CCP4 PWM 18F66J60
Franck26
CCP4 PWM 18F66J60
PostPosted: Thu May 14, 2009 3:38 am     Reply with quote
I've got some difficulty to have a PWM signal on CCP4 (RD2).
I've already had a look at this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=30035&highlight=ccp4
   ClearWatchDog();
   setup_adc_ports(NO_ANALOGS);
   LED_PinInit(); // RD2 is an output.
   setup_timer_2(T2_DIV_BY_1, 255, 1);
   setup_ccp4(CCP_PWM);
   set_pwm4_duty(128);   // 50% duty cycle
      ClearWatchDog();
Fuse:
#device PIC18F66J60
#device   ICD=TRUE
#FUSES   DEBUG            // Debug mode for use with ICD.
#FUSES   NOWDT            // No Watch Dog Timer
#FUSES   WDT16
#FUSES   NOPROTECT      // Code not protected from reading
#FUSES   HS                  // High Speed Oscillator
#FUSES   NOIESO            // Internal external Switch Over mode diasabled
#FUSES   NOFCMEN            // Fail-Safe clock disabled
#FUSES   PRIMARY            // Primary clock is system clock when scs=00
#FUSES   ETHLED            // Ethernet LED enabled
#FUSES   STVREN            // Stack full/underflow will cause reset
#FUSES   IESO               // Internal External Switch Over mode enabled
#FUSES   FCMEN               // Fail-safe clock monitor enabled
#FUSES   NOXINST            // Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use   delay(clock=25M)
CCP4 (RD2) output is going low (due to pin init) but it stay low Sad .
Do you have any idea?
Thanks,
Franck.
PostPosted: Thu May 14, 2009 11:40 am     Reply with quote
Post your compiler version.
Franck26
PostPosted: Thu May 14, 2009 12:19 pm     Reply with quote
Compiler version : PCD 4.083
Franck.
PostPosted: Thu May 14, 2009 12:27 pm     Reply with quote
ClearWatchDog();
Post those two functions, and all variable declarations used by them.
I need to be able to compile your test program.
Franck26
PostPosted: Thu May 14, 2009 1:04 pm     Reply with quote
typedef struct
   unsigned int b0:1;
   unsigned int b1:1;
   unsigned int b2:1;
   unsigned int b3:1;
   unsigned int b4:1;
   unsigned int b5:1;
   unsigned int b6:1;
   unsigned int b7:1;
}_Def_SFR_8;
volatile _Def_SFR_8   PORTD_TRIS;
volatile _Def_SFR_8   PORTD_LAT;
volatile _Def_SFR_8   PORTD_DATA;
#byte PORTD_TRIS   = 0x0F95      //@0x0F95
#byte PORTD_LAT   = 0x0F8C      //@0x0F8C
#byte PORTD_DATA   = 0x0F83      //@0x0F83
#define   ClearWatchDog()   #asm   CLRWDT   #endasm
#define   PIN_DIR_OUT   0
#define   PIN_LED_SYNC      PORTD_LAT.b2
#define   DIR_LED_SYNC      PORTD_TRIS.b2
void LED_PinInit(void)
   // Init pin.
   PIN_LED_SYNC = OFF;
   DIR_LED_SYNC = PIN_DIR_OUT;
Sorry, I know it looks overcomplicated to set a pin as output, it's just to keep a minimum of compatibility with other compiler...
The pin is correctly set as output, I can see that cos there is a pull-up connected and the voltage goes to 0 after init.
Thanks,
Franck.
PS: I won't have access to the forum until Monday.
PostPosted: Thu May 14, 2009 1:10 pm     Reply with quote
PIN_LED_SYNC = OFF;
Post the #define statement for 'OFF' so I can compile the program.
Franck26
PostPosted: Thu May 14, 2009 2:39 pm     Reply with quote
#define OFF 0
Thanks,
Franck.
PostPosted: Thu May 14, 2009 3:09 pm     Reply with quote
The problem is in the setup_ccp4() function. It's setting pin G3 to be
an output, but it really should be setting pin D2 as an output.
It's a bug in the compiler for the 18F66J60. For the larger PICs in this
series, CCP4 is on pin G2. But for the smaller 64-pin PIC, it's on D2.
You should tell CCS about this bug. (It's still in vs. 4.092).
If you are using standard i/o mode, you can fix it by manually setting
pin D2 to be an output, and set pin G3 back as an input, as shown below:
output_low(PIN_D2);
output_float(PIN_G3);
Franck26
PostPosted: Thu May 14, 2009 3:45 pm     Reply with quote
Thanks for your help Very Happy !!!
I'll try that on Monday.
Franck.
Franck26
PostPosted: Mon May 25, 2009 12:26 pm     Reply with quote
Sorry for the delay, I didn't get a chance to test those lines until now.
So I've tried:
output_low(PIN_D2);
//output_float(PIN_G3);
I had to remove output_float(PIN_G3) due to a compilation error (normal G3 doesn't exist on the 18F66J60).
Unfortunately, it doesn't change anything: the pin D2 is going low and stay in this state....
I'm going to try on another design to see if it's hardware...
Any other idea?
Thanks,
Franck.
Franck26
PostPosted: Mon May 25, 2009 12:50 pm     Reply with quote
Same problem on another design, with the same micro.
The problem is not hardware...
Franck.
PostPosted: Mon May 25, 2009 1:42 pm     Reply with quote
Your test program is too complicated. Try a very simple program:
#include <18F66J60.h>
#fuses HS,NOWDT,NOPROTECT
output_low(PIN_D2);   // Fix for bug in compiler
Franck26
PostPosted: Tue May 26, 2009 12:13 pm     Reply with quote
Thanks PCM,
It works, the problem was that after you told me to set manually pin D2 as output, I forgot to set the duty cycle (set_pwm4_duty(128))...
Thanks again,
Franck.
