Question about #INT_SSP
FoxtrotMike
PostPosted: Wed May 27, 2009 2:07 pm     Reply with quote
Hi:
I have to interface a device with a PC. Said device outputs it's data thru a Sync Serial Port, requiring to be provided with a clock signal. I'm using a PIC18 to provide the interface, reading data from the device via SPI and sending it to the PC via UART.
The data reading process starts with a pushbutton, which is read thru the INT_RB interrupt. Currently, I'm using the TIMER1 interrupt to force reading of the device.
This is the code I'm using:
#include <18F252.h>
#fuses HS,NOPROTECT,NOWDT,PUT
#use rs232(baud=2400, parity=N, bits=8, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#use standard_io(A)
#use standard_io(B)
#use standard_io(C)
// DEFINES //
#define SPI_MODE_0 (SPI_L_TO_H|SPI_XMIT_L_TO_H)
#define SPI_MODE_3 (SPI_H_TO_L|SPI_XMIT_L_TO_H)
#define PRESET 63869
// GLOBALS //
#byte PORTB = 0x0F81
int1 flag = 0;
int data, changes, last_b;
// PORT_B INTERRUPT //
#INT_RB
void portb_isr()
   changes = last_b ^ PORTB;
   last_b = PORTB;
   /////////////// PIN_B7 ///////////////
   //Detect falling edge on PIN_B7
   if (bit_test(changes,7)&& !bit_test(last_b,7))
      flag = 1;
   //Detect rising edge on PIN_B7
   if (bit_test(changes,7)&& bit_test(last_b,7))
      flag = 0;
// TMR1 INTERRUPT //
#INT_TIMER1
void timer1_isr()
   if(flag)
      data = spi_read(0xAA);
      putc(data);
   set_timer1(PRESET);
// MAIN ROUTINE //
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   set_timer1(PRESET);
   setup_timer_2(T2_DIV_BY_16, 129, 1);
   setup_spi(SPI_MASTER|SPI_MODE_1|SPI_CLK_T2);
   enable_interrupts(INT_RB);
So far it works alright, but I'd like to know if there's a way to use the #INT_SSP interrupt in a similar way to the #INT_RDA interrupt. I've used the UART quite a bit, but the SPI is something of a mystery to me. Also, I think that using a timer interrupt for this uses more resources than if I was reading SPI activity directly.
BTW, the code I tried for #INT_SSP was this:
#INT_SSP
void spi_isr()
   if(flag&&spi_data_is_in())
      putc(data);
I haven't had much luck with #INT_SSP, so if anyone can give me a pointer on how to implement it, I'd really appreciate it.
Best regards, and thank you in advance!!
PostPosted: Wed May 27, 2009 3:12 pm     Reply with quote
Why do you need #int_ssp for an SPI Master ? The master generates
the clock (SCLK). The master controls when the slave device sends
its data to the master.
When you do this, you are clocking out 0xAA to the slave device and
you're also clocking in a byte (to the master) from the slave. The byte
from the slave will be placed in 'data'.
