New to PIC12F. OSC and pullup questions
BarberColman
PostPosted: Thu Jul 15, 2010 2:27 pm     Reply with quote
This is my CCS / PIC12F510 project. The program logic is OK. I am having trouble with setting up the the following.
1. Setting the oscillator to 4MHZ.
2. I have not enabled the a/d or timer functions. Do I need to disable anything to use the pins as general purpose.
3. I need to to set the MCLR as general purpose I/O.
4. Does output_high or output_low set the tris register?
5. I found setup_WDT(WDT_576MS); and restart_wdt();. Anything else to
My basic problem is I am not used to the CCS compiler so I am having switch from direct control of registers to the CCS way.
jbmiller
PostPosted: Thu Jul 15, 2010 2:44 pm     Reply with quote
Here's the 'front end stuff I use for my 12F683 projects...
#include <12f683.h>
#fuses INTRC_IO,NOWDT,NOPUT,NOPROTECT,NOMCLR
#use delay(clock=4000000)                // 4MHz xtal
// end of processor specific stuff
...it should help you a bit
the #fuses options are as follows
use internal RC osc allowing xtal pins to now be I/O pins
do NOT use WatchDogTimer
do NOT use PowerUpTimer
do NOT protect pgm memory
do NOT use external MClr allowing that pin to be an I/O pin
hope this helps
remember start with small programs first 'led blinking, hello world' stuff then test and add 'modules' as required.
hope this helps
Jay
PostPosted: Thu Jul 15, 2010 2:59 pm     Reply with quote
Use the forum's search page to search for 12F510.
There are several threads that can help. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=33435
