Nokia 6100 display with 18F8722
Audi80
PostPosted: Thu May 07, 2009 6:45 am     Reply with quote
Hi there, i´ve bought two nokia displays to work in the new project i´m developing. And i´ve searched in the net for a good ccs example and found this one:
#include <18F8722.h>
#FUSES INTRC                       //Crystal Osc (<= 4mhz)
#FUSES PUT                      //Power Up Timer
#FUSES NOBROWNOUT               //Don't Reset when brownout detected
#define LCD_RESET   PIN_J6
#define LCD_CS   PIN_J7
#define SPI_CLK  PIN_C3
#define SPI_DO   PIN_C5
#define LED1 PIN_J0
#define LED2 PIN_J1
#bit SSPEN = 0xFC6.5
#include <bmp.h>
// Epson S1D15G10 Command Set
#define DISON       0xaf
#define DISOFF      0xae
#define DISNOR      0xa6
#define DISINV      0xa7
#define SLPIN       0x95
#define SLPOUT      0x94
#define COMSCN      0xbb
#define DISCTL      0xca
#define PASET       0x75   // 00,131
#define CASET       0x15   // 00,131
#define DATCTL      0xbc
#define RGBSET8     0xce
#define RAMWR       0x5c
#define RAMRD       0x5d
#define PTLIN       0xa8
#define PTLOUT      0xa9
#define RMWIN       0xe0
#define RMWOUT      0xee
#define ASCSET      0xaa
#define SCSTART     0xab
#define OSCON       0xd1
#define OSCOFF      0xd2
#define PWRCTR      0x20
#define VOLCTR      0x81
#define VOLUP       0xd6
#define VOLDOWN     0xd7
#define TMPGRD      0x82
#define EPCTIN      0xcd
#define EPCOUT      0xcc
#define EPMWR       0xfc
#define EPMRD       0xfd
#define EPSRRD1     0x7c
#define EPSRRD2     0x7d
#define NOP         0x25
#define ENDPAGE     131
#define ENDCOL      131
//a few basic colors
#define RED         0xE0                           // Color Code
#define GREEN       0x1C
#define BLUE        0x03
#define YELLOW      0xFC
#define MAGENTA     0xE3
#define CYAN        0x1F
#define BLACK       0x00
#define WHITE       0xFF
#use fast_io(C)
/* Table Font Size 5x7 Pixel */
const unsigned char font[475] =
   0x00 , 0x00 , 0x00 , 0x00 , 0x00 ,                  // Sp
   0x00 , 0x06 , 0x5F , 0x06 , 0x00 ,                      // !
   0x07 , 0x03 , 0x00 , 0x07 , 0x03 ,                      // ,
   0x24 , 0x7E , 0x24 , 0x7E , 0x24 ,                      // #
   0x24 , 0x2B , 0x6A , 0x12 , 0x00 ,                      // $
   0x63 , 0x13 , 0x08 , 0x64 , 0x63 ,                      // %
   0x36 , 0x49 , 0x56 , 0x20 , 0x50 ,                      // &
   0x00 , 0x07 , 0x03 , 0x00 , 0x00 ,                      // //
   0x00 , 0x3E , 0x41 , 0x00 , 0x00 ,                      // (
   0x00 , 0x41 , 0x3E , 0x00 , 0x00 ,                      // )
   0x08 , 0x3E , 0x1C , 0x3E , 0x08 ,                      // *
   0x08 , 0x08 , 0x3E , 0x08 , 0x08 ,                      // +
   0x00 , 0xE0 , 0x60 , 0x00 , 0x00 ,                      // ,
   0x08 , 0x08 , 0x08 , 0x08 , 0x08 ,                      // -
   0x00 , 0x60 , 0x60 , 0x00 , 0x00 ,                      // .
   0x20 , 0x10 , 0x08 , 0x04 , 0x02 ,                      // /
   0x3E , 0x51 , 0x49 , 0x45 , 0x3E ,                      // 0
   0x00 , 0x42 , 0x7F , 0x40 , 0x00 ,                      // 1
   0x62 , 0x51 , 0x49 , 0x49 , 0x46 ,                      // 2
   0x22 , 0x49 , 0x49 , 0x49 , 0x36 ,                      // 3
   0x18 , 0x14 , 0x12 , 0x7F , 0x10 ,                      // 4
   0x2F , 0x49 , 0x49 , 0x49 , 0x31 ,                      // 5
   0x3C , 0x4A , 0x49 , 0x49 , 0x30 ,                      // 6
   0x01 , 0x71 , 0x09 , 0x05 , 0x03 ,                      // 7
   0x36 , 0x49 , 0x49 , 0x49 , 0x36 ,                      // 8
   0x06 , 0x49 , 0x49 , 0x29 , 0x1E ,                      // 9
   0x00 , 0x6C , 0x6C , 0x00 , 0x00 ,                      // :
   0x00 , 0xEC , 0x6C , 0x00 , 0x00 ,                      // ;
   0x08 , 0x14 , 0x22 , 0x41 , 0x00 ,                      // <
   0x24 , 0x24 , 0x24 , 0x24 , 0x24 ,                      // =
   0x00 , 0x41 , 0x22 , 0x14 , 0x08 ,                      // >
   0x02 , 0x01 , 0x59 , 0x09 , 0x06 ,                      // ?
   0x3E , 0x41 , 0x5D , 0x55 , 0x1E ,                      // @
   0x7E , 0x09 , 0x09 , 0x09 , 0x7E ,                      // A
   0x7F , 0x49 , 0x49 , 0x49 , 0x36 ,                      // B
   0x3E , 0x41 , 0x41 , 0x41 , 0x22 ,                      // C
   0x7F , 0x41 , 0x41 , 0x41 , 0x3E ,                      // D
   0x7F , 0x49 , 0x49 , 0x49 , 0x41 ,                      // E
   0x7F , 0x09 , 0x09 , 0x09 , 0x01 ,                      // F
   0x3E , 0x41 , 0x49 , 0x49 , 0x7A ,                      // G
   0x7F , 0x08 , 0x08 , 0x08 , 0x7F ,                      // H
   0x00 , 0x41 , 0x7F , 0x41 , 0x00 ,                      // I
   0x30 , 0x40 , 0x40 , 0x40 , 0x3F ,                      // J
   0x7F , 0x08 , 0x14 , 0x22 , 0x41 ,                      // K
   0x7F , 0x40 , 0x40 , 0x40 , 0x40 ,                      // L
   0x7F , 0x02 , 0x04 , 0x02 , 0x7F ,                      // M
   0x7F , 0x02 , 0x04 , 0x08 , 0x7F ,                      // N
   0x3E , 0x41 , 0x41 , 0x41 , 0x3E ,                      // O
   0x7F , 0x09 , 0x09 , 0x09 , 0x06 ,                      // P
   0x3E , 0x41 , 0x51 , 0x21 , 0x5E ,                      // Q
   0x7F , 0x09 , 0x09 , 0x19 , 0x66 ,                      // R
   0x26 , 0x49 , 0x49 , 0x49 , 0x32 ,                      // S
   0x01 , 0x01 , 0x7F , 0x01 , 0x01 ,                      // T
   0x3F , 0x40 , 0x40 , 0x40 , 0x3F ,                      // U
   0x1F , 0x20 , 0x40 , 0x20 , 0x1F ,                      // V
   0x3F , 0x40 , 0x3C , 0x40 , 0x3F ,                      // W
   0x63 , 0x14 , 0x08 , 0x14 , 0x63 ,                      // X
   0x07 , 0x08 , 0x70 , 0x08 , 0x07 ,                      // Y
   0x71 , 0x49 , 0x45 , 0x43 , 0x00 ,                      // Z
   0x00 , 0x7F , 0x41 , 0x41 , 0x00 ,                      // [
   0x02 , 0x04 , 0x08 , 0x10 , 0x20 ,                      // Back slash
   0x00 , 0x41 , 0x41 , 0x7F , 0x00 ,                      // ]
   0x04 , 0x02 , 0x01 , 0x02 , 0x04 ,                      // ^
   0x80 , 0x80 , 0x80 , 0x80 , 0x80 ,                      // _
   0x00 , 0x03 , 0x07 , 0x00 , 0x00 ,                      // `
   0x20 , 0x54 , 0x54 , 0x54 , 0x78 ,                      // a
   0x7F , 0x44 , 0x44 , 0x44 , 0x38 ,                      // b
   0x38 , 0x44 , 0x44 , 0x44 , 0x28 ,                      // c
   0x38 , 0x44 , 0x44 , 0x44 , 0x7F ,                      // d
   0x38 , 0x54 , 0x54 , 0x54 , 0x18 ,                      // e
   0x08 , 0x7E , 0x09 , 0x09 , 0x00 ,                      // f
   0x18 , 0xA4 , 0xA4 , 0xA4 , 0x7C ,                      // g
   0x7F , 0x04 , 0x04 , 0x78 , 0x00 ,                      // h
   0x00 , 0x00 , 0x7D , 0x00 , 0x00 ,                      // i
   0x40 , 0x80 , 0x84 , 0x7D , 0x00 ,                      // j
   0x7F , 0x10 , 0x28 , 0x44 , 0x00 ,                      // k
   0x00 , 0x00 , 0x7F , 0x40 , 0x00 ,                      // l
   0x7C , 0x04 , 0x18 , 0x04 , 0x78 ,                      // m
   0x7C , 0x04 , 0x04 , 0x78 , 0x00 ,                      // n
   0x38 , 0x44 , 0x44 , 0x44 , 0x38 ,                      // o
   0xFC , 0x44 , 0x44 , 0x44 , 0x38 ,                      // p
   0x38 , 0x44 , 0x44 , 0x44 , 0xFC ,                      // q
   0x44 , 0x78 , 0x44 , 0x04 , 0x08 ,                      // r
   0x08 , 0x54 , 0x54 , 0x54 , 0x20 ,                      // s
   0x04 , 0x3E , 0x44 , 0x24 , 0x00 ,                      // t
   0x3C , 0x40 , 0x20 , 0x7C , 0x00 ,                      // u
   0x1C , 0x20 , 0x40 , 0x20 , 0x1C ,                      // v
   0x3C , 0x60 , 0x30 , 0x60 , 0x3C ,                      // w
   0x6C , 0x10 , 0x10 , 0x6C , 0x00 ,                      // x
   0x9C , 0xA0 , 0x60 , 0x3C , 0x00 ,                      // y
   0x64 , 0x54 , 0x54 , 0x4C , 0x00 ,                      // z
   0x08 , 0x3E , 0x41 , 0x41 , 0x00 ,                      // {
   0x00 , 0x00 , 0x7F , 0x00 , 0x00 ,                      // |
   0x00 , 0x41 , 0x41 , 0x3E , 0x08 ,                      // }
   0x02 , 0x01 , 0x02 , 0x01 , 0x00                        // ~
void pset(unsigned char color, unsigned char x, unsigned char y);
void spi_command(int);
void spi_data(int);
void LCD_Set_Box(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2);
void LCD_Fill_Screen(unsigned char color,unsigned char x1, unsigned char y1,unsigned char x2,unsigned char y2);
void LCD_Initial(void);
void Draw_Color_Bar(void);
void LCDWrite130x130bmp(void);
void LCD_Print_Char(unsigned char fcolor, unsigned char bcolor, unsigned char x, unsigned char y,char c);
void LCD_Print_String(unsigned char fcolor,unsigned char bcolor, unsigned char x, unsigned char y,char *text);
   int aux = 0;
   int16 i,index;
   char String_Buff[30];                           // String Array Buffer
   setup_oscillator(OSC_4MHZ);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H|SPI_CLK_DIV_4);
  // setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED, 0, 1);
   set_tris_c(0x00);   // all outputs, can change to mask only hardware SPI bits if needed
   set_tris_j(0x00);
   /*Just to be sure that the pic is running*/
   while(aux++<50){
         output_high(LED1);
         output_low(LED2);
         delay_ms(50);
         output_low(LED1);
         output_high(LED2);
         delay_ms(50);
   LCD_Initial();
   Draw_Color_Bar();
   delay_ms(2000);
   LCD_Fill_Screen(RED,0,0,131,131);
   LCD_Fill_Screen(GREEN,0,0,131,131);
   LCD_Fill_Screen(BLUE,0,0,131,131);
   LCD_Fill_Screen(YELLOW,0,0,131,131);
   LCD_Fill_Screen(MAGENTA,0,0,131,131);
   LCD_Fill_Screen(CYAN,0,0,131,131);
   LCD_Fill_Screen(BLACK,0,0,131,131);
   LCDWrite130x130bmp();
   delay_ms(2000);
   spi_command(DATCTL);                                // datctl
   spi_data(0x00);
   spi_data(0);
   spi_data(0x01);
   spi_data(0);
   LCD_Fill_Screen(BLACK,0,0,131,131);                 // Fill Screen with Black Color
   sprintf(String_Buff," TEST ET-LCD6610 ");
   LCD_Print_String(YELLOW, BLACK, 7, 5,String_Buff);
   sprintf(String_Buff," WWW.ETTEAM.COM ");
   LCD_Print_String(CYAN, BLACK, 7, 15,String_Buff);
   sprintf(String_Buff," TEST RED COLOR ");
   LCD_Print_String(RED, BLACK, 7, 30,String_Buff);
   sprintf(String_Buff," TEST GREEN COLOR ");
   LCD_Print_String(GREEN, BLACK, 7, 45,String_Buff);
   sprintf(String_Buff," TEST BLUE COLOR ");
   LCD_Print_String(BLUE, BLACK, 7, 60,String_Buff);
   sprintf(String_Buff," TEST WHITE COLOR ");
   LCD_Print_String(WHITE, BLACK, 7, 75,String_Buff);
   sprintf(String_Buff," TEST MAGENTA COLOR ");
   LCD_Print_String(MAGENTA, BLACK, 7, 90,String_Buff);
   sprintf(String_Buff," TEST CYAN COLOR ");
   LCD_Print_String(CYAN, BLACK, 7, 105,String_Buff);
   sprintf(String_Buff," TEST YELLOW COLOR ");
   LCD_Print_String(YELLOW, BLACK, 7, 120,String_Buff);
   delay_ms(5000);
void pset(unsigned char color, unsigned char x, unsigned char y){
//  sets the starting page(row) and column (x & y) coordinates in ram,
//  then writes the colour to display memory.  The ending x & y are left
//  maxed out so one can continue sending colour data bytes to the 'open'
//  RAMWR command to fill further memory.  issuing any other command
//  finishes RAMWR.
  x += 2;                  // for some reason starts at 2
  spi_command(PASET);   // page start/end ram
  spi_data(x);
  spi_data(ENDPAGE);
  spi_command(CASET);   // column start/end ram
  spi_data(y);
  spi_data(ENDCOL);
  spi_command(RAMWR);    // write
  spi_data(color);
void spi_command(int dat){
   output_low(LCD_CS);      // enable chip
   SSPEN = 0;               // shut off hardware SPI allowing direct access to SPI in/out pins
   output_low (SPI_DO);     // output low on data out (9th bit low = command)
   output_high (SPI_CLK);
   delay_cycles(1);         // send clock pulse
   output_low (SPI_CLK);
   SSPEN=1;                 // turn hardware SPI back on
   spi_write(dat);          // make PIC do the work for the command byte
   output_high(LCD_CS);     // disable
void spi_data(int dat){
   SSPEN = 0;               // turn off hardware SPI allowing us direct access to SPI in/out pins
   output_high (SPI_DO);    // output high on data out (9th bit high = data)
   spi_write(dat);          // make PIC do the work for the data byte
/* Initial LCD-NOKIA6610 */
   // reset display
   output_high (LCD_CS);
   output_low (LCD_RESET);
   output_high (LCD_RESET);
   //init'd, now drop CS to send commands/data and raise when finished
    spi_command(DISCTL);  // display control
    spi_data(0x0C);      // 12 = 1100 - CL dividing ratio [don't divide] switching period 8H (default)
    spi_data(0x20);      // 32 = (128/4)-1 (round up) number of display lines for scanning
    spi_data(0x0C);      // 12 = 1100 - number of lines to be inversely highlighted
    spi_data(0x00);
    spi_command(COMSCN);  // common scanning direction
    spi_data(0x01);
    // 0 0 0 =   1 -> 80   81 -> 160
    // 0 0 1 =   1 -> 80   81 <- 160
    // 0 1 0 =   1 <- 80   81 -> 160
    // 0 1 1 =   1 <- 80   81 <- 160
    spi_command(OSCON);  // internal oscialltor ON
    spi_command(SLPOUT);  // sleep out
    spi_command(VOLCTR);  // electronic volume, this is the contrast/brightness
    spi_data(0x23);   // volume (contrast) setting - fine tuning
    spi_data(0x03);   // internal resistor ratio - coarse adjustment
    spi_command(PWRCTR);  // power ctrl
    spi_data(0x0f);      //everything on, no external reference resistors
    spi_command(DISINV);  // invert display mode
    spi_command(DATCTL);  // data control
    spi_data(0x00);   // normal display of page/column address, page scan direction
    spi_data(0x00);   // normal RGB arrangement
    spi_data(0x01);   // 8-bit grayscale
    spi_command(RGBSET8);   // setup 8-bit color lookup table  [RRRGGGBB]
  //RED
    spi_data(0);
    spi_data(2);
    spi_data(4);
    spi_data(6);
    spi_data(8);
    spi_data(10);
    spi_data(12);
    spi_data(15);
    // GREEN
    spi_data(0);
    spi_data(2);
    spi_data(4);
    spi_data(6);
    spi_data(8);
    spi_data(10);
    spi_data(12);
    spi_data(15);
    //BLUE
    spi_data(0);
    spi_data(4);
    spi_data(9);
    spi_data(15);
    spi_command(NOP);  // nop
   LCD_Fill_Screen(WHITE,0,0,131,131);
   spi_command(DISON);                // Display On
/*  (x1,y1)                  */
/*                    (x2,y2)   */
                 unsigned char y1,
             unsigned char x2,
             unsigned char y2)
   spi_command(CASET);                              // Page Start/Eend ram
   spi_data(x1);
   spi_data(x2);
   spi_command(PASET);                              // Column Start/End ram
   spi_data(y1);
   spi_data(y2);
/* Fill Screen With Color */
                     unsigned char x1,
                  unsigned char y1,
                  unsigned char x2,
                  unsigned char y2)
  unsigned int16 j;
  unsigned int16 total_bytes1;
  unsigned int16 total_bytes2;
  unsigned int16 total_bytes;
  LCD_Set_Box(x1, y1, x2, y2);
  spi_command(RAMWR);
  total_bytes1 = (x2 - x1 + 1);
  total_bytes2 = (y2 - y1 + 1);
  total_bytes = total_bytes1 * total_bytes2;
  for (j = 0; j < total_bytes; j++)
    spi_data(color);
/* Create 4-Bar Color */
   LCD_Fill_Screen(RED,0,0,131,33);
   LCD_Fill_Screen(GREEN,0,34,131,66);
   LCD_Fill_Screen(BLUE,0,67,131,99);
   LCD_Fill_Screen(WHITE,0,100,131,131);
   unsigned int16 j; // loop counter
   // Data control (need to set "normal" page address for Olimex photograph)
   spi_data(0x00); // P1: 0x00 = page address normal, column address normal, address scan in column direction
   spi_data(0x01); // P2: 0x01 = RGB sequence B-> G-> R(Invert Direction)
   spi_data(0x02); // P3: 0x02 = Grayscale -> 16
   // Display OFF
   spi_command(DISOFF);
   // Column address set (command 0x2A)
   spi_command(CASET);
   spi_data(0);
   spi_data(131);
   // Page address set (command 0x2B)
   spi_command(PASET);
   spi_data(0);
   spi_data(131);
   // WRITE MEMORY
   spi_command(RAMWR);
  // for(j = 0; j < 25740; j++)
     for (j=0;j<sizeof(picture);j++)
      spi_data(picture[j]);
   // Data control (return to "inverted" page address)
   spi_data(0x00); // P1: 0x01 = page address inverted, column address normal, address scan in column direction
   spi_data(0x01); // P3: 0x02 = Grayscale -> 16
   // Display On
   spi_command(DISON);
/* Print Char on Screen */
               unsigned char x,
   unsigned int i;
   LCD_Set_Box(x,y,x,y+7);
   spi_command(RAMWR);
   for(i=0;i<8;i++)
     if (1<<i & c)
        spi_data(fcolor);
        spi_data(bcolor);
/* Print String on Screen */
                  unsigned char x,
   unsigned char c;
   unsigned char t;
   unsigned int16 i;
   unsigned int16 j;
   while(*text != 0)
     t = *text;
     i = t - 32;
     i = i * 5;
     for(j = i; j < i+5; j++)
       c = font[j];
       LCD_Print_Char(fcolor, bcolor, x++, y, c);
     LCD_Print_Char(fcolor, bcolor, x++, y, 0);
     text++;
Im using a PIC18F8722 my problem is that the only thing i can see the display doing is changing its color from blue to white nothing else happens, when i was searching in the www i´ve found that this display may have two controllers one from epson and another from phillips and the diference is in the back PCB that changes (Green for Philips and Brown for epson) and i have both of them, is there any problem in this routines?? Thanks
PostPosted: Thu May 07, 2009 6:33 pm     Reply with quote
The driver as posted here is for the Epson controller. I found a site where the PCB colors are reversed from what you wrote, i.e. the one with the green PCB or GE-8 sticker is the Epson. A brown/orange PCB or GE-12 sticker is the Philips.
If you have this wrong it explains the display not working.
What is your compiler version number?
What voltage is your PIC running at?
Add the fuses NOLVP and NOWDT. Low Voltage Programming is used by only the cheapest 1% of programmers, mostly home-brew programmers. The watchdog is another thing you want to make sure is disabled during testing.
Another driver worth trying: http://ccsinfo.com/forum/viewtopic.php?t=26461
Audi80
PostPosted: Mon May 11, 2009 9:03 am     Reply with quote
Hi there ckielstra, thank you for your response.
My compiler version is 4.013
And my pic is running at 3.7V
The watchdog is disabled and i´ve already tried with almost every "#fuses" so i dont know what is the problem. I will try with the example that you gave me and tell if it works. Very Happy
Thanks again.
