match0927
Joined: 26 May 2009 Posts: 3 Location: Halifax, Nova Scotia, Canada
| treat MMC card as a big EEPROM |
Posted: Tue May 26, 2009 8:48 am |
| If I just wanna use MMC card as an EEPROM. e.g. just read or write a byte to some address. Is there a simple code to implement? I do not need create a file on the card then read it via the PC. Thanks. |
asmallri
Joined: 12 Aug 2004 Posts: 1678 Location: Perth, Australia
| Re: treat MMC card as a big EEPROM |
Posted: Tue May 26, 2009 9:48 pm |
| match0927 wrote: | | If I just wanna use MMC card as an EEPROM. e.g. just read or write a byte to some address. Is there a simple code to implement? I do not need create a file on the card then read it via the PC. Thanks. |
You just need the basic low level SPI drivers. You need to take into account that unlike an EEPROM you cannot just change the location of a single byte but instead must read in the target sector into RAM (512 bytes) modify one or more bytes of interest, then write back the modified sector. Another important consideration is that the write endurance of an EEPROM is orders of magnitude higher than an MMC card. _________________ Regards, Andrew
Posted: Wed May 27, 2009 6:19 am |
| asmallri wrote: | | match0927 wrote: | | If I just wanna use MMC card as an EEPROM. e.g. just read or write a byte to some address. Is there a simple code to implement? I do not need create a file on the card then read it via the PC. Thanks. |
You just need the basic low level SPI drivers. You need to take into account that unlike an EEPROM you cannot just change the location of a single byte but instead must read in the target sector into RAM (512 bytes) modify one or more bytes of interest, then write back the modified sector. Another important consideration is that the write endurance of an EEPROM is orders of magnitude higher than an MMC card. |
So is there such a kind of code here? Very thanks? |
arunb
| RE: |
Posted: Fri May 29, 2009 4:21 am |
| Quote: |
Another important consideration is that the write endurance of an EEPROM is orders of magnitude higher than an MMC card |
Do this mean MMC will wear out faster than EEPROM ??
thanks
arunb |
asmallri
| Re: RE: |
Posted: Fri May 29, 2009 6:56 am |
| arunb wrote: | | Quote: |
thanks
arunb |
Yes. _________________ Regards, Andrew
