2 very simple questions on the pic..
rikky_japp
PostPosted: Fri May 01, 2009 2:33 am     Reply with quote
hi
i have 2 simple questions on the pic16f690 that came with pickit2.
hope you can help
1. what code i can use to short between 2 pins of the chip??
i need to short 2 pins without using any FET transistor. grounding them?
2. how can i eliminate a pwm function for a while and then turn it on again?
what are the 2 operations to start and stop pwm (after the i define the
code of the frequency and the duty) ? i need the line to start and stop
it.
thanks Smile)
Wayne_
PostPosted: Fri May 01, 2009 5:49 am     Reply with quote
They may not be that simple to answer.
1. This all depends, you cannot "short" the 2 pins but you may be able to emulate a short. If they are digital and one pin is driven by the external hardware and you just need the other pin to match then read the first pin and output the level to the second pin.
If it is indeed a short you need so either side can drive the line then you have a problem.
2. This again depends on what state you want the PWM pin to be in when it is in the stopped state. The simple option is to either set the duty to full on of full off. The other option is to change the configuration for the pin from pwm to IO.
Is this homework or required for a school/university project you are working on ? It looks like it might be.
If you are upfront about it then you may get more help.
rikky
PostPosted: Sat May 02, 2009 11:26 pm     Reply with quote
My goal was to short between 2 external points, don't care how, just need to short them (to turn off a regulator for control).
This is a project in university, its not a simple one but I found my self deal with this simple question.
Do you know any good book that contains all the CCS C operations? To download for free ??
meereck
PostPosted: Sun May 03, 2009 2:08 am     Reply with quote
You can get the CCS Compiler Manual: go to http://ccsinfo.com/downloads.php and scroll to "Current Compiler Manuals"
Wayne_
PostPosted: Tue May 05, 2009 2:10 am     Reply with quote
Use a relay, the pic can turn it on and off which will produce your short.
bungee-
PostPosted: Tue May 05, 2009 5:45 am     Reply with quote
Can you elaborate the short between 2 pins. Is it a simple switch action or something else.
If this is a switch action and things have to be electricaly seperated, then use relay. If electrical seperation is not necessary then you could use Mosfet. Wink
PWM duty can be turned to 0 so there would be no outgoing pulse. Or you could change pin function from output to input, that would be another way.
