I am confused.........
Lion
PostPosted: Tue May 26, 2009 11:16 pm     Reply with quote
Hello everyone,
First of all, I am so sorry to post my question again in new topic but I really can not figure out.
I am using PIC 16F877 and CCS 3.222 version, MPLAB V8.1 .
My question is that I am using UV tron flame detector.
When the sensor detect the fire, it will output_high.
I am using UV tron and Temperature sensor at the same time.
I know that I can use " while(! input(PIN_D5)) " to wait for the PIN_D5 go high or use "while(input(PIN_D5))" to wait for the PIN_D5 go low.
My question is that may I use "if" to do the same thing? I mean that I have two conditions for " if " loop. One is " Temp>30 " and the other one is the output_high of UV sensor .
May I use " if (Temp> 30 && input(PIN_D5))" ? ==> to check Temp>30 and wait for PIN_D5 output_high.
So far, I tried many ways but it can not get in the " if loop " Sometimes when Temp> 30 but PIN_D5 does not high. The code get in the loop.
I am confused. I use many "goto" command in my code. Does it damage the code structure?
In "Problem 1",(see the code) I try to check two conditions but it can not get in the "Problem 1" code in the beginning but I tries many method.
Now it always gets in the "Problem One" code but the flame detector do not detect the fire (if detect the fire, flame detector will output high). I do not understand why the code does not consider the condition?
My second question:
May I use the condition like (input(PIN_A2)!=0) or (input(PIN_A2)>1)
or (input(PIN_A2)==0)
The syntax is correct or not? If the PIN_A2 is used to check the flame detector output is high or low.
I really need someone help me to figure out.
Any help will be really really apprecitated.
Thank you so much
#include <16F877.h>
#device ADC=10
#use delay(clock=10000000)
#include<stdio.h>
#include <math.h>  // for temperature sensor
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
enable_interrupts(global);
//while(1)
       delay_ms(3000);
       output_high(PIN_D0); //go forward ;  this pin do not decide yet.
       output_high(PIN_D1); // go forward ;  this pin do not decide yet.
       output_high(PIN_C0); //Start Fire Gun
       output_high(PIN_C1); //Start barbette
       delay_ms(5000);  // initial ans settle down everything
start1:
//*** Temperature Sensor Code in this line ***///
        printf("Temperature now is in start1 %d\n\r",Temp);
        delay_ms(700);
        Ultrasonic();
        delay_ms(700);
if (Temp>29 && input(PIN_A2))  ==============> Problem 1
output_low(PIN_D0);  //stop Mother Vehicle
output_low(PIN_D1);  //stop Mother Vehicle
delay_ms(1000);      //This delay is due to inertia of DC motor
output_low(PIN_C0);  //
delay_ms(2000);
output_low(PIN_C1);
//printf("Find the Fire\n\r");
else if(Temp>29)
start2:
   if(distance6<27&&distance6>16&&distance5>12&&distance5<19)
printf("Distance 6 and 5 are good .Temperature is %d  \n\r ", Temp);
          delay_ms(3000);
          output_low(PIN_D0);   // Stop Forward ;
          output_low(PIN_D1);   // Stop Forward ;
          output_low(PIN_C0);   // Stop Fire Gun;
          output_low(PIN_C1);   // Stop the barbette;
          output_high(PIN_E0);  //Open the door.
          output_high(PIN_C2);  //Open the door.
          output_low(PIN_C2);
//**now DV1 and DV2 come out **//
          delay_ms(1500);
connect_again:
          output_low(PIN_C5);
          output_high(PIN_C5);
          delay_ms(1500);
//*** wireless connect code.  I do not show in this line***//
          delay_ms(3000);
          if(kbhit())
             TempDV1=getc();
             delay_ms(2500);
             output_low(PIN_C5); // For some function purpose
             output_high(PIN_C5);// For some function purpose
             delay_ms(1500);
             delay_ms(3000);
           if(kbhit())
          TempDV2=getc();     //In here, maybe I need put     TempDV2ACK=getc(); to get ACK return
          delay_ms(2000);
          output_low(PIN_C5);
          if (TempDV1>28 && TempDV1<120 || TempDV2>28 &&
        TempDV2<120)
              if (TempDV2>TempDV1+3)  //DV2 is higher than DV1
                  output_high(PIN_D3);
                  output_high(PIN_D4);   //turn_right
                  delay_ms(7000);
                  output_low(PIN_D3);    //stop turn_right ;
                  output_low(PIN_D4);    //Stop turn_right ;
                  delay_ms(1500);        //for relay, it needs time to release.
                  output_high(PIN_D0);   //  go_straight();
                  output_high(PIN_D1);   //  go_straight();
DV1_Detect:
                  if ( Temp>29&& input(PIN_A2))
                      output_low(PIN_D0);   //stop();
                      output_low(PIN_D1);
                                                     //motor
                      output_low(PIN_C0);  //Stop Fire Gun
                      delay_ms(2000);      //this delay is due to inertia of DC
                                                    //motor
                      output_low(PIN_C1);  //Stop the barbette
                      goto DV1_Detect;
               else if(TempDV1>TempDV2+3)
                  output_high(PIN_B3);   //turn_left();
                  output_high(PIN_C3);   //turn_left();
                  delay_ms(7000);
                  output_low(PIN_B3);    //stop turn_left;
                  output_low(PIN_C3);    //Stop turn_left;
                  delay_ms(1500);
DV2_Detect:
                  if( Temp>29 && input(PIN_A2)) //Detect Temp>29 and check
        //flame detector is
        //output_high
                      output_low(PIN_D1);   //stop();
                                                    //motor
                                                     //motor
                      printf("Find the FIRE ")
                      goto DV2_Detect;
                 goto connect_again;
          goto connect_again;
       goto start2;
goto start1;
SherpaDoug
PostPosted: Wed May 27, 2009 10:25 am     Reply with quote
If you can cut your program down to 20 or 30 lines you will get more help.
I would start by drawing a simple flowchart of your code, and maybe read a book about programming structure.
PostPosted: Wed May 27, 2009 4:23 pm     Reply with quote
Thank you for your suggestion.
I will cut it down and ask them in next topic.
Thank you so much.
PostPosted: Thu May 28, 2009 2:33 am     Reply with quote
No.
Don't keep launching new topics. Doing so, will not help, and makes it impossible for people to see what has 'passed'.When you add a post to the old topic, it automatically moves up the board, so keep the questions about a single problem, in a single thread. Only launch a new topic, once the problem is abandoned or solved, and you are asking about something else.
Launching new topics about the same question, is a way to annoy some of the people here, and reduce the chance of getting answers....
apcaye
PostPosted: Thu May 28, 2009 10:31 am     Reply with quote
Totally agreed, Ttelmah. I was trying to help Lion in a previous thread with the same problem as this one, but now I don't feel motivated to continue supporting him/her.
Adriano.
