ID: $32
Status ID: $33
