vidvranjek
PWM problem |
Posted: Tue May 12, 2009 12:40 pm |
Hi!
I'm still a newbee to C and PIC programming, so..... I'm also not english...
OK, here is my problem:
I'm trying to program a PIC to move about 6 servos simultaneously without using the internal PWM. I don't know where I went wrong (it's probably just the lack of C knowledge but please help me, I'm losing my mind with that!!
For starters I'm just trying to move 2 servos and it just doesn't do the job write. Here is the code (I'll post the whole thing in case... so just ignore the first part, its for the keypad and it works great). Both servos work until the time of the 1. servo isn't smaller than the time of the 1. servo.
Here it is... PLEASE HELP ME
#include "E:\Documents and Settings\Vid\My Documents\PIC\16F876\Servoti + tipkovnica\servoti+tipkovnica.h"
#define LCD_DATA_PORT b
#define LCD_TYPE 2
#define LCD_TRIS_LOCATION trisb
//#include <lcd.c>
int1 gor, dol, levo, desno, naprej, nazaj, enter, izhod, meni;
unsigned long pwm;
unsigned long pb[2];
unsigned long s[2];
int8 pin[2];
int n,x,y,temp,q;
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_8);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_2304MS);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
set_adc_channel(pin_a0);
WHILE(1)
output_high(pin_a1); //KEYPAD
if(input_state(pin_a4)==1){gor=1;} else gor=0;
if(input_state(pin_a5)==1){dol=1;} else dol=0;
if(input_state(pin_c7)==1){levo=1;} else levo=0;
output_low(pin_a1);
output_high(pin_a2);
if(input_state(pin_a4)==1){izhod=1;} else izhod=0;
if(input_state(pin_a5)==1){naprej=1;} else naprej=0;
if(input_state(pin_c7)==1){nazaj=1;} else nazaj=0;
output_low(pin_a2);
output_high(pin_a3);
if(input_state(pin_a4)==1){meni=1;} else meni=0;
if(input_state(pin_a5)==1){enter=1;} else enter=0;
if(input_state(pin_c7)==1){desno=1;} else desno=0;
output_low(pin_a3);
if (pwm>2500){pwm=2500;}
if (pwm<500){pwm=500;}
if (s[0]>2201){s[0]=2200;} // s[0] = 1. servo position
if (s[0]<799){s[0]=800;} // s[1] = 2. servo position
if (levo==1) {s[0]=s[0]+20;}
if (desno==1) {s[0]=s[0]-20;}
s[1]=read_adc()+1000;
n=2;
pb[0]=s[0];
pb[1]=s[1];
for( x=0; x<n; x++) // bubble sort
for( y=0; y<n-1; y++)
if(pb[y]>pb[y+1])
temp = pb[y+1];
pb[y+1] = pb[y];
pb[y] = temp;
for(q=0;q<n;q++)
if(s[q]==pb[0]){pin[q]=pin_b0;}
if(s[q]==pb[1]){pin[q]=pin_b1;}
// if(s[0]>s[1]){pin[1]=pin_b0;pin[0]=pin_b1;} else pin[0]=pin_b0;pin[1]=pin_b1;
// if(s[0]<s[1]){output_high(pin_b5);} else output_low(pin_b5);
// if(pin[1]==pin_b0) {output_high(pin_b4);} output_low(pin_b4);
output_high(pin_b0);
output_high(pin_b1);
delay_us(pb[0]);
output_low(pin[0]);
delay_us(pb[1]-pb[0]);
output_low(pin[1]);
delay_us(20000-pb[1]);
Posted: Tue May 12, 2009 2:19 pm |
Quote: | set_adc_channel(pin_a0); |
This is wrong. The ADC channel is a number such as 0, 1, or 2, etc.
It's not a CCS pin constant.
If you still have problems, then post this file:
Quote: | servoti+tipkovnica.h |
Also post your compiler version. |
bungee-
Posted: Tue May 12, 2009 2:23 pm |
I have posted a code for multiple servos on PIC18F4550, but it can be rewriten for other PIC-s ....
Here is the link. |
