Problem with LED dot matrix display
karthickiw
PostPosted: Sun Mar 29, 2009 7:12 am     Reply with quote
Hi friends,
I write the program to display the “Hello” in scrolling 7X60 LED display. I successful to scrolling the “Hello” massage in 7X60 LED display. I have problem with brightness of LED display Crying or Very sad . I don’t put any resistor for LED display. My coding is below….
#include<16f876.h>
#use delay(clock=20M)
#fuses NOWDT,HS, PUT, PROTECT, NODEBUG, BROWNOUT, NOLVP, CPD, WRT
#byte port_b=6
#define EXP_OUT_ENABLE PIN_A2    //RCK
#define EXP_OUT_CLOCK PIN_A1     //SCK
#define EXP_OUT_DO PIN_A0        //SER
#define NUMBER_OF_74595 7
#include <74595.C>
int inc=0,chr_no=31,column_no=56,last_inc;  // chr_no calculate from zero//
long int time2=0;
int CONST str_MAP[]={0x00 , 0x00 , 0x00 , 0x00 , 0x00,
                     0x7F , 0x08 , 0x08 , 0x08 , 0x7F,
                     0x00 , 0x38 , 0x54 , 0x54 , 0x54,
                     0x48 , 0x00 , 0x7F , 0x00 ,
                     0x38 , 0x44 , 0x44 , 0x44 , 0x38,
                     0x00 , 0x00 , 0x00 , 0x00 , 0x00};
#INT_timer2                                                // move the character in display
void seconds_timer2()
time2++;
if(time2==100)
inc++;
if (inc==(chr_no+1)) inc=0;
time2=0;
int data[7]=0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7F;
   int  mask[7];  //ffef
   int Column=0,str=0,act=0;
   setup_timer_2(T2_DIV_BY_16,255,1);
   //disable_interrupts(INT_TIMER2);
   set_tris_b (0x00);
   str=chr_no;
   column=column_no;
   while (TRUE)
       IF (str==255)
     str=chr_no;
      mask[0]=data[0];                 // move the data into the mask temp space
      mask[1]=data[1];
      mask[2]=data[2];
      mask[3]=data[3];
      mask[4]=data[4];
      mask[5]=data[5];
      mask[6]=data[6];
     // port_b=0x00;
      write_expanded_outputs (data);  // sent the data to 74HC595
      act=str+inc;
      if (act >chr_no) act=act-(chr_no+1);        // rotate the string
      port_b= str_map[act];       // sent the string to port B
      data[0]=mask[0];                       // move the temp data into the data
      data[1]=mask[1];
      data[2]=mask[2];
      data[3]=mask[3];
      data[4]=mask[4];
      data[5]=mask[5];
      data[6]=mask[6];
      str--;                           // increase the string pointer
      if(Column==1)            // check colume is end or not
      data[0]=0XFF;             // referene from frist column
      data[1]=0XFF;
      data[2]=0XFF;
      data[3]=0XFF;
      data[4]=0XFF;
      data[5]=0XFF;
      data[6]=0X7F;
      Column=column_no;
      str=chr_no;
      Column--;
      if ( column <= 8)
         if (column==8)
         data[0]=0X7F;
         data[1]=0XFF;
         data[2]=0XFF;
         data[3]=0XFF;
         data[4]=0XFF;
         data[5]=0XFF;
         data[6]=0XFF;
         rotate_right( &data[0] , 1); //move the next column    L <---- R
      else if( column<=16)
      if (column==16)
         data[0]=0XFF;
         data[1]=0X7F;
         data[2]=0XFF;
         data[3]=0XFF;
         data[4]=0XFF;
         data[5]=0XFF;
         data[6]=0XFF;
         rotate_right( &data[1] , 1); //move the next column    L <---- R
      //rotate_right( &data[1] , 1);
      else if( column<=24)
        if (column==24)
         data[0]=0XFF;
         data[1]=0XFF;
         data[2]=0X7F;
         data[3]=0XFF;
         data[4]=0XFF;
         data[5]=0XFF;
         data[6]=0XFF;
         rotate_right( &data[2] , 1); //move the next column    L <---- R
      else if( column<=32)
        if (column==32)
         data[0]=0XFF;
         data[1]=0XFF;
         data[2]=0XFF;
         data[3]=0X7F;
         data[4]=0XFF;
         data[5]=0XFF;
         data[6]=0XFF;
         rotate_right( &data[3] , 1); //move the next column    L <---- R
      else if( column<=40)
        if (column==40)
         data[0]=0XFF;
         data[1]=0XFF;
         data[2]=0XfF;
         data[3]=0XFF;
         data[4]=0X7F;
         data[5]=0XFF;
         data[6]=0XFF;
         rotate_right( &data[4] , 1); //move the next column    L <---- R
      else if( column<=48)
        if (column==48)
         data[0]=0XFF;
         data[1]=0XFF;
         data[2]=0XfF;
         data[3]=0XFF;
         data[4]=0XFF;
         data[5]=0X7F;
         data[6]=0XFF;
         rotate_right( &data[5] , 1); //move the next column    L <---- R
      else if( column<=56)
        if (column==56)
         data[0]=0XFF;
         data[1]=0XFF;
         data[2]=0XfF;
         data[3]=0XFF;
         data[4]=0XFF;
         data[5]=0XFF;
         data[6]=0X7F;
         rotate_right( &data[6] , 1); //move the next column    L <---- R
   //delay_us(500);
    }// while
}// main
Give the idea to increase the brightness of the LED display…
asmboy
PostPosted: Sun Mar 29, 2009 7:55 am     Reply with quote
without knowing the schematic you have for the HARDWARE - posting all the code in the world won't get an answer. perhaps if you post the same question 5 more times - .............
yours is not a problem of CODE - but of lack of electronics understanding - it appears THAT problem is very common here and has no easy answer .
rote
Do you have a schematic?
PostPosted: Mon Apr 20, 2009 10:25 pm     Reply with quote
I am interested in this project. I look at code and test is working but I
don't know your circuits.
Please post schematic of this project.
Thank you.
OE8PCK
PostPosted: Tue Apr 21, 2009 6:03 am     Reply with quote
I would suggest driving the leds through transistors, this way you can adjust the brightness with resistors. Driving directly on this scale does not seem to be a good idea. Wink
Paul OE8PCK
karthickiw
Re: Do you have a schematic?
PostPosted: Fri May 22, 2009 11:21 pm     Reply with quote
Thank you.
Give me your email id, I send schematic.
