john2003 Guest
| bug I2C PCD |
Posted: Sun May 17, 2009 9:30 pm |
I use dspic30f4012 pcd 4.088
| Code: | void ds1307_get_time(BYTE &hr, BYTE &min, BYTE &sec)
i2c_start();
i2c_write(0xD0);
i2c_write(0x00);
i2c_start();
i2c_write(0xD1);
sec = bcd2bin(i2c_read() & 0x7f); //read data is 0x00 always. no change.
min = bcd2bin(i2c_read() & 0x7f); //read data ok. change every minute.
hr = bcd2bin(i2c_read(0) & 0x3f); //read data ok. change every hour.
i2c_stop();
void ds1307_get_date(BYTE &day, BYTE &mth, BYTE &year, BYTE &dow)
i2c_start();
i2c_write(0xD0);
i2c_write(0x03); // Start at REG 3 - Day of week
i2c_start();
i2c_write(0xD1);
dow = bcd2bin(i2c_read() & 0x7f); //read data ok
day = bcd2bin(i2c_read() & 0x3f); //read data ok
mth = bcd2bin(i2c_read() & 0x1f); //read data ok
year = bcd2bin(i2c_read(0)); //read data ok
i2c_stop();
john2003 Guest
Posted: Sun May 17, 2009 9:41 pm |
| but this code i use 16f876 no problem. |
Posted: Mon May 18, 2009 1:22 am |
It helps if you say what your problem is...
Also, the code is incomplete. Post a very small program demonstrating your problem. The program must be complete including fuses, etc., so it can be copy/pasted without changes. |
Posted: Mon May 18, 2009 3:38 am |
One 'obvious' thing would be the clock rate, and speed settings for the I2C bus. I'd guess that you are likely to be clocking the DSPic a lot faster than the 876, and unless you are explicity selecting 100K I2C, the bus may well be too fast for the chip....
A 'mini' program, that just shows the fault, so other people can compile it, and see what is wrong, is the only way to really go.
john2003 Guest
Posted: Mon May 18, 2009 3:58 am |
| Code: | // I can not read second. data second is 0x00 alway not change.
// but I can read minute and hour.
#include <30f4012.h>
#use delay(clock=32M,restart_wdt)
#fuses XT_PLL8,PROTECT,NOWDT,NOWRT,NOCKSFSM,CKSNOFSM,NODEBUG,NOCOE
#use rs232(baud=9600,UART1A,ENABLE=PIN_D1)
#define RTC_SDA PIN_F2
#define RTC_SCL PIN_F3
#use i2c(master, sda=RTC_SDA, scl=RTC_SCL)
BYTE bin2bcd(BYTE binary_value);
BYTE bcd2bin(BYTE bcd_value);
unsigned int8 hr,min,sec,min_buf,sec_buf;
void ds1307_init(void)
BYTE seconds = 0;
i2c_start();
i2c_write(0xD0); // WR to RTC
i2c_write(0x00); // REG 0
i2c_start();
i2c_write(0xD1); // RD from RTC
seconds = bcd2bin(i2c_read(0)); // Read current "seconds" in DS1307
i2c_stop();
seconds &= 0x7F;
delay_us(3);
i2c_start();
i2c_write(bin2bcd(seconds)); // Start oscillator with current "seconds value
i2c_start();
i2c_write(0x07); // Control Register
i2c_write(0x80); // Disable squarewave output pin
i2c_stop();
i2c_start();
i2c_write(0xD0);
i2c_write(0x00); // Start at REG 0 - Seconds
i2c_start();
i2c_write(0xD1);
sec = bcd2bin(i2c_read() & 0x7f); // REG 0
min = bcd2bin(i2c_read() & 0x7f); // REG 1
hr = bcd2bin(i2c_read(0) & 0x3f); // REG 2
i2c_stop();
BYTE temp;
BYTE retval;
temp = binary_value;
retval = 0;
while(true)
// Get the tens digit by doing multiple subtraction
// of 10 from the binary value.
if(temp >= 10)
temp -= 10;
retval += 0x10;
else // Get the ones digit by adding the remainder.
retval += temp;
return(retval);
// Input range - 00 to 99.
BYTE temp;
temp = bcd_value;
// Shifting upper digit right by 1 is same as multiplying by 8.
temp >>= 1;
// Isolate the bits for the upper digit.
temp &= 0x78;
// Now return: (Tens * 8) + (Tens * 2) + Ones
return(temp + (temp >> 2) + (bcd_value & 0x0f));
void main() {
ds1307_init();
while(true){
ds1307_get_time(hr,min,sec);
if(sec_buf!=sec){
sec_buf=sec;
printf("%X:%X:%X"hr,min,sec);
if(min_buf!=min){
sec_buf=min;
john2003 Guest
Posted: Mon May 18, 2009 4:04 am |
| Code: | #include <30f4012.h>
BYTE seconds = 0;
i2c_start();
i2c_start();
i2c_stop();
seconds &= 0x7F;
delay_us(3);
i2c_start();
i2c_start();
i2c_stop();
i2c_start();
i2c_write(0xD0);
i2c_start();
i2c_write(0xD1);
i2c_stop();
BYTE temp;
BYTE retval;
retval = 0;
while(true)
if(temp >= 10)
temp -= 10;
retval += 0x10;
retval += temp;
return(retval);
BYTE temp;
temp = bcd_value;
temp >>= 1;
temp &= 0x78;
void main() {
ds1307_init();
while(true){
if(sec_buf!=sec){
sec_buf=sec;
if(min_buf!=min){
min_buf=min;
Posted: Mon May 18, 2009 4:17 am |
So try specifying a clock rate for the I2C:
#use i2c(master, sda=RTC_SDA, scl=RTC_SCL, SLOW)
john2003 Guest
Posted: Mon May 18, 2009 4:33 am |
// not work
#use i2c(master, sda=RTC_SDA, scl=RTC_SCL, SLOW) |
FvM
Posted: Mon May 18, 2009 3:20 pm |
I tried your last code version on a PIC24FJ128GA106 with a DS1337 RTC connected and it did display seconds as expected.
But I found a PCD bug with I2CBRG setup. For a clock frequency of 32 MHz, it should be set to 0x0122. Unfortunately, only an 8-Bit value is set. The programmer seems to have forgotten, that he's dealing with a 16-Bit processor.
| Code: | 02C6 B3C220 mov.b #0x22,0x0000
02C8 B7E204 mov.b 0x0000,0x0204 |
The erroneous setting results in about 850 kHz I2C clock.
Set I2CBRG manually in your code as a workaround.
| Code: | #word I2CBRG = 0x204
I2CBRG = 0x122; |
Best regards,
Frank |
john2003 Guest
Posted: Mon May 18, 2009 11:26 pm |
| Why i can read hour and minute. but i can not read second. |
FvM
Posted: Tue May 19, 2009 12:02 am |
Don't know. It may be related to the wrong frequency. Don't ask, please try.
I used most recent PCD V4.092. I didn't check for possible additional bugs with V4.088 or special
issues with dsPIC30 code. However, PIC24 I2C code has been operational for me since V4.079.
Because my application has a 16 MHz clock, I wasn't aware of the said bug. |
