Very strange behaviour of a function! please help
robin171
PostPosted: Wed May 06, 2009 5:15 am     Reply with quote
I use PCWH v. 4.079 and PIC18F6720. I have the following code:
bool   perilex2,perilex3;
   perilex2 = PERILEX_POS2;
   perilex3 = PERILEX_POS3;
   if(perilex2) fputc('C',COM1);
   else fputc('c',COM1);
   if(perilex3) fputc('D',COM1);
   else fputc('d',COM1);
   read_perilex(&status,perilex2,perilex3);
#define PERILEX_POS2      input(PIN_F7)
#define   PERILEX_POS3      input(PIN_F6)
The code must detect a square wave on pin F7 or F6. When I check the pins with a scope, no signal is present on both pins.
The code prints "cdABcdaB" to the serial port (see read_perilex function below). Somehow the variables perilex2 and perilex3 are changed when passing them into the function read_perilex. What is the problem here?
When I try this: read_perilex(&status,false,false) it works fine..
void   read_perilex(status_t *status, bool step2, bool step3)
s_u8 p2_off_ctr,p2_on_ctr,p3_off_ctr,p3_on_ctr;
   if(step3)      fputc('A',COM1);
   else         fputc('a',COM1);
   if(step2)      fputc('B',COM1);
   else         fputc('b',COM1);
   if(!step3 && (status->perilex_position == PERILEX_STEP3))
      p3_on_ctr = 0;
      if(p3_off_ctr > 100) status->perilex_position = PERILEX_STEP1;
      else p3_off_ctr++;
   else if(step3)
      p3_off_ctr = 0;
      if(p3_on_ctr > 100) status->perilex_position = PERILEX_STEP3;
      else p3_on_ctr++;
   else if(!step2 && (status->perilex_position == PERILEX_STEP2))
      p2_on_ctr = 0;
      if(p2_off_ctr > 100) status->perilex_position = PERILEX_STEP1;
      else p2_off_ctr++;
   else if(step2)
      p2_off_ctr = 0;
      if((p2_on_ctr > 100) && (status->perilex_position != PERILEX_STEP3)) status->perilex_position = PERILEX_STEP2;
      else p2_on_ctr++;
PostPosted: Wed May 06, 2009 11:36 am     Reply with quote
You have created your own types. Please post the typedef or #define
statement for 'bool'.
What I would do, is to make a test program that checks if the variables
are passed properly. I would get rid of about 90% of your code,
to do this.
