BLL
Joined: 11 Nov 2006 Posts: 181 Location: Birmingham, UK
18LF2620 serial port issue |
Posted: Wed Sep 09, 2015 3:18 pm |
Hi, I am being driven mad by a serial port!
I have an 18LF2620 running on 3.3V, using a 10MHz crystal. The port is on RC6 and 7. It is set at 9600Bd. Connected to this port is a pl2303 serial to USB converter, which goes to my PC. I use a resistive divider on the rcv line, so the 5V of the pl2303's TX line is reduced to 3.3V for the PIC.
I have used the very simple test program from the manual
printf("start");
while(true)
putc(getc()+1);
From the terminal program, if I type characters at more than about 2 per second, I see the correct response. If I slowly type, nothing comes back until I type faster, when it catches up! The power line is stable, the PIC has a 0.1 at its supply pins.
What is likely to be causing this strange behaviour please?
Any help much appreciated. |
Posted: Wed Sep 09, 2015 4:02 pm |
post a schematic -
your COMPLETE minimum program that shows the problem
and compiler version.
too much to guess at otherwise.
BTW: why are you using brand-X instead of nice reliable FTDI FT-232 chip ?? |
asmallri
Posted: Wed Sep 09, 2015 10:09 pm |
asmboy wrote: | post a schematic -
Reliable FTDI chip? You might want to look at some Arduino posts on the subject of FTDI drivers and what FTDI did in an attempt to nobble counterfeit chips. It blew back on FTDI big time. Turns out a lot of end users, including myself, buy products without knowing or caring who manufactures a minor component and are understandable upset when FTDI, through a windows update, bricked their product. A safe path for equipment designers, that do not control sourcing of the final components (as happens with outsourced manufacturing), is to use some other component. _________________ Regards, Andrew
asmallri
Re: 18LF2620 serial port issue |
Posted: Wed Sep 09, 2015 10:11 pm |
BLL wrote: | Hi, I am being driven mad by a serial port!
printf("start");
while(true)
putc(getc()+1);
Change your terminal program? _________________ Regards, Andrew
Joined: 01 Jul 2010 Posts: 9226 Location: Greensville,Ontario
Posted: Thu Sep 10, 2015 5:20 am |
couple of test options...
1) disconnect PIC and just loopback the USBTTL adapter and see what happens.....
2) Run the PIC at 5 volts and see what happens. This assuming it's rated for 5 volts, I didn't check...too many PICs, too little time !
BTW I've never had any issues with the $2 'knockoff' USBTTL modules.
ezflyr
Posted: Thu Sep 10, 2015 9:16 am |
asmallri wrote: | Reliable FTDI chip? You might want to look at some Arduino posts on the subject of FTDI drivers and what FTDI did in an attempt to nobble counterfeit chips. It blew back on FTDI big time. Turns out a lot of end users, including myself, buy their appliances without knowing or caring who manufactures a minor component and are understandable upset when FTDI, through a windows update, bricked their product. A safe path for equipment designers, that do not control sourcing of the final components (as happens with outsourced manufacturing, is to use some other component. |
The FTDI 'controversy' has absolutely nothing to do with the reliability of FTDI chips and drivers, so you are simply muddying the waters here to pontificate against FTDI, IMHO. As always, there are two sides to every story, and I think this article sums them both up pretty well:
http://tymkrs.tumblr.com/post/100749183024/ftdigate
I can sympathize with a company that tries to defeat those that steal their intellectual property, and diminish their business! But, on the other hand, the methods employed seem a bit heavy-handed! Clearly, it's not a simple issue! I just figured a more 'balanced' presentation on the topic was warranted.... _________________ John
If it's worth doing, it's worth doing in real hardware! |
BLL
18LF2620 serial problem |
Posted: Thu Sep 10, 2015 2:14 pm |
hanks for the reply. The simple test code was in my first post. I would include an image of the circuit if I could see how to do it!! It's a jpeg but the insert image doesn't appear right. Having not included as image before, I am lost! |
BLL
Posted: Thu Sep 10, 2015 2:17 pm |
To the gentleman suggesting loopback of the usb/serial adaptor, this works fine. I can't run the pic at 5V as there is an smt chip on the board which will fail if run over 3.3V, so that's not an option!! |
ezflyr
Posted: Thu Sep 10, 2015 2:45 pm |
Sorry for adding a bit of 'chafe' (above) to your thread !
To show us your schematic, you need to post the image to a free image hosting site (for example), and then post the link to the image here. Chances are you have a level incompatibility issue that we will be able to identify and help you to resolve once we see your schematic.
Example image hosting site: http://postimage.org/ _________________ John
Posted: Thu Sep 10, 2015 2:47 pm |
Well good news is you can eliminate the PC terminal program and the USBTTL module as 'loopback' functions fine...
So...
Using resistors to lower the 5V USB rcv signal to the 3V PIC will work to allow it to receive data ..
But, and there's always a 'but'....
Your 3V PIC might not be outputting a high enough '1' for the USBTTL module to see as a proper '1'. If it needs 80% of it's VCC of say 5 volts, that's 4 volt the PIC would have to produce and that can't happen runnin git on a VDD of 3 volts.
You might also post your test program, could be a simple thing like not having 'errors' in the USE RS232(....options...).
asmallri
Posted: Thu Sep 10, 2015 6:11 pm |
deleted because my mind was out of phase with reality. _________________ Regards, Andrew
ezflyr
Posted: Thu Sep 10, 2015 9:16 pm |
asmallri wrote: | Balanced? The pot calling the kettle black? Dementia?
Was't it you that unsolicitedly pontificated (I like that word) the use of an FDTI in lieu of the pl2303? |
No, that was asmboy that recommended the FTDI (you said FDTI???), not me! I'm not sure why that matters - he has an opinion on the matter, just like you!
Err, what is not 'balanced' about a post that includes more than 10 bullet points from *each* side of a given argument?? Did you even read the link??
Pot calling the kettle black??? Huh??? Here is the definition of 'Pontificate': to speak or express opinions in a pompous or dogmatic way. I wasn't expressing an opinion at all. What I did do was post a link to the arguments for your point of view, and against it. How is that 'the pot calling the kettle black'???
Dementia??? If you knew anything about *real* dementia you probably wouldn't go there......
I guess you are super-sensitive about this issue, and/or have a VERY thin skin _________________ John
asmallri
Posted: Thu Sep 10, 2015 9:44 pm |
Sorry ezflyr it is me suffering from dementia :-)
I mistakenly thought you posted this comment earlier: "BTW: why are you using brand-X instead of nice reliable FTDI FT-232 chip ??" _________________ Regards, Andrew
Posted: Fri Sep 11, 2015 9:48 am |
my comment was not meant to disrespect Prolific USB bridge chips but in my direct experience - the PL 2303 is not the best part for the application.
1- the part has no meaningful distribution in north america - just a lonely sales office in Canada.
AND
2- has been plagued in the past with issues of using an unsigned
driver for windows.
On the other hand my consultancy and a manufacturing partner have been shipping a 3 port bridge design "universal bridge card" that is an any-port to all ports hub :: with TTL, RS-232 +/-8v signalling, and USB courtesy of an FT-232 chip. we've shipped thousands of these as an OEM vendor for use in very high end research instruments , deployed round the globe.
And in the nearly 4 years of shipping the product have had near zero failures and no issues with driver support EVER. including during the period when FTDI were ( misguidedly IMHO) trying to protect their I.P. through suspect technical means.
I was not pleased with the driver debacle FTDI initiated , but i did not have a dog in the hunt due to no problems for me or my customers.
And it was in nobody's interest for me to engage in "knee-jerk" re engineering fixes for a part that was causing no grief to my bottom line or my customers.
Perhaps it is possible that they are not the nicest company in their tactics, but i have never had an issue with the parts being genuine , matching the spec sheet and being of high reliability in the field. When you sell to customers who include your $30 product in their $50K instrument - you don't fix what ain't broke..... |
